Grrr Posted September 21, 2016 Share Posted September 21, 2016 Grrr - Okay that lisp in #16 worked fine , in fact it's better than the original in that I don't have to select only polylines or only lines at a time. The real question though is why am I now able to run a lisp? I assume you added code which overcame whichever error I was getting as I still get no value when I run the original. Thats great to hear! And to elaborate the answer from my previous post: In AutoLISP there are extension functions, prefixed with vla-/vlax-/vlr-, which are part of the Visual Lisp (extension of AutoLISP), to load them (vl-load-com) must be used. The previous codes I posted, require this Visual Lisp - but for some reason they don't work for you, even after you use (vl-load-com). The last code I posted - doesn't require these VLISP extensions, so its a temporarily solution for you. I have no idea what might be the (real) problem, so look-up into ReMark's suggestions. And consider to hire someone like Lee Mac or Tharwat. Quote Link to comment Share on other sites More sharing options...
MisterJingles Posted September 22, 2016 Author Share Posted September 22, 2016 Thanks Grrr, I will look deeper into the cause at a later stage. For now the work-around will do what I need. Quote Link to comment Share on other sites More sharing options...
