Guinnessman Posted June 28, 2011 Share Posted June 28, 2011 Hi, I am having a problem with output size when rendering. From Draft right through to presentation the output size is greyed out so I cannot change it. I've never had this problem before. Have I inadvertantly clicked on something which disables the output size? Help !! Quote Link to comment Share on other sites More sharing options...
Raudel Solis Posted June 29, 2011 Share Posted June 29, 2011 post a screen shot. Quote Link to comment Share on other sites More sharing options...
Guinnessman Posted June 29, 2011 Author Share Posted June 29, 2011 Screen grab attached. Any ideas?? Quote Link to comment Share on other sites More sharing options...
Raudel Solis Posted June 29, 2011 Share Posted June 29, 2011 so your in Acad 2012, on the "tims workspace migration" up at top click it and select 3d modeling and rendering. you can always switch back later. Tell me what this does for you towards you problem. Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 29, 2011 Share Posted June 29, 2011 That's an unusual drawing file name there at the top: 03007-02ACAD_1_1_2385.sv$.dwg What happened? Your profile says AutoCAD 2009 but you are clearly using AutoCAD 2012. Profile change coming up? Quote Link to comment Share on other sites More sharing options...
Raudel Solis Posted June 29, 2011 Share Posted June 29, 2011 with the $ symbol i can probably suspect that there was some needed recovery along the way. Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 29, 2011 Share Posted June 29, 2011 Wonder if that has anything to do with his problem? Quote Link to comment Share on other sites More sharing options...
Guinnessman Posted June 29, 2011 Author Share Posted June 29, 2011 Thanks Raudel. Switching to the 3D ribbon gave me access to the output size. When they first brought the ribbon out I couldn't get used to it so reverted back to old school drop downs. Think I may need to convert to ribbon now though. There are sooo many more rendering tools on the ribbon!!! ReMark - You are correct, I haven't updated my profile on here for ages. (I'll get right on that). The workstation I am using doesn't like rendering too much and crashes on a regular basis. The one in the screen grab was recovered this morning after todays first crash. I need a bigger computer!!! Thanks for all your help guys. Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 29, 2011 Share Posted June 29, 2011 What are the specs on the computer you are using now? Have you made any changes using 3dconfig's Manual Tune feature? Quote Link to comment Share on other sites More sharing options...
Guinnessman Posted June 29, 2011 Author Share Posted June 29, 2011 Here are my specs. (Please don't laugh too hard) Windows XP 32 bit 2 x Intel® Xeon® CPU 5150 @2.66GHz 3.25GB RAM NVIDIA Quadro FX 3500 I've only recently started rendering, and have told the powers that be that if I am going to be doing this regularly then I will need a workstation upgrade. That was 3 weeks ago. Not holding my breath. Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 29, 2011 Share Posted June 29, 2011 Have you tried the RPREF command? Quote Link to comment Share on other sites More sharing options...
Guinnessman Posted June 29, 2011 Author Share Posted June 29, 2011 Yep, tried that yesterday morning, just in case it was slightly different to the list on the advanved render settings in the render drop down tab. That was blank too. I think switching onto the 3D modelling ribbon has bump started it now though. It is now available on my dropdowns again! Yay! I think I should still bite the bullet and force myself to get to grips with the ribbon now. Thanks all. Quote Link to comment Share on other sites More sharing options...
Raudel Solis Posted June 29, 2011 Share Posted June 29, 2011 oh man the ribbon was awesome!, i had worked at times with previous versions of autocad with the classic setup and i abandoned it because i could never find anything since i was new to autocad... later when the 2010 release arrived i became really enthusiastic about autocad and its new ribbon. at first it was difficult but it became very simple within 2 weeks. Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 29, 2011 Share Posted June 29, 2011 The Ribbon is anathema to most old time users of AutoCAD. I think it helps to be young and have no prior experience with earlier (non-Ribbon) versions of AutoCAD. Quote Link to comment Share on other sites More sharing options...
Guinnessman Posted June 30, 2011 Author Share Posted June 30, 2011 Agreed ReMark. But I'm sure it's only a matter of time until Autocad bring out a new release in which you cannot use the classic set up. All development appears to be centred around the Ribbon, so I think maybe it's time I took the plunge. (Expect to see me on here a lot more over the next few days whining on about the good ol' days!) Quote Link to comment Share on other sites More sharing options...
Cad64 Posted June 30, 2011 Share Posted June 30, 2011 I'm sure it's only a matter of time until Autocad bring out a new release in which you cannot use the classic set up. I certainly hope that's not true. Quote Link to comment Share on other sites More sharing options...
Raudel Solis Posted June 30, 2011 Share Posted June 30, 2011 i think i can put in a " good ol' saying" "OUT WITH THE OLD, IN WITH THE NEW" Quote Link to comment Share on other sites More sharing options...
Cad64 Posted June 30, 2011 Share Posted June 30, 2011 As long as I can close the ribbon, that's fine with me. Quote Link to comment Share on other sites More sharing options...
Raudel Solis Posted June 30, 2011 Share Posted June 30, 2011 As long as I can close the ribbon, that's fine with me. i dont think i can possibly live without the ribbon Quote Link to comment Share on other sites More sharing options...
Guinnessman Posted July 1, 2011 Author Share Posted July 1, 2011 Hopefully they will stick with keeping all options available. Although the 3D Ribbon has more commands which are useful, I'm finding it a little restrictive when I need to do something else within a 3D environment. For example, needing to take a quick measurement. There is no facility on that particular ribbon, so you have search the other ribbons to find it. (I know I can type the command entry MEASUREGEOM as well, but that's not the point) Each to their own I guess. And I'm not that old! Quote Link to comment Share on other sites More sharing options...
