How to put numbers on points ?
termal007
thanks but i don't want doing click by click in 1530 points !! is very Time-consuming
are u doing simple by one click ?
One click.....1530 points? That's asking a lot don't you think?
How would the program know which point is the first? Which one should be the last? Should it number the points starting at the top and working towards the bottom or start on the left and number to the right? What's the order? What's the sequence?
Yes I think so too . :lol:
Termal try this routine .
(defun c:Pnum (/ i s h)
 (if (and (setq i 0
                s (ssget '((0 . "POINT")))
          (setq h (getdist "\n Specify height of text :"))
   ((lambda (x / n e)
      (while (setq n (ssname s (setq x (1+ x))))
        (setq e (entget n))
        (entmakex (list '(0 . "TEXT")
                        (assoc 10 e)
                        (cons 11 (cdr (assoc 10 e)))
                        (assoc 8 e)
                        (cons 7 (getvar 'TEXTSTYLE))
                        (cons 40 h)
                        (cons 1 (itoa (setq i (1+ i))))
     -1
it is not important which of point in first or end !!!
each point is one number so not needs i think which one was first !!
please see attach file . this attach is part of total points coordinate of alignment .
how i doing easy put numbers on points ?
point.dwg
Calm down dude. Since you did not make that point clear in your initial post someone had to ask. That someone happened to be me. Next time be more specific about your criteria.
Edited by ReMark
Have you tried Tharwat's code?!?
Works fine for your purposes, but in dwg posted all points are duplicated.
(if (and (setq i 0
((lambda (x / n e)
(setq e (entget n))
(assoc 10 e)
(assoc 8 e)
(cons 40 h)
-1
@Tharwat the lisp program works (almost perfect) however it puts two consecutive numbers on each point instead of ONE.
Just a little bug somewhere.
Steve
Steve
As GP_ stated the drawing contains duplicated points ;)
(if (and (setq i 0
((lambda (x / n e)
(setq e (entget n))
(assoc 10 e)
(assoc 8 e)
(cons 40 h)
-1
@tharwat, oh oh, my bad, the original OP drawing somehow on my system has double points at each location. I will try to fix at my end.... I think your program is OK and not in error !!
Steve
  • 10 years later...
 (if (and (setq i 0
   ((lambda (x / n e)
        (setq e (entget n))
                        (assoc 10 e)
                        (assoc 8 e)
                        (cons 40 h)
     -1
Hi Tharwat,
Can this lisp be modified to ask for the start number and to add a suffix to layer as -RPS
Quick and dirty :
 (if (and (setq i (1- (getint "\nStarting number : ")))
          (setq s (ssget '((0 . "POINT"))))
          (setq h (getdist "\nSpecify height of text : "))
   ((lambda (x / n e)
        (setq e (entget n))
                        (assoc 10 e)
                        (cons 8 (strcat (cdr (assoc 8 e)) "-RPS"))
                        (cons 40 h)
     -1
Edited by marko_ribar
Just now, marko_ribar said:
Quick and dirty :
   ((lambda (x / n e)
        (setq e (entget n))
                        (assoc 10 e)
                        (cons 40 h)
     -1
IAM GETTING THIS ERROR
It was closing bracket here :
I've updated the code...
Sorry, I overlooked those initial (setq's...
Thanks for the Update, 1 last request is to assign the color to the new layer (i.e. -RPS) same as the Original layer .
ex. points which by default has color 1 so points-rps also should have color red. If possible.
Thanks again.
Just pick color for your POINTS-RPS Layer and newely created points will inherit that layer as the one with the same color if you add line : (cons 62 (getvar 'cecolor)) at the end under line (cons 1 (itoa (setq i (1+ i))))... But untested if you give RGB color to Layer, you don't even need (cons 62 ...
I just don't know what boders you with colors issue... It should work well as 'cecolor is only variable responsible for newly appended entities to database...
Thanks for all your support But I am getting error.
