  2. @marko_ribar The 3d is a nice addition, but the general case is 2d in the context of graph. Your suggestion for the filter is indeed more robust. ymg
  3. I agree with ymg and thanks for improvement ab Dictionary... Nevertheless, IMHO the general case is to perform A* with 3D entities, so 3D polyline is my preferable result... You can explode polylines, select LINES in 2D, or 3D and perform A*; with my version you'll get 3D POLYLINE, after which you can just COPYBASE it with 0,0,0 base and put it into clipboard... Then, do several UNDO until before you exploded anything... Finally, you PASTECLIP with 0,0,0 from clipboard and if network was 3D, then 3D POLYLINE should be just fine, and if network was 2D, you explode 3D POLYLINE into LINE segments, and just do JOIN command on Previous selection - you'll get LWPOLYLINE to which you should just manually adjust lineweight... That's all, simple and unexaustive procedure... BTW., your filter '(0 . "*LINE") in acquirying selection sspl also involves SPLINE entities, for which A* isn't adequate... Perhaps, you should do it with '(0 . "LINE,LWPOLYLINE,POLYLINE") as proper filter... Little robust, but appropriate...
  4. @GLAVCVS Now you know why I had two different selection set for lines and polylines. ymg
  5. Today
  6. It's an honor to know you find it useful. I have some of your excellent code and use it often ("c:TIN", for example) because, quite simply, no one has done anything better yet.
  7. I think I understand the problem now. But it only happens with lines. With polylines, whether 3D or not, this doesn't happen. The issue is that "getPointAtParam" doesn't work the same way with lines as it does with polylines. If param=1, it doesn't return the expected result. I've modified the code to fix this (I think) ;; Pathfinding with the A* algorithm by ymg 22/07/2024 ; ;; ; ;; Revised a prog by HELMUT SCHRÖDER - heschr@gmx.de - 2014-09-14 ; ;; found at Cadtutor.net ; ;; ; ;; Kept the same format for edges list but added lines as valid choice ; ;; Format: (((x1 y1) (x2 y2)) (((x2 y2) (x3 y3))....(xn yn))) ; ;; ; ;; The user is asked to pick a start and an endpoint. ; ;; The program will find the shortest path in a network of connected ; ;; polylines and/or lines and draw a new polyline representing the result. ; ;; ; ;; Two lists of nodes openlst and closelst are created from the above ; ;; mentionned edges list. The format of a node list is: ; ;; (((Point) (Prev Point) Cumulated_Distance Estimated_Total_Distance)...) ; ;; ; ;; Main change from origina are: ; ;; - cons the list instead of append ; ;; - vl-sort the openlist instead of the quicksort ; ;; - Replaced and renamed some vars and subroutine. ; ;; - Added fuzz 1e-4 to all points comparison ; ;; - Change the get_path function ; ;; - Added line as possible edges ; ;; - Added an error handler ; ;; - Added a timer to the search portion of the program ; ;; ; ;; The above changes amounted to an acceleration of about 4x from the ; ;; original program. ; ;; : ;; If you compile this program to a .fas you'll get more than 10x faster. ; ;; ; ;| Added or revised code by GLAVCVS (january 2026) -All set are grouped into one -An associative sparse matrix cell->handles is created for faster cell querying (using new 'addToDict' and 'getCell' functions) -The "edges" list is replaced with the local search retourned by 'getCell' T E S T S ===== fas: 4-5 x faster than previous fas lsp: 7-8 x faster than previous lsp |; (defun c:A* (/ sspl i edges startp endp openlst closelst found acdoc Edgelay Pathlay Pathcol Pathlwt lstClvs ) (vl-load-com) ; Changes values of following 4 global variables to suit your need. ; (setq Edgelay "0" Pathlay "0" Pathcol 1 ; 1=Red 2=Yellow etc. ; Pathlwt 70 ; lineweight for path 0.7mm ; ) (or acdoc (setq acdoc (vla-get-activedocument (vlax-get-acad-object))) ) (set_errhandler '("CLAYER" "OSMODE" "CMDECHO")) (setvar 'CMDECHO 0) (setvar 'OSMODE 1) ;;; (if (setq ;;; ssp (ssget '"X" (list (cons 0 "LWPOLYLINE") (cons 8 Edgelay))) ;;; ) ;;; (foreach en (mapcar (function cadr) (ssnamex ssp)) ;;; (addToDict en) ;;; (setq edges (append edges (mk_edge (listpol2d en)))) ;;; ) ;;; nil ;;; ) ;;; ;;; (if (setq ssl (ssget '"X" (list (cons 0 "LINE") (cons 8 Edgelay)))) ;;; (foreach en (mapcar (function cadr) (ssnamex ssl)) ;;; (setq edges (cons (list (butlast (vlax-curve-getstartpoint en)) ;;; (butlast (vlax-curve-getendpoint en)) ;;; ) ;;; edges ;;; ) ;;; ) ;;; ) ;;; ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;ADDED by GLAVCVS (prompt "\rWait...\n") (vla-update (vlax-get-acad-object)) (if (setq sspl (ssget "X" (list '(0 . "*LINE") (cons 8 EdgeLay)))) (foreach en (mapcar (function cadr) (ssnamex sspl)) (addToDict en) ) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (setq startp (butlast (getpoint "\nPick Start Point: ")) ; Startpoint - reduced to 2D ; endp (butlast (getpoint "\nPick End Point: ")) ; Endpoint - reduced to 2D ; openlst (list (list startp '(0 0) 0.0 (distance startp endp))) ; Add starting node to openlst ; ) (vla-startundomark acdoc) (setq ti (getvar 'MILLISECS)) (while (and openlst (not found)) (setq node (car openlst)) (if (equal (car node) endp 1e-4) (setq found T closelst (cons node closelst) ) (setq closelst (cons node closelst) openlst (upd_openlst edges node endp (cdr openlst) closelst) ) ) ) (if found (mk_lwp (get_path closelst)) (alert "No path was found") ) (princ (strcat "\nExecution time:" (itoa (- (getvar 'MILLISECS) ti)) " milliseconds." ) ) (*error* nil) (princ) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;ADDED by GLAVCVS ;;;Create dictionary (defun addToDict (en / p1 p2 id clv i l c a) (setq i -1 id (cdr (assoc 5 (setq l (entget en)))) c (= (cdr (assoc 0 l)) "LINE") a 10) (while (setq p (if (and (setq i (1+ i)) c) (cdr (assoc (+ a i) l)) (vlax-curve-getPointAtParam en i))) (if (setq val (assoc (setq clv (strcat (itoa (fix (car p))) "-" (itoa (fix (cadr p))))) lstClvs)) (setq lstClvs (subst (append val (list (cons id i))) val lstClvs)) (setq lstClvs (cons (list clv (cons id i)) lstClvs)) ) ) ) ;;;return list cell (defun getCell (pt / clv v lr id p p0 pr par l c oc) (defun oc (c e i) (if c (cdr (assoc (+ i 10) l)) (vlax-curve-getPointAtParam e i))) (if (setq val (assoc (setq clv (strcat (itoa (fix (car pt))) "-" (itoa (fix (cadr pt))))) lstClvs)) (foreach par (cdr val) (setq e (handent (car par)) c (= (cdr (assoc 0 (setq l (entget e)))) "LINE")) (if (zerop (setq pr (cdr par))) (setq lr (cons (list (butlast (oc c e pr)) (butlast (oc c e (1+ pr)))) lr)) (setq lr (cons (list (butlast (oc c e (1- pr))) (setq p0 (butlast (oc c e pr)))) lr) lr (if (setq p (oc c e (1+ pr))) (cons (list p0 (butlast p)) lr) lr) ) ) ) ) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; ; ;; upd_openlst ; ;; ; ;; Each node of the openlst is passed to this sub and we scan the edges list ; ;; to find the corresponding edges. Then both points of the edges are tested ; ;; for equality to the nodes. The fixed cost (distance) is updated and so is ; ;; the estimated total distance. Updates are first put in a temporary node. ; ;; ; ;; We then proceed to test if the temp variable is already in the closelst ; ;; and proceed to the next edge. ; ;; ; ;; If temp is true and temp is not in closelst we go to the recursive sub ; ;; in_openlst which adjust the values and return the updated openlst : ;; ; ;; Upon return we sort the openlst on smallest estimated distance ; ;; and return the openlst to the main routine ; ;; ; (defun upd_openlst (edges node endp openlst closelst / lEdges edge pt fcost p1 p2 d temp) (setq pt (car node) fcost (caddr node) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;added By GLAVCVS (setq lEdges (getCell pt)) (foreach edge lEdges (setq p1 (car edge) p2 (cadr edge) d (distance p1 p2) temp nil ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;; (while edges ;;; (setq p1 (caar edges) ;;; p2 (cadar edges) ;;; edges (cdr edges) ;;; d (distance p1 p2) ;;; temp nil ;;; ) ;Testing both points of an edge and building a temporary node ; (cond ((equal pt p1 1e-4) (setq temp (list p2 p1 (+ fcost d) (+ fcost d (distance p2 endp)))) ) ((equal pt p2 1e-4) (setq temp (list p1 p2 (+ fcost d) (+ fcost d (distance p1 endp))) ) ) ) (if (and temp (not (memberfuzz (car temp) closelst))) (setq openlst (in_openlst temp openlst)) ) ) ; Keep openlist sorted on smallest Estimated Total Cost ; (vl-sort openlst (function (lambda (a b) (< (cadddr a) (cadddr b)))) ) ) ;in_lst Replaced by memberfuzz ; ;(defun in_lst (pt lst) ; (cond ; ((not lst) nil) ; ((equal pt (caar lst) 1e-4) lst) ; (T (in_lst pt (cdr lst))) ; ) ;) ; returns a new openlst with a double exchanged if cost is lower ; ;; ; (defun in_openlst (node lst) (cond ((not lst) (list node)) ((equal (car node) (caar lst) 1e-4) (if (< (cadddr node) (cadddr (car lst))) (cons node (cdr lst)) lst ) ) (T (cons (car lst) (in_openlst node (cdr lst)))) ) ) (defun in_openlst2 (node lst / s c) (setq s (splitat (caar node) lst) c (cadddr node) ) (cond ((not lst) (list node)) ((not (car s)) (cons node (cadr s))) ((not (cadr s)) (cons node (car s))) (T (if (< (cadddr node) (cadddr (cadr s))) (append (car s) (cons node (cdr s))) lst ) ) ;(T (c ns node lst)) ) ) ;; ; ;; listpol2D by ymg (Simplified a Routine by Gile Chanteau ; ;; ; ;; Parameter: en, Entity Name or Object Name of Any Type of Polyline ; ;; ; ;; Returns: List of Points in 2D WCS ; ;; ; ;; Notes: Requires butlast function for 2d points. ; ;; ; (defun listpol2d (en / i lst) (repeat (setq i (fix (1+ (vlax-curve-getEndParam en)))) (setq lst (cons (butlast (vlax-curve-getPointAtParam en (setq i (1- i)))) lst ) ) ) ) ;; ; ;; mk_edge ; ;; ; ;; From a list of consecutives points as supplied by listpol2D, ; ;; Returns a list of edges (((x1 y1)(x2 y2)) ((x2 y2)(x3 y3))...) ; ;; ; (defun mk_edge (lst) (mapcar (function (lambda (a b) (list a b))) lst (cdr lst)) ) ;; ; ;; butlast ; ;; ; ;; Returns a list without the last item ; ;; Used here mainly to change points to 2D ; ;; ; (defun butlast (lst) (reverse (cdr (reverse lst)))) ;; ; ;; get_path ; ;; ; ;; Returns The list of points of shortest path found from closelst. ; ;; ; (defun get_path (lst / path) (setq path (list (caar lst)) prev (cadar lst) lst (cdr lst) ) (while (setq lst (memberfuzz prev lst)) (setq prev (cadar lst) path (cons (caar lst) path) ) ) path ) ;; ; ;; memberfuzz by Gile Chanteau ; ;; ; ;; Modified to work with nodes list ; ;; ; (defun memberfuzz (p lst) (while (and lst (not (equal p (caar lst) 1e-4))) (setq lst (cdr lst)) ) lst ) (defun splitat (p lst / tr) (while (and lst (not (equal p (caar lst) 1e-4))) (setq tr (cons (car lst) tr) lst (cdr lst) ) ) (list (reverse tr) lst) ) (defun truncfuzz (p lst) (if (and lst (not (equal p (caar lst) 1e-4))) (cons (car lst) (truncfuzz p (cdr lst))) ) ) (defun posfuzz (p lst) (- (length lst) (length (memberfuzz p lst))) ) (defun rotleft (lst) (append (cdr lst) (list (car lst)))) (defun rotright (lst) (cons (last lst) (butlast lst))) ;; ; ;; mk_lwp ; ;; ; ;; Draw an lwpolyline given a point list ; ;; ; ;; Will be drawn on layer with color and lineweight defined by Variables ; ;; at beginnung of program. ; ;; ; (defun mk_lwp (pl) (entmakex (append (list (cons 0 "LWPOLYLINE") (cons 100 "AcDbEntity") (cons 100 "AcDbPolyline") (cons 8 Pathlay) (cons 62 Pathcol) (cons 90 (length pl)) (cons 70 0) (cons 370 Pathlwt) ) (mapcar (function (lambda (a) (cons 10 a))) pl) ) ) ) ;; Error Handler by Elpanov Evgenyi ; (defun set_errhandler (l) (setq varl (mapcar (function (lambda (a) (list 'setvar a (getvar a)))) l ) ) ) (defun *error* (msg) (mapcar 'eval varl) (if (and msg (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*")) ) (princ (strcat "\nError: " msg)) ) (vla-endundomark acdoc) (princ) )
  8. Marko, the point about @GLAVCVS is the use of a dictionnary to accelerate access to the edges and it is brilliant. As for 3D we all know that it can be extended to it. Dictionnaries in this context acts just like a hash table and is technique that I had overlooked for far too long and on which I am currently exploring further. Once again Thanks @GLAVCVS
  9. I'll attach *.DWG on which I tested path finding... Network was generated from Polygon Mesh... Mesh was exploded into 3DFACE entities and then those 3DFACEs extracted LINEs in 3D... Along with *.DWG, I'll post short *.lsp for extracting LINEs from 3DFACEs... (defun c:3dfs2lins ( / ch ss i 3df x p1 p2 p3 p4 lil ) (initget "Yes No") (setq ch (getkword "\nDo you want to keep 3DFACE(s) (No - deletion), or remove (Yes - deletion) [Yes/No] <Yes> : ")) (if (not ch) (setq ch "Yes") ) (prompt "\nSelect 3DFACE(s) on unlocked Layer(s) to extract lines from reference edges...") (if (setq ss (ssget "_:L" (list (cons 0 "3DFACE")))) (repeat (setq i (sslength ss)) (setq 3df (ssname ss (setq i (1- i)))) (setq p1 (cdr (assoc 10 (setq x (entget 3df))))) (setq p2 (cdr (assoc 11 x))) (setq p3 (cdr (assoc 12 x))) (setq p4 (cdr (assoc 13 x))) (if (not (vl-some (function (lambda ( x ) (or (equal (list p1 p2) x 1e-6) (equal (list p2 p1) x 1e-6)))) lil)) (progn (entmake (list (cons 0 "LINE") (cons 10 p1) (cons 11 p2))) (setq lil (cons (list p1 p2) lil)) ) ) (if (not (vl-some (function (lambda ( x ) (or (equal (list p2 p3) x 1e-6) (equal (list p3 p2) x 1e-6)))) lil)) (progn (entmake (list (cons 0 "LINE") (cons 10 p2) (cons 11 p3))) (setq lil (cons (list p2 p3) lil)) ) ) (if (not (vl-some (function (lambda ( x ) (or (equal (list p3 p4) x 1e-6) (equal (list p4 p3) x 1e-6)))) lil)) (progn (entmake (list (cons 0 "LINE") (cons 10 p3) (cons 11 p4))) (setq lil (cons (list p3 p4) lil)) ) ) (if (not (vl-some (function (lambda ( x ) (or (equal (list p4 p1) x 1e-6) (equal (list p1 p4) x 1e-6)))) lil)) (progn (entmake (list (cons 0 "LINE") (cons 10 p4) (cons 11 p1))) (setq lil (cons (list p4 p1) lil)) ) ) (if (= ch "Yes") (entdel 3df) ) ) ) (princ) ) A-star.dwg
  10. SLW210
    Drawing Name to Layout Tab
    I'm sure these can be improved, I'll check more into things when I have more time. As is, hopefully they are useful to others. Many of our drawings follow the standard M-XX-001 for Mechanical, G-XX-001 for General, E-XX-001 for Electrical, etc. occasionally we have just drawings with descriptive names, so having the -1, -2, etc. works, if I have M-10-001 and several sheets, so M-10-001-1, -2, etc. works. usually my G-10-001, drawing would have tabs, G-10-001, G-10-002, and so on in order, so I need some options depending. Now you have me thinking on something.
  11. How can I convert the text size for insertion to the number x by 0.001, that is, if the size is 4250, then we get 4.250 when inserting? Thanks!
  12. There are several posted images of Plate 2 for this particular project available for viewing in related threads. Have you checked any of them out? What, specifically, seems to be the problem?
  13. ReMark
    If you do a search of this forum using the phrase "Penn Foster structural" you will find several threads containing information (text & images) pertaining to this project.
  14. Are you the only that works on these drawings?
  15. I’m not aware of all the possible situations. I was thinking of a scenario like the one shown in the drawings attached so far. But are you sure the modifications you’re suggesting are really necessary? If you attach a drawing showing the situation you’re referring to, I’ll understand it better. In any case, considering 3D linear objects has some interesting implications, because it introduces an additional variable into the cost (the elevation difference) … What if we want to add more variables to the cost of each segment? Encoding them through some property like color, thickness, etc.? And replacing the function "distance" as the central cost estimator with another one ("valuate", for example) that also weighs additional variables?
  16. (defun c:mahi (/ pt p1 p2) (setq p1 (getpoint)) ; point from the file (while (setq p2 (getpoint)) ; point from the file ;;;; code point extration from txt or excel (command "line" p1 p2 "") (setq p1 p2) ) (princ) ) Extract a point from the txt file, then draw a line in AutoCAD point.txt
  17. @ronjonp It's a great code! The program performs permission to explode for all blocks of the same name. Is it possible to perform permission to explode only for one (2, 3...) the selected block? Is it possible to leave the other blocks of the same name unchanged? Allow permission to explode for one of the block occurrences.
  18. Hi... I've seen @GLAVCVS code and found that it had some lacks... I've debugged it and make it work for lines and path in 3d... Path is now 3D POLYLINE and selection of network edges are lines in 3D... I've shortened complete code and left only necessary subs and comments... So, this is my revision and I hope it could also be beneficial... ;; Pathfinding with the A* algorithm by ymg 22/07/2024 ; ;; ; ;; Revised a prog by HELMUT SCHRÖDER - heschr@gmx.de - 2014-09-14 ; ;; found at Cadtutor.net ; ;; ; ;; Kept the same format for edges list but added lines as valid choice ; ;; Format: (((x1 y1 z1) (x2 y2 z2)) ((x2 y2 z2) (x3 y3 z3))....(xn yn zn))) ; ;; ; ;; The user is asked to pick a start and an endpoint. ; ;; The program will find the shortest path in a network of connected ; ;; lines and draw a new 3dpolyline representing the result. ; ;; ; ;; Two lists of nodes openlst and closelst are created from the above ; ;; mentionned edges list. The format of a node list is: ; ;; (((Point) (Prev Point) Cumulated_Distance Estimated_Total_Distance)...) ; ;; ; ;; Main change from origina are: ; ;; - cons the list instead of append ; ;; - vl-sort the openlist instead of the quicksort ; ;; - Replaced and renamed some vars and subroutine. ; ;; - Added fuzz 1e-4 to all points comparison ; ;; - Change the get_path function ; ;; - Added line as possible edges ; ;; - Added an error handler ; ;; - Added a timer to the search portion of the program ; ;; ; ;; The above changes amounted to an acceleration of about 4x from the ; ;; original program. ; ;; : ;; If you compile this program to a .fas you'll get more than 10x faster. ; ;; ; ;| Added or modified code by GLAVCVS (january 2026) -All set are grouped into one -An associative sparse matrix cell->handles is created for faster cell querying (using new 'addToDict' and 'getCell' functions) -The "edges" list is replaced with the local search retourned by 'getCell' T E S T S ===== fas: 4-5 x faster than previous fas lsp: 7-8 x faster than previous lsp |; (defun c:A* (/ *error* addToDict getCell upd_openlst in_openlst get_path memberfuzz mk_3dpl set_errhandler ssl i startp endp 3dpl openlst closelst found acdoc lstClvs Pathlay Pathcol Pathlwt varl node ti ) (or (not (vl-catch-all-error-p (vl-catch-all-apply (function vlax-get-acad-object) nil))) (vl-load-com)) (defun *error* (msg) (if 3dpl (if command-s (command-s "_.draworder" 3dpl "" "_f") (vl-cmdf "_.draworder" 3dpl "" "_f") ) ) (mapcar (function eval) varl) (if (and msg (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*"))) (princ (strcat "\nError: " msg)) ) (vla-endundomark acdoc) (princ) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;ADDED by GLAVCVS ;;;Create dictionary (defun addToDict (en / i id p val clv) (setq i -1 id (cdr (assoc 5 (entget en)))) (while (and (/= (setq i (1+ i)) 2) (if (= i 0) (setq p (vlax-curve-getStartPoint en)) (setq p (vlax-curve-getEndPoint en)))) (if (setq val (assoc (setq clv (strcat (rtos (car p) 2 4) "-" (rtos (cadr p) 2 4) "-" (rtos (caddr p) 2 4))) lstClvs)) (setq lstClvs (subst (append val (list (cons id i))) val lstClvs)) (setq lstClvs (cons (list clv (cons id i)) lstClvs)) ) ) ) ;;;return list cell ;;*** Modified to access the new dictionary format *** (defun getCell (pt / val clv par e lr) (if (setq val (assoc (setq clv (strcat (rtos (car pt) 2 4) "-" (rtos (cadr pt) 2 4) "-" (rtos (caddr pt) 2 4))) lstClvs)) (foreach par (cdr val) (setq e (handent (car par))) (setq lr (cons (list (vlax-curve-getStartPoint e) (vlax-curve-getEndPoint e)) lr)) ) ) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; ; ;; upd_openlst ; ;; ; ;; Each node of the openlst is passed to this sub and we scan the edges list ; ;; to find the corresponding edges. Then both points of the edges are tested ; ;; for equality to the nodes. The fixed cost (distance) is updated and so is ; ;; the estimated total distance. Updates are first put in a temporary node. ; ;; ; ;; We then proceed to test if the temp variable is already in the closelst ; ;; and proceed to the next edge. ; ;; ; ;; If temp is true and temp is not in closelst we go to the recursive sub ; ;; in_openlst which adjust the values and return the updated openlst ; ;; ; ;; Upon return we sort the openlst on smallest estimated distance ; ;; and return the openlst to the main routine ; ;; ; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (defun upd_openlst (node endp openlst closelst / lEdges pt fcost p1 p2 d temp) (setq pt (car node) fcost (caddr node) ) (setq lEdges (getCell pt)) (foreach edge lEdges (setq p1 (car edge) p2 (cadr edge) d (distance p1 p2) temp nil ) (cond ((equal pt p1 1e-4) (setq temp (list p2 p1 (+ fcost d) (+ fcost d (distance p2 endp)))) ) ((equal pt p2 1e-4) (setq temp (list p1 p2 (+ fcost d) (+ fcost d (distance p1 endp)))) ) ) (if (and temp (not (memberfuzz (car temp) closelst))) (setq openlst (in_openlst temp openlst)) ) ) (vl-sort openlst (function (lambda (a b) (< (cadddr a) (cadddr b))))) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (defun in_openlst (node lst) (cond ((not lst) (list node)) ((equal (car node) (caar lst) 1e-4) (if (< (cadddr node) (cadddr (car lst))) (cons node (cdr lst)) lst ) ) (t (cons (car lst) (in_openlst node (cdr lst)))) ) ) ;; ; ;; get_path ; ;; ; ;; Returns The list of points of shortest path found from closelst. ; ;; ; (defun get_path (lst / path) (setq path (list (caar lst)) prev (cadar lst) lst (cdr lst) ) (while (setq lst (memberfuzz prev lst)) (setq prev (cadar lst) path (cons (caar lst) path) ) ) path ) ;; ; ;; memberfuzz by Gile Chanteau ; ;; ; ;; Modified to work with nodes list ; ;; ; (defun memberfuzz (p lst) (while (and lst (not (equal p (caar lst) 1e-4))) (setq lst (cdr lst)) ) lst ) ;; ; ;; mk_3dpl ; ;; ; ;; Draw an 3dpolyline given a point list ; ;; ; ;; Will be drawn on layer, lineweight and color defined by Variables ; ;; at beginnung of program. ; ;; ; (defun mk_3dpl (pl / 3dpl) (setq 3dpl (entmakex (list (cons 0 "POLYLINE") (cons 100 "AcDbEntity") (cons 8 Pathlay) (cons 370 Pathlwt) (cons 100 "AcDb3dPolyline") (cons 66 1) (list 10 0.0 0.0 0.0) (cons 70 8) (cons 40 0.0) (cons 41 0.0) (list 210 0.0 0.0 1.0) (cons 71 0) (cons 72 0) (cons 73 0) (cons 74 0) (cons 75 0) (cons 62 Pathcol) ) ) ) (foreach p pl (entmake (list (cons 0 "VERTEX") (cons 100 "AcDbEntity") (cons 8 Pathlay) (cons 100 "AcDbVertex") (cons 100 "AcDb3dPolylineVertex") (cons 10 p) (cons 40 0.0) (cons 41 0.0) (cons 42 0.0) (cons 70 32) (cons 50 0.0) (cons 71 0) (cons 72 0) (cons 73 0) (cons 74 0) ) ) ) (entmake (list (cons 0 "SEQEND") (cons 100 "AcDbEntity") (cons 8 Pathlay) (cons -2 3dpl) ) ) 3dpl ) ;; Error Handler by Elpanov Evgenyi ; (defun set_errhandler (l) (setq varl (mapcar (function (lambda (a) (list (quote setvar) a (getvar a)))) l)) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; MAIN ROUTINE ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ; Change values of following 3 variables to suit your need. ; (setq Pathlay "0" Pathcol 3 ; 1=Red 2=Yellow 3=Green etc. ; Pathlwt 30 ; lineweight for path 0.3 mm ; ) (or acdoc (setq acdoc (vla-get-activedocument (vlax-get-acad-object)))) (set_errhandler (list "clayer" "osmode" "cmdecho")) (setvar (quote cmdecho) 0) (setvar (quote osmode) 1) (setvar (quote lwdisplay) 1) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (prompt "\nSelect LINE network entities...") (if (setq ssl (ssget (list (cons 0 "LINE")))) (foreach en (vl-remove-if (function listp) (mapcar (function cadr) (ssnamex ssl))) (addToDict en) ) ) (initget 1) (setq startp (getpoint "\nPick or specify Start Point : ")) (initget 1) (setq endp (getpoint "\nPick or specify End Point : ")) (setq openlst (list (list startp (list 0.0 0.0 0.0) 0.0 (distance startp endp)))) (vla-startundomark acdoc) (setq ti (getvar (quote millisecs))) (while (and openlst (not found)) (setq node (car openlst)) (if (equal (car node) endp 1e-4) (setq found t closelst (cons node closelst)) (setq closelst (cons node closelst) openlst (upd_openlst node endp (cdr openlst) closelst)) ) ) (if found (setq 3dpl (mk_3dpl (get_path closelst))) (alert "No path was finded...") ) (princ (strcat "\nExecution time : " (itoa (- (getvar (quote millisecs)) ti)) " milliseconds...")) (*error* nil) ) HTH. Regards, M.R.
  19. CADLEARNER1234
    hello, I am looking for help on plate 2 so if you happen to have already completed it, or have any visuals, it would be greatly appreciated
  20. Hello, I am currently struggling through this project, I managed to get through sheet 1 but i need help with sheet 2, as the instructions given by Penn Foster are useless, difficult to understand, frankly I feel like the quality of the program has failed to match the cost. I'll upload a picture to show where I am at in the project thusfar. I am in sheet 2 and this is what I have thus far
  21. BIGAL
    Another been using for years, pads dwg number. We named our layouts as D01, D02 etc. ; if less than 10 (if (< dwgnum 10.0) (setq newstr2 (strcat dwgname "-D0" (rtos dwgnum 2 0))) (setq newstr2 (strcat dwgname "-D" (rtos dwgnum 2 0))) ) ; can add more "0" to get "001" etc. use a cond. (cond ((< dwgnum 10) (setq newstr2 (strcat dwgname "-D00" (rtos dwgnum 2 0)))) ((< dwgnum 100) (setq newstr2 (strcat dwgname "-D0" (rtos dwgnum 2 0)))) ((>= dwgnum 100)(setq newstr2 (strcat dwgname "-D" (rtos dwgnum 2 0)))) ) Maybe a bit shorter than the Vl string trim.
  22. Yesterday
  23. BIGAL
    Smart offset lisp
    Thanks @Nikon for the improvements to the code. Have saved the new version.
  24. No, id don't use any of those. Many thanks.
  25. Verticals are Civil 3D, AutoCAD Map 3D, AutoCAD Mechanical, AutoCAD Architectural, etc. I'm busy at work start to finish these days, if I get time I'll see if I can discover the issue.
  26. I had these for a bit and figured I'd share. I was surprised I couldn't find anything to rename the layout tab automatically, I am probably the only person too lazy to type them in, if there are some LISPs out there I couldn't find them. They do what I need, but I am sure more options could be added and most likely improved so feel free to comment or ask, no guarantee I can get time to work on them in the near future. I am busy busy at work right now. I use the first and last one the most. I have them set for drag and drop, just comment or delete the (c:---------) at the bottom to not run on load. The first I had for a bit, I just drag and drop into a drawing with a single tab and the tab name is the drawing name. ;;; Layout tab with drawing name. (Works with only one layout tab) ;;; ;;; By SLW210 (a.k.a. Steve Wilson) ;;; (defun c:DwgNameLayTab () (setq dName (vl-filename-base (getvar "DWGNAME"))) (setq lout (vla-get-ActiveLayout (vla-get-ActiveDocument (vlax-get-acad-object)))) (vla-put-Name lout dName) ) (c:DwgNameLayTab) Another one I did, does same as above, but if more than one tab adds -1, -2, etc. ;;; Adds suffix to drawing name in layout tabs, if one tab dwgname only. ;;; ;;; By SLW210 (a.k.a. Steve Wilson) ;;; (defun c:LayoutNameFromDWG ( / dwgName layouts layCount addSuffix idx doc layObj) (vl-load-com) ;; Get drawing name without extension (setq dwgName (vl-filename-base (getvar "DWGNAME"))) ;; Get list of layouts excluding Model (setq layouts (vl-remove "Model" (layoutlist))) (setq layCount (length layouts)) ;; Determine suffix behavior (cond ;; Only one layout no suffix ((= layCount 1) (setq addSuffix nil) ) ;; More than one layout suffix REQUIRED ((> layCount 1) (setq addSuffix T) ) ) ;; Get active document (setq doc (vla-get-ActiveDocument (vlax-get-acad-object))) ;; Rename layouts (setq idx 1) (foreach lay layouts (setq layObj (vla-item (vla-get-Layouts doc) lay)) (vla-put-Name layObj (if addSuffix (strcat dwgName "-" (itoa idx)) dwgName ) ) (setq idx (1+ idx)) ) (princ "\nLayout tabs renamed successfully.") (princ) ) (c:LayoutNameFromDWG) This does the exact same as the LayoutNameFromDWG.lsp , I think I had lost it and rewrote it, I don't see any advantage in one over the other, maybe someone else can tell. ;;; Layout tab with drawing name adds suffix if more than one tab (-1, -2). ;;; ;;; By SLW210 (a.k.a. Steve Wilson) ;;; (defun c:DwgNameLayTab1 ( / dName doc layouts layCount idx lout) (vl-load-com) ;; Drawing name (no extension) (setq dName (vl-filename-base (getvar "DWGNAME"))) ;; Get document and layouts (setq doc (vla-get-ActiveDocument (vlax-get-acad-object))) (setq layouts (vl-remove "Model" (layoutlist))) (setq layCount (length layouts)) ;; Rename layouts (setq idx 1) (foreach lay layouts (setq lout (vla-item (vla-get-Layouts doc) lay)) (vla-put-Name lout (if (> layCount 1) (strcat dName "-" (itoa idx)) dName ) ) (setq idx (1+ idx)) ) (princ) ) (c:DwgNameLayTab1) This one does a bit more, first tab is the DwgName, if more than one tab it adds a suffix to the second, third, etc. but first tab is still DwgName only, if as is often my case the DwgName ends in a number like I often have M-10-001, it just adds 1 to each of the next tabs. Example, M-10-001,M-10-002, M-10-003, M-10-004, etc. ;;; Layout tab drawing name to first tab, more than one tab adds suffix after first tab (-1, -2), if ends in numbers adds 1 to number ;;; for example M-10-001,M-10-002, M-10-003, M-10-004. ;;; ;;; By SLW210 (a.k.a. Steve Wilson) ;;; (defun c:DwgNameLayTab2 ( / dName doc layouts idx lout baseName numStr startNum numLen pos) (vl-load-com) ;; Drawing name (no extension) (setq dName (vl-filename-base (getvar "DWGNAME"))) ;; Get layouts (exclude Model) (setq layouts (vl-remove "Model" (layoutlist))) ;; Extract trailing number (with padding) --- (setq pos (strlen dName)) (while (and (> pos 0) (<= 48 (ascii (substr dName pos 1)) 57)) (setq pos (1- pos)) ) (if (< pos (strlen dName)) (progn (setq baseName (substr dName 1 pos)) (setq numStr (substr dName (1+ pos))) (setq startNum (atoi numStr)) (setq numLen (strlen numStr)) ;; number of digits ) (setq baseName dName startNum 1 numLen 0) ) ;; Get document (setq doc (vla-get-ActiveDocument (vlax-get-acad-object))) ;; Rename layouts (setq idx 0) (foreach lay layouts (setq lout (vla-item (vla-get-Layouts doc) lay)) (vla-put-Name lout (cond ;; First layout: exact drawing name ((= idx 0) dName) ;; Subsequent layouts (T (if (> numLen 0) ;; DWG ends with number increment & pad (strcat baseName (vl-string-right-trim " " (strcat (substr "0000000000" 1 (- numLen (strlen (itoa (+ startNum idx))))) (itoa (+ startNum idx)) ) ) ) ;; No trailing number add -1, -2, ... (strcat dName "-" (itoa idx)) ) ) ) ) (setq idx (1+ idx)) ) (princ) ) (c:DwgNameLayTab2)
  27. Hi SLW210. No. I only use AutoCAD 2014. What is Verticals? It seems that there are too many tag-alongs in your drawings, even when they are visibly empty. Export to DXF? Thank you.
