  1. Today
  2. I've edited the code again, and it seems to have worked this time.
  3. VicoWang
    VedaCAD
    Version 1.1
    1 download
    Note: To install via VCID, you need to install VedaCAD in advance and log in to a free account (or PRO account). Tips: Welcome developers to publish their plugins on VedaCAD and obtain their plugin's VCID for plugin sharing (even free accounts can publish). The following methods can be used to test the installation and deployment of the VedaCAD plugin via the VCID test: [Quick Annotator] VCID: 7JAU18 @ VedaCAD [Codebase Packer] VCID: 0FBGZB @ VedaCAD [VAgent Demo] VCID: PLG96B @ VedaCAD [Gomoku CadCade] VCID: 1G8VY1 @ VedaCAD [Omni Wheel] VCID: US87Y8 @ VedaCAD [Side DIM] VCID: 5EDNWJ @ VedaCAD [Smart Break] VCID: D86938 @ VedaCAD [Wave Animator] VCID: 31E6TS @ VedaCAD
  4. Have you ever created a curved 3D model that looked smooth while working on it, but the edges appeared faceted or rough? The geometry may be correct. The display can be affected by the visual style and object smoothness settings. For curved solids, I first check the visual style and use SMOOTHMESHCONVERT or the appropriate smoothness tools when working with mesh-based geometry. For solid models, changing the display quality can also make a noticeable difference without changing the actual model. This is one of those cases where the model isn't necessarily wrong—the way it is displayed can make it look wrong. Have you ever mistaken a display issue for a modelling problem? What did you check first?
  5. cadprops
    How do I Open/View/Import .SLDPRT files?
    For anyone finding this older thread with the same problem: check the SLDPRT version first, and ask the sender for STEP or Parasolid if you need geometry that can be imported and edited in another CAD system. A viewer only confirms what is in the file; it does not restore the SolidWorks feature tree or drawing tolerances. I work on CADProps. Its browser SolidWorks viewer can inspect SLDPRT/SLDASM files, show converted geometry and bounding dimensions, and export STEP when the file parses: https://www.cadprops.com/tools/solidworks-viewer/ . The current guest limit is 10 MiB and files are temporarily processed server-side, so confidential models should only be uploaded if that workflow is acceptable.
  6. It seems that Cadtutor refused to accept my modification. Basically, I changed *TOUT* to *OUT* and '(if (findfile *PS-READY*)' to '(if (and *PS* (findfile *PS-READY*))'
  7. @GLAVCVS BTW: I didn't see any changes to your original code. For example I still see the lines using *PS-TOUT* I've tried it on a couple of Windows 10 Pro OS computers running AutoCAD 2021, 2023 & 2027 one at a time and not multiple sessions. Upon further testing the Select Files window can be unstuck by toggling to the Edge browser making that active and then toggling back to AutoCAD. The problem still occurs even when the Edge browser is not running. But as long as I launch the Edge browser (when it's not already running) then the Select Files window would free up to function as designed. This problem does not occur on the single Windows 11 OS computer I tested this on.
  8. You were right I forgot to clean *PS-TOUT* from my test code I've also tweaked something else in the code. Try it again
  9. Which version of AutoCAD are you using? Do you have multiple AutoCAD sessions open?
  10. @GLAVCVS Thanks for the modified code. But I'm encountering the following errors after attempting to load it: ; error: bad argument type: stringp nil The error is caused by the following lines of code under the PS-EXEC function: ;|Waiting for a Powershell response / Esperar a que PowerShell responda|; (while (not (findfile *PS-TOUT*));(not (findfile *PS-OUT*)) (setq t0 1000) (repeat 1000 (setq t0 (1+ t0))) ) ;|Reading response / Leer respuesta|; (setq fp (open *PS-TOUT* "r"));(open *PS-OUT* "r")) (while (setq lin (read-line fp)) (setq result (cons lin result)) ) (close fp) When I change the following lines of code referencing *PS-TOUT* to what you had commented out using *PS-OUT* then at least it'll load successfully: ;|Waiting for a Powershell response / Esperar a que PowerShell responda|; (while (not (findfile *PS-OUT*));(not (findfile *PS-OUT*)) (setq t0 1000) (repeat 1000 (setq t0 (1+ t0))) ) ;|Reading response / Leer respuesta|; (setq fp (open *PS-OUT* "r"));(open *PS-OUT* "r")) (while (setq lin (read-line fp)) (setq result (cons lin result)) ) (close fp) But after this when I call the pl:getfiledps function using the following line of code: (pl:getfiledps "Select Files" (getvar"dwgprefix") "dwg" 1) The Select Files window would appear on top of my AutoCAD session and then just hang there. I'm unable to select any files from this window or move the window out of the way: I would have to terminate the AutoCAD app from Task Manager But the Select Files window remains. Now the window is freed up for me to select files and drag the window around. Any thoughts as to why this is occurring on my end?
  11. Yesterday
  12. You can start a PowerShell instance from LISP and keep it running in the background, ready to receive instructions. I've played around with this idea a little and ended up with the following code. I haven't tested it thoroughly enough, so its robustness could probably be improved. But it may be useful. (defun PS-START (/ fp sh cmd n) (vl-load-com) ;| -------------------------------------------------------------- ; Si existe READY, suponemos de momento que ya está funcionando. ; Posteriormente podemos hacer PS-ALIVE más rigurosa. |; -------------------------------------------------------------- (setq *PS-SERVER* (strcat (getenv "TEMP") "\\PL_PS_Server.ps1") *PS-TCMD* (strcat (getenv "TEMP") "\\PL_PS_Command.tmp") *PS-CMD* (strcat (getenv "TEMP") "\\PL_PS_Command.txt") *PS-OUT* (strcat (getenv "TEMP") "\\PL_PS_Output.txt") *PS-READY* (strcat (getenv "TEMP") "\\PL_PS_Ready.txt") ) (if (and *PS* (findfile *PS-READY*)) T (progn ;|Clean previous files / Limpiar archivos anteriores|; (if (findfile *PS-CMD*) (vl-file-delete *PS-CMD*) ) (if (findfile *PS-OUT*) (vl-file-delete *PS-OUT*) ) ;|Create server script / Crear script servidor|; (setq fp (open *PS-SERVER* "w")) ;|Nombres de los archivos de comunicación|; (write-line "$cmd = $env:TEMP + '\\PL_PS_Command.txt'" fp) (write-line "$out = $env:TEMP + '\\PL_PS_Output.txt'" fp) (write-line "$ouTmp = $env:TEMP + '\\PL_PS_Output.tmp'" fp) (write-line "$ready = $env:TEMP + '\\PL_PS_Ready.txt'" fp) ;|Indicate Powershelll ready / Señalizar que PowerShell está preparado|; (write-line "Set-Content -Path $ready -Value $PID -Encoding Default" fp) ;|Main loop / Bucle principal Powershell remains here for entire session / PowerShell permanece aquí durante toda la sesión|; (write-line "while ($true) {" fp) ;|Is there any pending request? / ¿Hay una orden pendiente?|; (write-line " if (Test-Path $cmd) {" fp) ;|Read ALL code / Leer TODO el código. -Raw permite que PS-EXEC pueda mandar scripts de varias líneas, no solamente una instrucción |; (write-line " $code = Get-Content -Path $cmd -Raw -Encoding Default" fp) ;|Delete request inmediately / Borrar la petición inmediatamente. Esto indica que el servidor ya se ha hecho cargo de ella.|; (write-line " Remove-Item $cmd -Force" fp) ;|Orden para terminar el servidor|; (write-line " if ($code.Trim() -eq '__EXIT__') {" fp) (write-line " break" fp) (write-line " }" fp) ;|Execute code IN THIS POWERSHELL SESSION / Ejecutar código EN ESTA MISMA SESIÓN POWERSHELL|; (write-line " try {" fp) (write-line " $result = Invoke-Expression $code" fp) ;| OUT must always be created so that PS-EXEC knows the process has finished Hay que crear siempre OUT. Incluso si la expresión devuelve $null necesitamos crear el archivo para que PS-EXEC sepa que hemos terminado. |; (write-line " if ($null -eq $result) {" fp) (write-line " Set-Content -Path $ouTmp -Value '' -Encoding Default" fp) (write-line " }" fp) (write-line " else {" fp) (write-line " $result | Out-File -FilePath $ouTmp -Encoding Default" fp) (write-line " }" fp) (write-line " Move-Item $ouTmp $out -Force" fp);rename PL_PS_Output.tmp / renombramos PL_PS_Output.tmp ;|Capturar errores|; (write-line " }" fp) (write-line " catch {" fp) (write-line " ('__ERROR__ ' + $_.Exception.Message) | Out-File -FilePath $out -Encoding Default" fp) (write-line " }" fp) ; close / cerrar 'IF Test-Path' (write-line " }" fp) ;| Sleep / Demorar 10 ms. Prevents resident Powershell instance from continuously using a CPU core while it has nothing to do Evita que el PowerShell residente utilice continuamente un núcleo de CPU mientras no tiene nada que hacer |; (write-line " Start-Sleep -Milliseconds 10" fp) ; cerrar WHILE (write-line "}" fp) ;|PowerShell está terminando|; (write-line "Remove-Item $ready -Force -ErrorAction SilentlyContinue" fp) (close fp) ;|Arrancar PowerShell|; (if (not *PS*) (progn (setq cmd (strcat "powershell.exe " "-NoLogo " "-NoProfile " "-NonInteractive " "-STA " "-ExecutionPolicy Bypass " "-WindowStyle Hidden " "-File \"" *PS-SERVER* "\"" ) sh (vlax-create-object "WScript.Shell") ) (vlax-invoke-method sh 'Run cmd 0 :vlax-false) (vlax-release-object sh) ) ) ;| Esperar a que PowerShell cree READY Máximo: 5 segundos |; (setq n 0) (while (and (not (findfile *PS-READY*)) (< n 500) ) (repeat 10000 (getvar "MILLISECS")) (princ "\rEsperando...") (setq n (1+ n)) ) ;|Result / Resultado|; (if (findfile *PS-READY*) T nil ) ) ) ) (defun PS-EXEC (code / fp lin result t0) ;| Clears any previous result / Borrar posible resultado anterior|; (if (findfile *PS-OUT*) (vl-file-delete *PS-OUT*) ) ;| Write code that Powershell should executed / Escribir el código que debe ejecutar PowerShell|; (setq fp (open *PS-CMD* "w")) (write-line code fp) (close fp) ;|Waiting for a Powershell response / Esperar a que PowerShell responda|; (while (not (findfile *PS-OUT*));(not (findfile *PS-OUT*)) (setq t0 1000) (repeat 1000 (setq t0 (1+ t0))) ) ;|Reading response / Leer respuesta|; (setq fp (open *PS-OUT* "r"));(open *PS-OUT* "r")) (while (setq lin (read-line fp)) (setq result (cons lin result)) ) (close fp) ;| Delete result / Borrar resultado|; (vl-file-delete *PS-OUT*) (reverse result) ) (defun PL-FILEDIALOG-INIT (/ hwnd) ;; HWND de ESTA instancia concreta de AutoCAD (setq hwnd (vla-get-HWND (if (minusp (- (atoi (getvar "ACADVER")) 16)) (vla-get-activeDocument (vlax-get-acad-object)) (vlax-get-acad-object))) ) ;; Windows Forms + OpenFileDialog (PS-EXEC (strcat "Add-Type -AssemblyName System.Windows.Forms;" "$script:f=New-Object System.Windows.Forms.OpenFileDialog" ) ) ;|Small 'wrapper' to convert AutoCAD's HWND into a valid 'IWin32Window' for ShowDialog(owner) Pequeño 'wrapper' para convertir el HWND de AutoCAD en un 'IWin32Window' válido para 'ShowDialog (owner)' |; (PS-EXEC (strcat "Add-Type -TypeDefinition " "'using System;" "using System.Windows.Forms;" "public class WindowWrapper:IWin32Window{" "private IntPtr h;" "public WindowWrapper(IntPtr hwnd){h=hwnd;}" "public IntPtr Handle{get{return h;}}" "}' " "-ReferencedAssemblies System.Windows.Forms" ) ) ;|Locate AutoCAD and create owner Localizar AutoCAD y crear el 'owner' |; (PS-EXEC (strcat "$script:owner=New-Object WindowWrapper(" (itoa hwnd) ")" ) ) T ) (defun pl:getfiledps (title dir ext flg / psquote makefilter code) ;| Escape / Escapar ' PowerShell|; (defun psquote (s / p n) (setq n 0) (while (setq p (vl-string-search "'" s n)) (setq s (strcat (substr s 1 p) "''" (substr s (+ p 2))) n (+ p 2) ) ) s ) (defun makefilter (s / p r x) (setq r "") (while (setq p (vl-string-search ";" s)) (setq x (substr s 1 p) r (strcat r "*." x ";") s (substr s (+ p 2)) ) ) (strcat r "*." s) ) ;|Default values / Valores por defecto|; (if (/= (type title) 'STR) (setq title "Select Files") ) (if (not (and (= (type dir) 'STR) (vl-file-directory-p dir) ) ) (setq dir (getvar "DWGPREFIX")) ) (if (= (type ext) 'STR) (setq ext (makefilter ext)) (setq ext "*.dwg") ) ;| Build only the code needed for this call: Powershell, Forms, f and owner ALREADY EXISTS Construir únicamente el código necesario para ESTA llamada: PowerShell, Forms, f y owner YA EXISTEN |; (setq code (strcat "$script:f.FileName='';" "$script:f.Title='" (psquote title) "';" "$script:f.InitialDirectory='" (psquote dir) "';" "$script:f.Filter='Files (" ext ")|" ext "';" "$script:f.Multiselect=" (if (and (= (type flg) 'INT) (/= flg 0) ) "$true;" "$false;" ) "$r=$script:f.ShowDialog($script:owner);" "if($r -eq " "[System.Windows.Forms.DialogResult]::OK)" "{$script:f.FileNames}" ) ) ;| Execute in the resident Powershell instance / Ejecutar en PowerShell residente |; (PS-EXEC code) ) ;|If Powershell is not already running, start a instance / SI POWERSHELL NO ESTÁ INSTANCIADO, SE CREA UNA INSTANCIA|; (if (not *PS*) (progn (setq *PS* (PS-Start)) (PL-FILEDIALOG-INIT))) ;;;(startapp "notepad" *PS-OUT*) (setq *PS* nil) (pl:getfiledps "Hola" "c:\\" "dwg" 1) How does it work?... When the code is loaded, a PowerShell instance and a base script are created. After that, simply call the pl:getfiledps function whenever you need it.
  13. dan20047
    Properties window & sssetfirst
    You're right, but it doesn't change the properties window behavior. I wonder if this is a Bricscad bug related to the PropertyPreviewDelay setting. For the sssetfirst syntax, I can't be bothered to look up the correct format so I always use the variable in both locations, since the help file says the first argument is ignored.
  14. mhupp
    looked at your code closer the first argument needs to be nil in sssetfirst left over from legacy code. https://help.autodesk.com/view/OARX/2023/ENU/?guid=GUID-4076CD9D-1C66-4C73-ACC0-3A6CD0B0D2D8 '(sssetfirst gripset[pickset]) 'gripset 'AutoCAD no longer supports grips on unselected objects, so this argument is ignored. However, if gripset is nil and no pickset is specified, sssetfirst turns off the grip handles and selections it previously turned on. 'pickset 'A selection set to be selected. (setq ss1 (ssget)) (sssetfirst nil ss1)
  15. dan20047
    I have dual monitors and properties is always open, it just isn't recognizing objects selected with sssetfirst. However you gave me the idea to toggle it off/of which does refresh it to show the selected objects. Thanks. (command "Propertiesclose" "properties")
  16. Great work!!! From a purely three-dimensional cross-sectional view, unlike the closed cross-sections of conventional three-dimensional software such as SketchUp, if the cut section after this trimming can be sealed off reasonably, it is at least visually more in line with intuition.
  17. MATCHPROP has settings, some specific to the object selected. It should match Text Height, etc. and Dimension Styles, etc., it also works between open drawings. AutoCAD 2022 Help | To Copy Properties From One Object to Other Objects | Autodesk AutoCAD 2022 Help | MATCHPROP (Command) | Autodesk This is a good reason to also use blocks, change one and the rest change as well.
  18. Is this a free service?
  19. Have you ever tried to use PRESSPULL on what looks like a completely enclosed area, but AutoCAD refuses to create or extrude a 3D solid? I've discovered that sometimes, the visualized boundary can be misleading. The presence of a small gap, overlapping objects, or objects that aren't actually forming a valid closed area can inhibit PRESSPULL's ability to create or extrude a 3D solid. Instead of redrawing everything, I would first try using BOUNDARY on the perceived enclosed area. If it fails to create a closed boundary, I would look at the endpoints and attempt to fix the gap or overlapping geometry. As soon as there is a valid closed boundary, PRESSPULL should be able to do its job. Have you ever encountered this problem while trying to create a 3D model? What was the cause in your case?
  20. Hi everyone, We're building CADProps, a free browser-based tool for quickly opening and inspecting STEP/STP files without installing a full CAD package. It's aimed at mechanical engineers, CNC users, and manufacturing teams who need a fast way to check model geometry before quoting or production: https://www.cadprops.com Full disclosure: CADProps is our tool. We're still improving it, so feedback on real-world STEP files—especially large or complex models—would be very useful.
  21. mhupp
    I usually just keep it docked on the right side and use ctrl+1 to open it if needed. any of these will open properties (command "Properties") (command "PR") (command "CH") (command "MO")
  22. Last week
  23. I use a variation of the ssx.lsp to select objects in the drawing. In Bricscad v15 using (sssetfirst ss1 ss1) would both activate grips and activate the properties window to show info on those objects. For example select all blocks with same name, I could quickly edit the attribute value for all of them. I'm testing upgrade to v26 and the properties window no longer activates unless I manually toggle the property preview button. Is there a system variable to use the old behavior? Here is the simple code: (setq ss1 (ssget)) (sssetfirst ss1 ss1)
  24. j2lstaples
    AI taking over
    Honestly, I've been using AI to code in AutoLISP for the past year or so and I think it's more successful at it than I am. I'm not saying it's clean code, but I'm saying it's already useful. I had a sales engineer ask me info on a project that they're selling trying to verify if what they sold was feasible and with the tool the AI built, I could give them concrete details. If I had to finish that tool, it would have taken me months to write it. I had to test it a bunch of times in autocad and give feedback and it'll find the problem. I had to upgrade which models I used if it gets stuck or restart a new chat. I have a bunch of md files for it to remember how the codebase works but it's getting there. I would say the AI didn't code the whole thing, I still gave it most of the ideas to use, it just had to fill stuff in between for the implementation. At the end of the day, I just want it to work. I had it write a debug.txt which it can read after each test run. I had it create toy functions to measure what it did after the fact. There's a couple of good engineering practices still in place, it's just that I'm allowing myself to have 'fuzzy' details about the implementation.
  25. Yes, I've encountered that problem...usually that's when I have to go to my lisp library or come up with new code to accommodate for when matchprop falls short
  26. The Scenario (The Security Blindspot) A draftsman, facing a tight deadline, downloads an unvetted compiled plugin (.DLL or .ARX) from a public forum. Because CAD plugins execute directly within the application's memory space, malicious code bypasses traditional network firewalls entirely, exposing the enterprise to ransomware. The IT department demands a complete lockdown of all CAD installations. The Legacy Approach OS-level lockdowns cripple engineering efficiency, while traditional CAD deployment tools (requiring .exe installers and Registry modifications) trigger massive IT compliance red flags. The Modern Solution (Zero-Install & SecOps Gateway) VedaCAD operates with a Zero-Install footprint, utilizing a pure LISP microkernel that requires no OS-level admin privileges or Registry modifications—complying natively with strict corporate GPO security policies rather than demanding risky security exemptions. For ultimate B2B compliance, VedaCAD offers two powerful safeguards: EDR SecOps Gateway: All third-party binaries imported into the corporate Foundry are automatically routed to the company's internal EDR (Endpoint Detection and Response) sandbox for black-box detonation. Only payloads returning a "SAFE" webhook are authorized for fleet deployment. Dedicated Enterprise Nodes (DED): VedaCAD can dynamically provision an absolutely physically isolated database and edge storage node, eliminating shared-database cross-tenant risks. (Note: Both the EDR Gateway integration and Dedicated D1 Nodes are exclusive Add-ons available for the Enterprise Tier.)
  27. The Scenario (The Firewall Block) You find a modern package manager to streamline your CAD fleet, but your Chief Information Security Officer (CISO) instantly rejects it. For defense contractors, top-tier architectural firms, and government agencies, placing proprietary LISP routines and DWG templates on a third-party SaaS cloud is a strict violation of corporate data sovereignty policies. The Legacy Approach Enterprises are forced to choose between highly efficient cloud deployments and strict data residency compliance, often falling back to archaic, hard-to-maintain on-premise servers. The Modern Solution (BYOS - Bring Your Own Storage) VedaCAD pioneers a decoupled Control Plane / Data Plane architecture through its BYOS integration. Enterprise administrators can bind their own private AWS S3, Cloudflare R2, or internal MinIO bucket API credentials directly into the dashboard. VedaCAD handles the complex routing and telemetry, but the physical assets (.LSP, .DLL, .DWT) are written to and streamed directly from the customer's own private storage. We enforce an "As-Is Custody" guarantee—our servers never touch your proprietary binaries. (Note: The BYOS S3 routing module is an exclusive Add-on available for the Enterprise Tier.)
  28. The Scenario (The 50-Page PDF) A new engineer joins the firm. The CAD Manager wastes half a day mapping Support Paths, importing .arg profiles, and loading menus. Even worse, the firm has heavily invested in proprietary automation plugins, but the new hire doesn't know how to use them because no one reads the 50-page static PDF manual buried on the intranet. The Legacy Approach Manual terminal configuration is unscalable. Static documentation disconnected from the drafting environment leads to poor tool adoption. The Modern Solution (JIT Provisioning & In-Context SOPs) With VedaCAD’s Enterprise functionalities, onboarding is automated via JIT (Just-In-Time) Provisioning. Utilizing Enterprise SSO, the CAD Manager assigns the new hire to the "Structural Squad". When the engineer logs into AutoCAD, VedaCAD instantly fetches and mounts every proprietary plugin, template, and command alias assigned to that specific squad in seconds. If they don't know how to use a tool? They simply click the "SOPs" button inside the VedaCAD client. VedaCAD uses a secure hardware-bound token (OTT) to instantly bypass passwords and log them into the Web Portal in their browser, displaying the specific Markdown guidelines and Demo GIFs tied to their assigned assets.
