Mine is in my support folder..
This post is like option 2 of this post. Is there an option 3 ? Will answer last question in other post. -
Adding data to property lookup tables
I don;t think you need Excel. You can match a dcl to a dynamic block so you can enter values and then in turn update the block. It is something I have insert block and the dcl is displayed, its global code so works with any dynamic block. Need a dwg with your block and can test. -
Masterful -
jamami started following Adding data to property lookup tables
I am updating a dynamic block using dummy parameters to achieve multiple visibility states, I have got it working at 2m and 3m by manually inputting data but I need to go to 40m and there are 9 visibility states for for each length. I can generate the data in Excel and ideally I want to cut paste this into the property lookup table but this is not possible. I can cut paste into a block property table but not a lookup table and adding 300+ lines manually in 3 separate tables is not practical. The attached image shows one table completed for 2 and 3m lengths. Can this data be scripted ?
rlx started following increase or decrease value of attdef...help
rlx replied to leonucadomi's topic in AutoLISP, Visual LISP & DCL
Load VT , start with VT (or C:VT) Click on one of the attdef's , you get the main dialog Click on setup (bottom right) and change difference to 5 , click on ok to return to main dialog Finaly click on Renum and select all attdefs , enter, done... VT uses grread in a constant loop so exit with escape, cancel or spacebar that will get you in quick menu and you can escape / Quit / cancel from there. Not all buttons will work because some are company specific like revision but for now it should get you what you need. VT.LSP -
Field update issues in dynamic block
the attached video shows the issue we are experiencing. selecting 'Evaluate' on the Field formula box blows up the expression :- {\urtf1\ansi\ansicpg65001\deff0\deflang2057{\fonttbl{\f0\fnil\fcharset0 MS Shell Dlg 2;}} \viewkind4\uc1\pard\f0\fs17\{\\urtf1\\ansi\\ansicpg65001\\deff0\\deflang2057\{\\fonttbl\{\\f0\\fnil\\fcharset0 MS Shell Dlg 2;\}\}\par \{\\colortbl ;\\red190\\green190\\blue190;\}\par \\uc1\\pard\\f0\\fs17 250+\\highlight1\\kerning1\\protect 2250\}} Video Project 1.mp4 -
leonucadomi started following increase or decrease value of attdef...help
leonucadomi posted a topic in AutoLISP, Visual LISP & DCL
hello: Now I find myself in another situation. I have an attdef group I would like to be able to make a selection in a window and that the numbering is increased or decreased by a desired amount. maintaining the numbering format with zeros examplse (001,020,999) example: any help you can provide, thanks. Drawing2.dwg -
it is an issue on a few machines here in the office. I saw a post on autodesk forum suggesting it was UTF-8 coding setting in windows regional settings, I have tried changing this but it has had no effect. Block attached with both field and dim variants _d-spans.dwg -
@jim78b Have you tried the Autodesk Design Center? You can drill into drawings and pull out blocks, layers, etc.. You can use a short program to pull up design center in the folder you want - something like: ;;-------------------------------------------------------- ;; Command: (C:DSN) ;; Description: ;; This Command Starts the AutoCAD Design Center window ;; in the path specified. ;;-------------------------------------------------------- (defun c:DSN ( / usrpath) (setq usrpath "C:\\MyBlocks");<--CHANGE TO YOUR PREFFERED LOCATION. (if (= (getvar "adcstate") 0) (if usrpath (command "._adcnavigate" usrpath)) (command "._adcclose") ) (princ) ) ;; End Command "DSN"
@jim78b You cannot make an AutoLISP or Visual LISP program have a modeless interface like your example unless you use a third party add-on called OpenDCL or another called ObjectDCL. Using those is also very advanced programming. Otherwise, DCL in AutoLISP can only make simple Modal dialogs (meaning you can't work in the graphics editor when they are displayed).
SLW210 replied to jamami's topic in AutoCAD Drawing Management & Output
Your Field inside your Formula needs an object selected. I just picked the top line and it works for me. Not sure if that works for the correct value, so you may need something else to pick. _d-spans fixed.dwg -
ok you are the best thanks for your time and support!
I am waiting for IT to install some things including updates for Visual Studio, when that gets done, I'll look into writing something better. The LISP that was posted in your other thread was a better start than this.
Ok for now thanks, I thought it was much simpler. Thanks a lot
As I have already mentioned, that LISP has too many issues. I trash canned all of my attempts, @pkenewell is correct, I had something else in there. I'll try to think about it. Yes, I had nil there. Every issue I tracked down, a new one came up. Just forget that LISP and start from scratch.
https://apps.autodesk.com/ACD/it/Detail/Index?id=8055037424722464637&appLang=en&os=Win64
@jim78b I don't understand what you mean. Again - if you want this program to be property troubleshooted, please provide an example drawing and a visual explanation if what you are expecting to happen.
@pkenewell I dont know how , when, or why but I can see the acadauto.chm to work I did a copy file from Copy and paste chm and paste to the dwg , and despite vlide show the same alert NOT FOUND , it work.
Sorry, but thank you for your hard work. It works now, but: I thought I had a window always open with the block list that automatically updates without me having to select anything. I'd like the window to stay open even when I'm working. If I click on a block name, it highlights in the drawing. Sorry if I wasn't specific. Thanks
@jim78b I also noticed on the first line, the setq statement need to be set to something. You can't just have (setq *block_name_list*). I just put "nil" below, but it seems to want a list of Block Names? ;; This global list will store the clean names for selection (setq *block_name_list* nil);<-- Needs to be set to something ALSO: If you want someone to work on this for you. I think you need to provide a sample drawing with what you want to accomplish. I don't have time to troubleshoot this by re-creating the circumstances where this program is needed.
@jim78b There is another one. Sorry - I did this accidentally in my earlier post on those 2 lines. I corrected my previous posts. " (sssetfirst nil nil)" ; Clear any previous selection grips
pkenewell started following acadauto.chm not found
@devitg This appears to be a Bug in VLIDE. I get the same problem. I think the interface was not updated for the current help system.
thanks i edit but give me again syntax error
@jim78b The end quote is in the wrong place on this line. See correction below. " (if ss (sssetfirst nil ss))" ;<--Quote BEFORE comment. Highlight all found instances in current space
