  2. You want to create a GUI? There’s a sample in python creating a palette with block names and preview https://github.com/CEXT-Dan/PyRx?tab=readme-ov-file#features you’d have to roll it yourself. There’s also opendcl if you feel more comfortable with lisp
  3. Yesterday
  4. jim78b
    Detail circle in MS
    Monday i Will test It and i tell you .thanks a lot
  5. SLW210
    Detail circle in MS
    Did you get a chance to see how this was working for you?
  6. You asked in the AutoLISP, Visual LISP & DCL Forum, something like what @mhupp posted is the best solution with FREE LISP, IMO. You need to look at asking this in some .NET forums, though not sure the FREE will happen.
  7. I just use -. 1'2-3/4 will work, just a fraction all you need is 3/4, no need for 0'0-3/4, for just fractional inches just 2-3/4 works. The 0'-0 1/16" was referencing a selection example in the precision for Architectural Units.
  8. Last week
  9. AutoCAD will correctly interpret fractions if the type of UNITS is set to Architectural.
  10. Great thank you . i am planning to add into the startup folder and give a go but got distracted today .
  11. Yes i don't mean lisp. I ask if there was something way to do this free .
  12. when there is no space ! then how autocad identifies fractional part ?
  13. When you print/plot to PDF make sure that the setting to print with transparency is turned on.
  14. Just get that one then. Drawing Tree | AutoCAD | Autodesk App Store I am pretty sure, that is not a LISP.
  15. i want like this https://sites.google.com/site/avcplugins/dwgtree
  16. ok i use wayback site and download but is not what i search. i prefer a window palette like count
  17. yes i know but It would be interesting to be able to make that block window without it highlighting anything and without launching the count command. i
  18. Not much time this week, should be better next week for playing with codes.
  19. Not Support File Search Path (that may need to be also), but Trusted Locations folder.
  20. Thanks i go the website try download blktree.lsp but is corrupted!
  21. You can also try with COUNT command built-in AutoCAD. Something like this you will get from picture 1.
  22. This has what you want but you will have to use the wayback website to find a none corrupt file as it looks like the website has been abandon. (Last Updated April 1st, 2013) blktree https://jefferypsanders.com/autolisp.html might have the file kicking around here some where.
  23. No worries, I get that we have other usages, for my work changing the position of the arc segment without changing the tangentcy is important. If it doesn't keep that I'll have to fix it afterwards every time. I updated the code in the previous post to be a little bit less gittery, but I understand that not everyone will sacrifice smoothness to have snap enabled. Therefore here is a version without snap. So the only difference with the one from Evgeny's is that you are able to type in an offset distance as well as select an (inexact) point. offset - nosnap.lsp
  24. I'll try to find time in the coming days to modify and expand offsetea. I've found a couple of bugs in it, likely due to the lack of stress testing. Also, I'll try to find a way to rein in those arcs governed by tangents. I might include a few more improvements as well. But I'll leave that as a surprise.
  25. I don't know how this code behaves when running on other versions of AutoCAD and/or PCs. So I’ll speak based on what I see on mine: Basically, what your code proposes is the same as Evgeny's original code. But with less visual smoothness. Maybe that's why GRSnap doesn't seem visually useful. In any case, I don't understand why it's so important for the arcs to be governed by tangents. If, at the very least, you could control them so the user could adjust them with the cursor, I’d see some utility in it. I think you wrote this too quickly — you can probably do much better. P.S. Your spontaneity and sincerity make me feel comfortable saying this, because it makes me think you'll gladly accept others' honesty as well.
  26. How can I create an additional window, such as Properties, to list all blocks and groups, including nested ones. I'd like to see a tree view. See the attached image, the window on the left.
  27. Nice Lee, never thought about doing that
