help with extracting text from one dimension....
ronjonp replied to leonucadomi's topic in AutoLISP, Visual LISP & DCL
Glad to help : ) -
@GLAVCVSok ,l will manage it, thanks
@ronjonp Yes, thank you very much. It's perfect now! Sorry for explaining it wrong at the beginning. - Today
Code updated above ... give it a try! -
@maahee I think you should copy the code again. I forgot to clean up the junk files before publishing it, and it might not be working properly because of that.
Rhovium joined the community
The separator character is " " (1 space) and is stored in <->. You will need to change it when necessary.
Try (defun c:crgPts (/ nmarch arch lin p p0) (defun damePts (tx m / c p l l1 i num nm nmdo damePts) (setq num "" nm "") (while (/= (setq c (substr tx (setq i (if i (1+ i) 1)) 1)) "") (if (= c m) (setq l (append l (list num)) l1 (if (not (member nm l1)) (append l1 (list nm)) l1) num "" nm "" nmdo nil) (cond ((and (not nmdo) (wcmatch c "#,[.]")) (setq num (strcat num c))) ((or nmdo (wcmatch c "@")) (setq nm (strcat nm c) nmdo T)) ) ) ) (cons (car l1) (if (/= num "") (append l (list num)) l)) ) (setq <-> " "); change if need (if (setq nmarch (getfiled "Load file" "" "txt" 2)) (if (setq arch (open nmarch "r")) (while (setq lin (read-line arch)) (setq p (damePts lin <->) p (list (atof (cadr p)) (atof (caddr p)) (if (cadddr p) (atof (cadddr p)) 0.0)) ) (if p0 (command "_line" p0 (setq p0 p) "") (setq p0 p) ) ) ) ) (princ) )
蒸桑拿的企鹅 joined the community
I did see a for-purchase program that used a raster image and maybe worked with QGIS, I'll see if I can find it again, the demo video looked pretty good and even split around islands, side branches, etc.. It had a lot of parameters to fill out in a window for what to grab, so still a good bit of work, IIRC.
How can I write the code for a batch fillet plugin for images like this?
SLW210 replied to amook147's topic in AutoLISP, Visual LISP & DCL
Are you looking for a LISP, Python, VBA, .NET, etc.? I moved your thread to the AutoLISP, Visual LISP & DCL Forum. -
x y z 21.0937p1 200.4997p1 0p1 22.0937p2 201.4997p2 0p2 23.0937p3 203.4997p3 0p3 23.0807p4 203.4797p4 0p4 The txt file should always be kept in the above uniform format and should have the prefix or suffix from the point point.txt
lisp to find convert all unexplodable blocks within a file to explodable blocks
Nikon replied to Elektrik's topic in AutoLISP, Visual LISP & DCL
Yes, rename the block first, then use the @ronjonp code. -
Probably, for my task, it will be easier to change the @mhupp code. ;; Copy dimension value to another location (x0.001) + text angle = 0 ;; DimCopy.lsp the original / creator mhupp ;; https://www.cadtutor.net/forum/topic/75587-help-with-extracting-text-from-one-dimension/#findComment-597630 ;; modification using AI (defun _DimCopy001:OnlyNum (s / lst out c) ;; we leave only numbers, minus sign, period/comma (setq lst (vl-string->list s) out "") (foreach c lst (if (member c (vl-string->list "0123456789-.,")) (setq out (strcat out (chr c))) ) ) ;; comma -> period (vl-string-subst "." "," out) ) (defun _DimCopy001:SetText (e / ed txt num new r50) (setq ed (entget e) txt (cdr (assoc 1 ed))) ;; change the text to *0.001 (if (and txt (/= txt "")) (progn (setq txt (_DimCopy001:OnlyNum txt)) (if (and txt (/= txt "")) (progn (setq num (atof txt)) (setq new (rtos (* num 0.001) 2 3)) ; for example 4250 -> 4.250 (setq ed (subst (cons 1 new) (assoc 1 ed) ed)) ) ) ) ) ;; ang 0 (DXF 50) (if (setq r50 (assoc 50 ed)) (setq ed (subst (cons 50 0.0) r50 ed)) (setq ed (append ed (list (cons 50 0.0)))) ) (entmod ed) (entupd e) ) (defun C:DimCopy001Txt (/ dim BP LastEnt en obj oldEcho) (vl-load-com) (setq oldEcho (getvar 'cmdecho)) (setvar 'cmdecho 0) (while (setq dim (car (entsel "\nSelect Dimension: "))) (setq obj (vlax-ename->vla-object dim)) (setq BP (vlax-get obj 'TextPosition)) (setq LastEnt (entlast)) (command "_.Copy" dim "" "_non" BP (getpoint BP "\nCopy to: ")) (command "_Explode" (entlast)) (if (setq en (entnext LastEnt)) (while en (cond ((= "MTEXT" (cdr (assoc 0 (entget en)))) (command "_Explode" en) ; convert mtext to text ) ((= "TEXT" (cdr (assoc 0 (entget en)))) (_DimCopy001:SetText en) ; <<< scale + angle 0 ) (t (entdel en) ) ) (setq en (entnext en)) ) ) ) (setvar 'cmdecho oldEcho) (princ) ) Perhaps this code can be made prettier and shorter... -
amook147 posted a topic in AutoLISP, Visual LISP & DCL
Drawing2.dwg As shown in the figure below: Select multiple graphics in batch and change the R value from 0.2 to another value? -
amook147 joined the community
@ronjonp thanks. This code reduces the height of the text, but I need to reduce the dimension value (x 0.001) and insert the text (angle text 0, text height = height of the dimtext). -
tombu started following Creating a surface model in Civil 3D from existing 3D polylines, lines and points
tombu replied to 0misclose's topic in Civil 3D & LDD
- 5 replies
- surface modelling
- civil 3d
(and 2 more)
Tagged with:
Lee Mac started following lisp to find convert all unexplodable blocks within a file to explodable blocks
Lee Mac replied to Elektrik's topic in AutoLISP, Visual LISP & DCL
You could use this to rename the reference in question so that it references a different (duplicate) block definition, which could then be marked as explodable. -
Something like this? (defun c:foo (/ d e el m p1 p2) (cond ((and (setq e (car (entsel "\nPick dimension: "))) (vlax-property-available-p (vlax-ename->vla-object e) 'measurement) (setq d (vla-get-measurement (vlax-ename->vla-object e))) (progn (vlax-for a (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) (cdr (assoc 2 (entget e))) ) (and (= "AcDbMText" (vla-get-objectname a)) (setq m (vlax-vla-object->ename a))) ) m ) (setq p1 (cdr (assoc 10 (setq el (entget m))))) (setq p2 (getpoint p1 "\nSpecify second point: ")) ) (setq e (entmakex (append (vl-remove-if '(lambda (x) (= 330 (car x))) el) (list (cons 10 p2)))) ) (vla-put-textstring (setq e (vlax-ename->vla-object e)) (vl-princ-to-string (* 0.001 d))) (vla-put-rotation e 0.) ) ) (princ) ) -
ronjonp replied to Elektrik's topic in AutoLISP, Visual LISP & DCL
This is not possible that I'm aware of. The code above could be modified to explode the blocks selected then make those block definitions un-explodable again. -
BIGAL replied to Elektrik's topic in AutoLISP, Visual LISP & DCL
You may have to Wblock one block, open the wblock, change the explode to "Yes" then rename the block. You can now insert that block into your dwg say deleting the original block. But you will have 2 blocks. -
@SLW210 I like the idea of choices in layout name, the main issue is how each company names their layouts or sheet names etc. We used a simple year+projectnumber so a a 2026002-D01 was the name of a layout and single PDF when plotted. If a multi page pdf it would be just 2026002.pdf but we had revisions and a plot date on each sheet.
@GLAVCVS I’ve been testing your latest code. It’s truly impressive. I’m attaching an image of the most difficult area of the last drawing: it’s hard to find a spot where the centerline is not perfectly equidistant. And where it isn’t, it’s always below the tolerance — hats off to you. I’ve also been curious to try the code on embedded geometric figures. As you said, the code fails quite badly here. But when it does work, it returns results that are quite different from those of the @dexus or @GP_ codes, which are much simpler I wonder: why?
I apologize for my English. I use a translator, but I'm not sure if it translates well enough. I have several blocks with the same name. I want to allow exploding for only one selected block. Convert one unexplodable block to explodable block (another translation). Is it possible to leave the other blocks of the same name unchanged? -
marko_ribar started following lisp to find convert all unexplodable blocks within a file to explodable blocks
marko_ribar replied to Elektrik's topic in AutoLISP, Visual LISP & DCL
Ron, I think he thinks to make explodable only selected references and not definitions... Unfortunately, I think this is impossible... -
marko_ribar replied to heschr's topic in AutoLISP, Visual LISP & DCL
Hi, it's me again... I've implemented lastly coded interventions by @GLAVCVS into my cleaned version... It should work well with user selection of network entities... Still filter for selection is now very robust, but it seems that it should be coded like that (I don't know how to make it better - shorter)... I think that this version fulfills any situation that may occur LINES, POLYLINES (2D-Heavy, 3D), LWPOLYLINES (without arced segments). If you see something I missed, please don't hasitate to inform - post reply... ;; Pathfinding with the A* algorithm by ymg 22/07/2024 ; ;; ; ;; Revised a prog by HELMUT SCHRÖDER - heschr@gmx.de - 2014-09-14 ; ;; found at Cadtutor.net ; ;; ; ;; Kept the same format for edges list but added lines as valid choice ; ;; Format: (((x1 y1 z1) (x2 y2 z2)) ((x2 y2 z2) (x3 y3 z3))....) ; ;; ; ;; The user is asked to pick a start and an endpoint. ; ;; The program will find the shortest path in a network of connected ; ;; lines and draw a new 3dpolyline representing the result. ; ;; ; ;; Two lists of nodes openlst and closelst are created from the above ; ;; mentionned edges list. The format of a node list is: ; ;; (((Point) (Prev Point) Cumulated_Distance Estimated_Total_Distance)...) ; ;; ; ;; Main change from origina are: ; ;; - cons the list instead of append ; ;; - vl-sort the openlist instead of the quicksort ; ;; - Replaced and renamed some vars and subroutine. ; ;; - Added fuzz 1e-4 to all points comparison ; ;; - Change the get_path function ; ;; - Added line as possible edges ; ;; - Added an error handler ; ;; - Added a timer to the search portion of the program ; ;; ; ;; The above changes amounted to an acceleration of about 4x from the ; ;; original program. ; ;; : ;; If you compile this program to a .fas you'll get more than 10x faster. ; ;; ; ;| Added or modified code by GLAVCVS (january 2026) -All set are grouped into one -An associative sparse matrix cell->handles is created for faster cell querying (using new 'addToDict' and 'getCell' functions) -The "edges" list is replaced with the local search retourned by 'getCell' T E S T S ===== fas: 4-5 x faster than previous fas lsp: 7-8 x faster than previous lsp |; (defun c:A* (/ *error* addToDict getCell upd_openlst in_openlst get_path memberfuzz mk_lwp f3Dpol LM:rtos set_errhandler sspl i startp endp e openlst closelst found acdoc lstClvs Pathlay Pathcol Pathlwt varl node ti ) (or (not (vl-catch-all-error-p (vl-catch-all-apply (function vlax-get-acad-object) nil))) (vl-load-com)) (defun *error* (msg) (if e (if command-s (command-s "_.draworder" e "" "_f") (vl-cmdf "_.draworder" e "" "_f") ) ) (mapcar (function eval) varl) (if (and msg (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*"))) (princ (strcat "\nError: " msg)) ) (vla-endundomark acdoc) (princ) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;ADDED by GLAVCVS ;;;Create dictionary (defun addToDict (en / p val id clv i l c a) (setq i -1 id (cdr (assoc 5 (setq l (entget en)))) c (= (cdr (assoc 0 l)) "LINE") a 10) (while (setq p (if (and (setq i (1+ i)) c) (cdr (assoc (+ a i) l)) (vlax-curve-getPointAtParam en i))) (if (setq val (assoc (setq clv (strcat (LM:rtos (car p) 2 4) "," (LM:rtos (cadr p) 2 4) "," (LM:rtos (caddr p) 2 4))) lstClvs)) (setq lstClvs (subst (append val (list (cons id i))) val lstClvs)) (setq lstClvs (cons (list clv (cons id i)) lstClvs)) ) ) ) ;;;return list cell ;;*** Modified to access the new dictionary format *** (defun getCell (pt / val clv lr pr par l c oc p0 p) (defun oc (c e i) (if c (cdr (assoc (+ i 10) l)) (vlax-curve-getPointAtParam e i))) (if (setq val (assoc (setq clv (strcat (LM:rtos (car pt) 2 4) "," (LM:rtos (cadr pt) 2 4) "," (LM:rtos (caddr pt) 2 4))) lstClvs)) (foreach par (cdr val) (setq e (handent (car par)) c (= (cdr (assoc 0 (setq l (entget e)))) "LINE")) (if (zerop (setq pr (cdr par))) (setq lr (cons (list (oc c e pr) (oc c e (1+ pr))) lr)) (setq lr (cons (list (oc c e (1- pr)) (setq p0 (oc c e pr))) lr) lr (if (setq p (oc c e (1+ pr))) (cons (list p0 p) lr) lr) ) ) ) ) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;; ; ;; upd_openlst ; ;; ; ;; Each node of the openlst is passed to this sub and we scan the edges list ; ;; to find the corresponding edges. Then both points of the edges are tested ; ;; for equality to the nodes. The fixed cost (distance) is updated and so is ; ;; the estimated total distance. Updates are first put in a temporary node. ; ;; ; ;; We then proceed to test if the temp variable is already in the closelst ; ;; and proceed to the next edge. ; ;; ; ;; If temp is true and temp is not in closelst we go to the recursive sub ; ;; in_openlst which adjust the values and return the updated openlst ; ;; ; ;; Upon return we sort the openlst on smallest estimated distance ; ;; and return the openlst to the main routine ; ;; ; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (defun upd_openlst (node endp openlst closelst / lEdges pt fcost p1 p2 d temp) (setq pt (car node) fcost (caddr node) ) (setq lEdges (getCell pt)) (foreach edge lEdges (setq p1 (car edge) p2 (cadr edge) d (distance p1 p2) temp nil ) (cond ((equal pt p1 1e-4) (setq temp (list p2 p1 (+ fcost d) (+ fcost d (distance p2 endp)))) ) ((equal pt p2 1e-4) (setq temp (list p1 p2 (+ fcost d) (+ fcost d (distance p1 endp)))) ) ) (if (and temp (not (memberfuzz (car temp) closelst))) (setq openlst (in_openlst temp openlst)) ) ) (vl-sort openlst (function (lambda (a b) (< (cadddr a) (cadddr b))))) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (defun in_openlst (node lst) (cond ((not lst) (list node)) ((equal (car node) (caar lst) 1e-4) (if (< (cadddr node) (cadddr (car lst))) (cons node (cdr lst)) lst ) ) (t (cons (car lst) (in_openlst node (cdr lst)))) ) ) ;; ; ;; get_path ; ;; ; ;; Returns The list of points of shortest path found from closelst. ; ;; ; (defun get_path (lst / path) (setq path (list (caar lst)) prev (cadar lst) lst (cdr lst) ) (while (setq lst (memberfuzz prev lst)) (setq prev (cadar lst) path (cons (caar lst) path) ) ) path ) ;; ; ;; memberfuzz by Gile Chanteau ; ;; ; ;; Modified to work with nodes list ; ;; ; (defun memberfuzz (p lst) (while (and lst (not (equal p (caar lst) 1e-4))) (setq lst (cdr lst)) ) lst ) ;; ; ;; f3Dpol ; ;; ; ;; Draw an 3dpolyline given a point list ; ;; ; ;; Will be drawn on layer, lineweight and color defined by Variables ; ;; at beginnung of program. ; ;; ; (defun f3Dpol (pts c / ep ll la e) (setq ep (if (= 1 (getvar (quote cvport))) (vla-get-PaperSpace acdoc) (vla-get-ModelSpace acdoc)) ll (apply (function append) pts) la (vlax-safearray-fill (vlax-make-safearray vlax-vbDouble (cons 0 (1- (length ll)))) (mapcar (function float) ll)) e (vla-Add3DPoly ep la) ) (vla-put-Color e c) (vla-put-Layer e Pathlay) (vla-put-Lineweight e Pathlwt) (vlax-vla-object->ename e) ) ;; ; ;; mk_lwp ; ;; ; ;; Draw an lwpolyline given a point list ; ;; ; ;; Will be drawn on layer with color and lineweight defined by Variables ; ;; at beginnung of program. ; ;; ; (defun mk_lwp (pl) (entmakex (append (list (cons 0 "LWPOLYLINE") (cons 100 "AcDbEntity") (cons 100 "AcDbPolyline") (cons 8 Pathlay) (cons 62 Pathcol) (cons 90 (length pl)) (cons 70 (* 128 (getvar (quote plinegen)))) (cons 370 Pathlwt) ) (mapcar (function (lambda (a) (cons 10 a))) pl) ) ) ) ;; A wrapper for the rtos function to negate the effect of DIMZIN - Lee Mac (defun LM:rtos (real units prec / dimzin result) (setq dimzin (getvar (quote dimzin))) (setvar (quote dimzin) 0) (setq result (vl-catch-all-apply (function rtos) (list real units prec))) (setvar (quote dimzin) dimzin) (if (not (vl-catch-all-error-p result)) result ) ) ;; Error Handler by Elpanov Evgenyi ; (defun set_errhandler (l) (setq varl (mapcar (function (lambda (a) (list (quote setvar) a (getvar a)))) l)) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; MAIN ROUTINE ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ; Change values of following 3 variables to suit your need. ; (setq Pathlay "0" Pathcol 3 ; 1=Red 2=Yellow 3=Green etc. ; Pathlwt 30 ; lineweight for path 0.3 mm ; ) (or acdoc (setq acdoc (vla-get-activedocument (vlax-get-acad-object)))) (set_errhandler (list "clayer" "osmode" "cmdecho")) (setvar (quote cmdecho) 0) (setvar (quote osmode) 1) (setvar (quote lwdisplay) 1) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (prompt "\nSelect LINE and polygonal POLYLINE network entities...") (if (setq sspl (ssget (list (cons -4 "<or") (cons 0 "LINE") (cons -4 "<and") (cons 0 "POLYLINE") (cons -4 "<or") (cons 70 8) (cons 70 9) (cons 70 0) (cons 70 1) (cons 70 128) (cons 70 129) (cons -4 "or>") (cons -4 "and>") (cons -4 "<and") (cons 0 "LWPOLYLINE") (cons -4 "<not") (cons -4 "<>") (cons 42 0.0) (cons -4 "not>") (cons -4 "and>") (cons -4 "or>")))) (foreach en (vl-remove-if (function listp) (mapcar (function cadr) (ssnamex sspl))) (addToDict en) ) ) (initget 1) (setq startp (getpoint "\nPick or specify Start Point : ")) (initget 1) (setq endp (getpoint "\nPick or specify End Point : ")) (setq openlst (list (list startp (list 0.0 0.0 0.0) 0.0 (distance startp endp)))) (vla-startundomark acdoc) (setq ti (getvar (quote millisecs))) (while (and openlst (not found)) (setq node (car openlst)) (if (equal (car node) endp 1e-4) (setq found t closelst (cons node closelst)) (setq closelst (cons node closelst) openlst (upd_openlst node endp (cdr openlst) closelst)) ) ) (if found (if (vl-some (function (lambda (x) (not (equal (last x) 0.0 1e-4)))) (setq path (get_path closelst))) (setq e (f3Dpol path Pathcol)) (setq e (mk_lwp path)) ) (alert "No path was found...") ) (princ (strcat "\nExecution time : " (itoa (- (getvar (quote millisecs)) ti)) " milliseconds...")) (*error* nil) ) HTH. Regards, M.R. -
Hi Nikon. I'm not sure what you're asking?
