  2. not in this case , unless i am doing something wrong. I have attached example dwg. Basically i had 3DFaces as Triangles and converted them using lisp into 3dpolyline Triangles, but it creates 4 Vertices for each Triangle, another lisp which supposed to create contours over triangles refusing to do so and say 3dpolylines are not closed polylines. Long story short, I am looking for a lisp which could create Contours at desired interval over 3DFaces. For example at 0.2m 1.0m interval and label them up along at specific distance. sample.dwg
  3. Please explain how to use it correctly, which command to call?
  4. Thanks @GLAVCVS I would advise against (vlr-remove-all), as this will remove all reactors defined within the session, not only those defined by your program.
  5. Today
  6. Great code, as always, Mr. Lee As for mine, I think I forgot that some reactors are persistent. So, Nikon, the problem is that you must have opened the same drawing several times in the same AutoCAD session, and several prompts have accumulated, repeating the request several times. That problem shouldn't occur anymore with this new code. Also, you'll be able to see the text inserted before confirming the closing of the drawing. Simply replace the "fota" function in your "acad2021Doc.lsp" with this new one. (defun fota (/ arch cad cmd mens) (defun pregunta (a b / cad) (cond ((= (car b) "CLOSE") (if (and *lstCmds* (setq mens (cmdsCargados)) (= (vlax-invoke-method (vlax-create-object "wscript.shell") 'popup "驴Dejar en el dibujo un MTEXT con todos los comandos utilizados?" 0 "Guardar comandos usados" 4) 6) ) (progn (vlr-remove-all) (vla-AddMText (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))) (vlax-3d-point (getpoint "\nInsertion point...")) 100 mens) (vlax-invoke-method (vlax-get-acad-object) 'Update) ) (vlr-remove-all) ) ) ((= (type a) 'VLR-Lisp-Reactor) (if (not (member (setq cad (substr (car b) 4 (- (strlen (car b)) 4))) *lstCmds*)) (setq *lstCmds* (cons (substr (car b) 4 (- (strlen (car b)) 4)) *lstCmds*)) ) ) ) ) (vlr-remove-all) (foreach sim (atoms-family 0) (if (wcmatch (setq cmd (strcase (vl-princ-to-string sim) T)) "c:*") (setq *afI* (cons sim *afI*)) ) ) (setq *r* (vlr-command-reactor nil '((:vlr-commandwillStart . pregunta)))) (setq *r1* (vlr-lisp-reactor nil '((:vlr-lispwillstart . pregunta)))) )
  7. Here's a quick & dirty version - it's not advisable to prompt the user for any input as part of a reactor callback. (defun init ( ) (foreach grp (vlr-reactors :vlr-command-reactor :vlr-lisp-reactor) (foreach rtr (cdr grp) (if (= "lisp-commands" (vlr-data rtr)) (vlr-remove rtr) ) ) ) (setq lisp-command-list nil) (vlr-command-reactor "lisp-commands" '((:vlr-commandwillstart . onsave))) (vlr-lisp-reactor "lisp-commands" '((:vlr-lispwillstart . onlisp))) (princ) ) (defun onsave ( rtr arg / idx lyr sel str ) (setq lyr "lisp-commands") (cond ( (not arg)) ( (not (wcmatch (setq arg (strcase (car arg))) "SAVE,QSAVE,SAVEAS"))) ( lisp-command-list (if (setq sel (ssget "_X" (list (cons 8 lyr)))) (repeat (setq idx (sslength sel)) (entdel (ssname sel (setq idx (1- idx)))) ) ) (setq str "") (foreach itm (vl-sort lisp-command-list '(lambda ( a b ) (> (cdr a) (cdr b)))) (setq str (strcat str "\\P" (car itm) "\t\t" (itoa (cdr itm)))) ) (makelayer lyr) (entmakex (list '(0 . "MTEXT") '(100 . "AcDbEntity") '(100 . "AcDbMText") '(010 0.0 0.0) (cons 1 (substr str 3)) (cons 8 lyr) ) ) ) ) (princ) ) (defun onlisp ( rtr arg / fun itm ) (cond ( (not arg)) ( (wcmatch (setq arg (strcase (car arg))) "~(C:*)")) ( (setq fun (substr arg 4 (- (strlen arg) 4)) itm (assoc fun lisp-command-list) ) (setq lisp-command-list (subst (cons (car itm) (1+ (cdr itm))) itm lisp-command-list)) ) ( (setq lisp-command-list (cons (cons fun 1) lisp-command-list))) ) (princ) ) (defun makelayer ( lay ) (if (not (tblobjname "layer" lay)) (entmake (list '(0 . "LAYER") '(100 . "AcDbSymbolTableRecord") '(100 . "AcDbLayerTableRecord") '(070 . 0) (cons 2 lay) '(062 . 8) '(290 . 0) ) ) ) ) (vl-load-com) (init)
  8. I load programs and use them.
  9. I need you to explain a little more. Did you use multiple Lisp commands or just load files? Take a screenshot of the code you pasted into the "acad2021Doc.lsp" file.
  10. I tested the code a bit more, sometimes the window with the message "Display commands on the screen?" does not work correctly. I have to click "Yes" several times, I specify the insertion point of the text, but the window appears again, and if I click "No", the window also appears several times. And one more small note, when I specify the insertion point, I don't see how the text is inserted. A window about saving the drawing appears immediately… Maybe I'm doing something wrong...
  11. Steven P
    Maybe this might help: Lee Macs option at the end might give you a start. Do you want it to open the viewports automatically or with the user perhaps pressing say 'space' bar?
  12. Hello, good day. I’d like to continue working on the material volume tables in AutoCAD — specifically the ones that have been exploded and no longer retain a defined table structure. These tables begin with a top row that contains the stationing of each section, formatted like this: Material(s) at Station 0+250.00 This first row contains only one column. The second row has four fixed columns that serve as headers for the data rows below. These headers are consistent across all sections and do not change. From left to right, they are: Material Name Area Volume Cumulative Volume The third row and all subsequent rows contain the actual data, aligned with the headers above. The material names may vary from project to project, but within a single project, they remain consistent across all sections. In the second column of each row, the area of the material is listed as a numeric value. The third column contains the volume, and the fourth column contains the cumulative volume. Since these tables have been exploded, the numbers no longer update automatically. That’s why we need a solution where, after manually updating the area values, the corresponding volumes and cumulative volumes are automatically recalculated and replaced in the table. So far, all our attempts to achieve this have failed. Now I’d like to share some insights that might help: Stationing is critical. The first step must be to extract the station number from the top row as an integer. This allows us to calculate the distance between two consecutive sections, which is essential for computing the volume of a truncated cone. Area values should remain unchanged. We only need to read them and use them in calculations to update the Volume and Cumulative Volume columns. New observation about table geometry: The vertical spacing between the second row and all subsequent rows is exactly three times the text height. Also, the insertion point (X coordinate) of the area values is exactly aligned with the insertion point of the word “Area” — and the same applies to the Volume and Cumulative Volume values. Update logic: Let’s assume we have only one material row (though usually there are more). Let’s name the area value in the first section A1, and the area in the second section A2. These two values represent the top and bottom surfaces of a truncated cone with height H, where H is the difference between the station numbers of the two sections. The calculated volume should replace the volume value in the second section. Then, this volume should be added to the cumulative volume from the first section, and the result should replace the cumulative volume in the second section. Naturally, this volume and cumulative update must follow the correct station order
  13. I need a lisp code to open named viewports one after another. To view as animation.
  14. I'm not sure...
  15. OVERKILL should remove the duplicate vertices.
  16. This tool will be perfect when complemented by another tool that detects this MTEXT and loads the files it refers to. This means that the command name must be the same as the file name. This idea needs to be further developed. It's very interesting. PS: Is it possible that this issue has already been discussed in another thread on this forum?
  17. @GLAVCVS ¡Muchísimas gracias! Thanks a lot! The last code works great! I get a list of used programs. Special thanks for "Nikon's doubts". Now it's the end of my doubts. ¡Buena suerte en nuevos proyectos!
  18. Yesterday
  19. Hi all I have many Closed 3dpolyline Triangles with 4 vertices each. Would it be possible with the help of lisp command to track all triangles and remove duplicates, please? Its the first and second vertices with same position. Thank you
  20. Final edit to prevent the dialog from asking unnecessary questions. Remember: the LISP commands it will remember will be those that have been executed at some point. (defun fota (/ arch cad cmd mens) (defun pregunta (a b / cad) (cond ((= (car b) "CLOSE") (if (and *lstCmds* (setq mens (cmdsCargados)) (= (vlax-invoke-method (vlax-create-object "wscript.shell") 'popup "Print commands on screen?" 0 "Nikon's doubts" 4) 6) ) (vla-AddMText (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))) (vlax-3d-point (getpoint "\nInsertion point...")) 100 mens) ) ) ((= (type a) 'VLR-Lisp-Reactor) (if (not (member (setq cad (substr (car b) 4 (- (strlen (car b)) 4))) *lstCmds*)) (setq *lstCmds* (cons (substr (car b) 4 (- (strlen (car b)) 4)) *lstCmds*)) ) ) ) ) (foreach sim (atoms-family 0) (if (wcmatch (setq cmd (strcase (vl-princ-to-string sim) T)) "c:*") (setq *afI* (cons sim *afI*)) ) ) (setq *r* (vlr-command-reactor nil '((:vlr-commandwillStart . pregunta)))) (setq *r1* (vlr-lisp-reactor nil '((:vlr-lispwillstart . pregunta)))) ) (defun cmdsCargados (/ cad) (setq *cadCmds* nil) (foreach sim (atoms-family 0) (if (not (member sim *afI*)) (if (and (wcmatch (setq cad (strcase (vl-princ-to-string sim) T)) "c:*") (member (strcase (substr cad 3)) *lstCmds*) ) (setq *cadCmds* (strcat (if *cadCmds* (strcat *cadCmds* "\n") "\\C1Commands loaded during last sesion:\\C256\n") (substr cad 3))) ) ) ) *cadCmds* ) (fota)
  21. Thanks for the suggestion, @Steven P I'll look into it.
  22. I think it's a good idea that I'm also going to try: leaving a text box with the names of the Lisp commands used to edit a drawing. This new code will filter all of AutoCAD's predefined Lisp commands and, of those loaded by the user, will only consider those that have been used in the drawing. To avoid confusion, replace everything above with this new one. (defun fota (/ arch cad cmd) (defun pregunta (a b / cad) (cond ((= (car b) "CLOSE") (if (and *lstCmds* (= (vlax-invoke-method (vlax-create-object "wscript.shell") 'popup "Print commands on screen?" 0 "Nikon's doubts" 4) 6)) (c:cmdsCargados)) ) ((= (type a) 'VLR-Lisp-Reactor) (if (not (member (setq cad (substr (car b) 4 (- (strlen (car b)) 4))) *lstCmds*)) (setq *lstCmds* (cons (substr (car b) 4 (- (strlen (car b)) 4)) *lstCmds*)) ) ) ) ) (foreach sim (atoms-family 0) (if (wcmatch (setq cmd (strcase (vl-princ-to-string sim) T)) "c:*") (setq *afI* (cons sim *afI*)) ) ) (setq *r* (vlr-command-reactor nil '((:vlr-commandwillStart . pregunta)))) (setq *r1* (vlr-lisp-reactor nil '((:vlr-lispwillstart . pregunta)))) ) (defun c:cmdsCargados (/ cad arch linea) (setq *cadCmds* nil) (foreach sim (atoms-family 0) (if (not (member sim *afI*)) (if (and (wcmatch (setq cad (strcase (vl-princ-to-string sim) T)) "c:*") (member (strcase (substr cad 3)) *lstCmds*) ) (setq *cadCmds* (strcat (if *cadCmds* (strcat *cadCmds* "\n") "\\C1Commands loaded during last sesion:\\C256\n") (substr cad 3))) ) ) ) (if *cadCmds* (vla-AddMText (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))) (vlax-3d-point (getpoint "\nInsertion point...")) 100 *cadCmds*)) (princ) ) (fota)
  23. I have about 50 lisp programs in startup. I upload the rest as needed. I have a list of autoload programs of this type (_autoload "MTxt")(c:MTxt). Many teams have pseudonyms in acad.pgp. I just want the list of used programs to remain in the drawing. Lee Mac's LISPLogV1-0.lsp program does what I need, only in a .csv file.
  24. 300 Lisp programmes... If you have the time, create this: (defun recordLISP (LispName / ) (if (= LispsList nil) ; check if list exits (progn (setq LispsList (list LispName)) ; create new list, add text string to it ) ; end progn (progn (setq LispsList (cons LispName LispsList)) ; add LispName to LispsList ) ; end progn ) ; end IF ) (defun c:MySave ( / ) (defun MakeMText (pt TxtString) (entmakex (list (cons 0 "MTEXT") (cons 100 "AcDbEntity") (cons 100 "AcDbMText") (cons 10 pt) (cons 1 TxtString) )) ; end Entmakex, End List ) ; end MakeMText (defun LM:lst->str ( lst del ) (if (cdr lst) (strcat (car lst) del (LM:lst->str (cdr lst) del)) (car lst) ) ) (MakeMText (GetPoint "Enter Insert Point") (LM:lst->str (reverse LispsList) "\\P")) ) and for every LISP you want to record add this line (recordLISP "-LISPNAME-") A little over the top maybe, but you get to control what LISPs you really want to record. For example, I have a couple of shortcuts, for example "ZA" for Zoom All, "PlotPDF" to plot a PDF - neither of these examples are a part of the process to create a drawing, where others such as "CTX+" - Copy Text, increment by 1 is, I might want to record that. If you LISP library is like mine you could probably cut 50 or so off that 300 LISPs as unnecessary to record think. I am curious what the end result you want to do is, once you have listed the commands you use, you can recreate process to create the drawing, but perhaps without also knowing mouse clicks and keyboard entries not a lot else?
    아주 좋은 프로그램입니다 저는 이프로그램의 라이센스를구입하려하는데 방법을모르겠네요 알려주세요
  25. @NikonI think there's an easier and more definitive way. Wait.
  26. I saved this code in acad2021Doc.lsp
  27. I open a new file, download, for example, 3 lisps, but when I close it, the text is saved indicating the number of programs, more than 3. In my opinion, programs that are in startup are being displayed...
