  1. Today
  2. When several engineers are working on the same DWG, keeping track of changes can get tricky. I think it's best to maintain one central folder for approved drawings and use clear revision numbers so everyone knows which file is current. AutoCAD's DWG Compare feature is also useful for checking what has been added, removed, or modified between two versions. Revision clouds and notes can help highlight specific changes. It's also worth checking Xrefs and related drawings before issuing the updated file to make sure nothing has been missed.
  3. Yesterday
  4. Hi everyone, I'm Kavi. I'm looking into how people turn drawings into editable CAD and would like to hear how you handle it in practice. When you receive a PDF drawing without the original DWG, do you usually import it and clean up the geometry, or redraw it? I'm interested in both CAD-exported PDFs and scanned drawings. What makes you decide it's quicker to start again? A recent example would be helpful. I've also put together a short survey on this, if you'd rather share your experience there: https://forms.gle/QoFESgVmF7Hv3XXP9 It takes about 2 minutes. Replies here are just as welcome.
  5. The traditional battery industry has long depended on what can be extracted from the Earth, whether it’s lithium nickel, cobalt, or graphite. Nexus Power is upending that with an innovative approach to source battery materials above ground instead. Across India, fields of rice, wheat, corn, and other crops leave behind enormous amounts of stalks, leaves, and other organic materials after harvest. In many regions, fields are burned to clear the land for the next planting season, worsening the air quality in a country that already grapples with pollution. Nexus Power sees something entirely different in those agricultural remains: the raw ingredients for a sustainable battery alternative. Founded by twin sisters Nishita and Nikita Baliarsingh, Nexus Power is developing energy-storage technology that derives key materials from agricultural waste. It’s a win-win for the circular economy. Less air pollution from the fires and a sustainable battery alternative that is also completely biodegradable. With AutoCAD and Autodesk Fusion, they’re making this vision a reality. From an idea to a working battery Autodesk technology has been pivotal in helping Nexus Power move from concept to physical battery. The team uses AutoCAD and Fusion to design the battery components, evaluate designs through simulation, and rapidly turn digital models into working prototypes. According to Nikita Baliarsingh, the seamless interoperability between the two allows the team to pass updates smoothly between environments, reducing translation errors and keeping hardware and electrical teams in sync. “Using AutoCAD alongside Fusion gives us a seamless 2D-to-3D design pipeline,” Nikita says. “AutoCAD handles the precise 2D schematic design, electrical routing, and mechanical layouts, while Fusion allows us to take those layouts into 3D space for spatial packaging, thermal analysis, and structural CAD modeling.” Early protoype of Nexus Power battery cell. “Developing advanced battery technologies requires precision at every level, AutoCAD provides the foundational drafting environment needed to translate complex electro-chemical and structural parameters into standardized, production-ready engineering blueprints efficiently.” Nikita Baliarsingh, Co-founder, Nexus Power Designing with precision from the start During the design phase, AutoCAD was key for efficiency and accuracy. Automated wire numbering and component tagging streamlined complex wiring diagrams and virtually eliminated labelling errors. Smart schematic libraries sped up component placement and ensured consistency across battery module schematics. The team could also flag open circuits and duplicate tags early, saving significant debugging time prior to prototyping. Dynamic blocks allowed the team to quickly adapt and scale components across different battery pack architectures. With automatic bill of materials (BOM) generation in AutoCAD, they were able to instantly create accurate component lists straight from schematics, drastically cutting down manual documentation time. The Electrical toolset was also used for the electrical architecture, wiring harnesses, and battery management system (BMS) integration. “The primary benefit of the Electrical toolset was the automated schematic auditing and real-time error checking, which ensured high accuracy across complex circuitry without requiring manual double-checks,” Nikita says. Nexus Power battery pack. Looking ahead with AutoCAD For Nexus Power, AutoCAD is the undisputed choice as they continue to refine and expand their batteries. “AutoCAD is the industry standard for a reason,” Nikita says. “It offers unmatched precision, high adaptability, and seamless standardization across engineering teams. Its built-in automation features handle tedious tasks so designers can focus on core product innovation.” The post Nexus Power Turns Agricultural Waste Into a Sustainable Battery Alternative With AutoCAD appeared first on AutoCAD Blog. View the full article
  6. There is always a balance between providing enough information for manufacturing and making a drawing unnecessarily crowded. Adding every dimension, tolerance, surface finish, note, and detail may make a drawing difficult to read, while leaving too much information to interpretation can lead to manufacturing errors. How do you decide what information belongs on the main drawing, what should go into detail views, and what can be handled through general notes or standard specifications? Has your approach changed with experience, particularly when drawings are used by different manufacturing teams or suppliers?
  7. When importing geometry from another CAD system, I have occasionally seen models contain tiny edges, sliver faces, and irregular surfaces that are barely noticeable visually but cause problems during subsequent operations. These imperfections can affect face selection, filleting, shelling, Boolean operations, and downstream manufacturing workflows. How do you normally deal with this type of geometry? Do you repair the imported model, simplify the problematic areas, or rebuild the affected features from scratch?
  8. Last week
  9. Am sure that is new from when I was recording macros - might be time to revisit action recorder then
  10. BIGAL
    Hatch Name to Multileader Lisp?
    In simple terms two ways to do it a field in the block text or just read the layer and write that into the attribute. Using the field option has the advantage of if you change the hatch layer the attribute updates. the disadvantage is that you can not save the ID of the object in a Block it has to be updated each time you say make the Mleader. Yes can be done. Maybe later today will do something, limited time at moment.
  11. @Dadgad "30 or 40 drawings open at the same time" here is a freebie for you. It will display the dwg names for you pick which one to Goto. Multi radio buttons.lspListbox-AH.lsp Gotodwg.lsp
  12. ROLANDO JR
    Hi, Could anyone help me create fix the Attached Mleader. 1. Add Field to read the Hatch by Layer name. 2.Create a LISP/Routine Thank you in advance. Mleader Tag By Hatch Layer Name.dwg
  13. Actually you can edit the action macros, although I typically just rerecord them too, if I find I have an issue. In order to access the editing window click on the circled icon in the second screenshot. For me, the best ones do not require additional input while they are running. Typically the macro might perform up to about a dozen different actions, ending with Zoom All, Purge and SAVE. I usually might have 30 or 40 drawings open at the same time, than forward tab to the next drawing and run the same one again...5 or 6 seconds later, when it has completed Tab forward again, and just roll through a fair sized batch quite quickly.
  14. SLW210
    Free Linux 2D CAD similar to AutoCAD LT 2000
    I have moved your thread to the Catch All Forum. How does this compare to LibreCAD?
  15. Action Recorder lead me to LISPs, I was annoyed with having to re-record each time I didn't quit get it right and couldn't edit the recording. Good tool though
  16. Before sending 2D profiles for laser, plasma, or waterjet cutting, drawings sometimes contain small gaps, overlapping entities, duplicate lines, open contours, or geometry that appears closed but cannot be recognized as a valid profile. These problems may not be obvious during drafting, but they can interrupt the CAM workflow or cause unexpected toolpaths. What checks do you normally perform before sending CAD geometry for CNC cutting? Do you use automated geometry validation, cleanup tools, or manually inspect each contour before exporting DXF?
  17. When designing welded structures in CAD, the overall assembly may be straightforward to model, but preparing fabrication drawings for individual members can become time-consuming. Members often require different cut lengths, end angles, hole locations, notches, and orientation details. Extracting this information from the assembly without creating confusion can be challenging, especially when several members look similar. How do you organize weldment models and fabrication drawings? Do you model every member separately, use a structured assembly approach, or rely on cut lists and detailed views to communicate fabrication requirements?
  18. Does anybody else use the ACTION RECORDER? It may well be, the most underappreciated functionality in AutoCad. As one who does not write Lisp, I find it quite intuitive, and incredibly helpful "on the fly". Essentially a Key Stroke Recorder, I use it all the time, and it saves me hours on a busy day, with highly repetitive tasks which need to be run on many hundreds of drawings in succession. Another great 3D Modeling command is PRESSPULL, it is much more powerful, quicker and more useful than EXTRUDE. I first learned about it in this video tutorial https://www.cadtutor.net/tutorials/autocad/extrude-and-press-pull/ . 3D Align is another great command, for when things go all off axis, and need to be realigned.
  19. import traceback import wx from pyrx import Ap class TestUIDialog(wx.Dialog): def __init__(self, parent=None): style = wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER super().__init__( parent, title="PyRx wxPython Control Check", size=(340, 240), style=style, name="PyRxTestUIDialog", ) # Create a panel, a sizer and some controls panel = wx.Panel(self) sizer = wx.BoxSizer(wx.VERTICAL) self.cb = wx.CheckBox(panel, label="Modern Visual Styles Active") self.cb.SetValue(True) self.combo = wx.ComboBox( panel, choices=["Option A", "Option B"], value="Option A", style=wx.CB_READONLY, ) # Bind to an event self.combo.Bind(wx.EVT_COMBOBOX, self.on_combo_select) self.gauge = wx.Gauge(panel, range=100) self.gauge.SetValue(70) self.txt = wx.TextCtrl(panel, value="Text input test") self.btn = wx.Button(panel, wx.ID_OK, label="Close Test") # add the controls to the sizer for ctrl in (self.cb, self.combo, self.gauge, self.txt, self.btn): sizer.Add(ctrl, 0, wx.ALL | wx.EXPAND, 8) # add the sizer to the panel panel.SetSizer(sizer) def on_combo_select(self, event): print("Selected:", self.combo.GetValue()) event.Skip() @Ap.Command() def testui(): try: with TestUIDialog() as dlg: res = Ap.Application.showModalDialog(dlg) print(res) except Exception as err: traceback.print_exception(err)
  20. Some components look straightforward in a 3D CAD model, but once they reach the machining stage, certain features can become difficult to manufacture because of tool access, internal corners, deep pockets, or awkward setups. A model may satisfy the design requirements but still require unnecessary machining operations or special tooling. At what stage do you consider machining limitations while developing a CAD model? Do you make design changes to simplify tool access and setups, or does the manufacturing team usually identify these issues after the model is completed?
  21. I previously worked for a Municipal Authority and they had a Licensed Surveyor so he had the problem of tying things together. Sometimes easy sometimes very complex. Most of our projects were field surveyed so were current and tied to world co-ordinates.
  22. I have produced a Linux (and windows) 2D CAD program which may be of interest to some of your users. Basic drafting no bells or whistles. Free download, no registration Free to use perpetually. Am I allowed to mention it on this forum. If so where.
  23. indiancad
    Automatically drawing blocks
    Thanks for the clarification, SLW210. Appreciate the guidance. I'll keep contributing new topics and discussions.
  24. @AONE_LED has received the message about reviving old posts. So should be good now. @indiancad creates new posts, so no problem there, some are interesting at least. @BIGAL that's a good idea, as they do seem quite helpful, just a decade or so late.
  25. Even if left as a scan, the scan will last longer than the paper (maybe). Saying that, I work for a very old company (about a century), we still have some pretty decent old blueprints, but the decent ones look to have been copies of the originals. Luckily a quality scanner has a BLUEPRINT mode and makes some pretty good scans of those most of the time. We use a lot of contractors, so lucky for me they do a lot of that as well. Sometimes I do it for them if my boss requests. Here lately we have had a company do some laser scanning, further reducing the need for the old drawings. There is no guarantee the old drawing are correct either, so yes you always have to verify. I previously worked for a company that did quite a bit of work in the automobile industry, you know some of those factories are very old, that was the company that sent them out to be digitized. And yet, due to all of the different work (some not documented apparently) and different companies that do work, everything needs field verification. So all of that had to be budgeted into the job bids. Several competitors went under for having low bids and having to eat all of those costs. I never said anything about not verifying everything. I actually have to take worn out parts and create a .dwg of it, that takes a whole lot of verifying and redrawing.
  26. If there is a need for mass distribution, you can try the VedaCAD.com I developed (supports AutoCAD 2006 to the latest version) 1. For individual developer distribution scenarios, you can use VCID to distribute it for free to the target users 2. For enterprise scenarios, you can centrally manage the plugins (such as AutoLISP, ARX, DLL, etc.) and environment configurations (such as CTB, SHX, DWT, etc.) for the entire company (even across regional multi-offices)
  27. However.... I have been working for 30 years now, never picked up a set of pencils or sat at a drawing board, always CAD and electronic formats, we really shouldn't be accepting scanned drawings! OK so I work on utilities, and some of the kit is 50 years and more old there is still those drawings to work through but I push in every project for the budget to redraw what we can.
  28. When working with complex 3D parts, small changes to an earlier feature can sometimes cause several downstream features to fail, particularly when fillets, chamfers, cuts, and face references depend on the original geometry. This can make seemingly simple design changes unexpectedly time-consuming. How do you structure your 3D models to minimize these failures? Do you prefer building simpler features first, delaying fillets until the end, avoiding references to unstable faces, or using a different modelling strategy altogether?
