Tharwat started following TAKEOFF PIPE OF DIFFERENT SIZES
Have a close look at my Water Supply program which should facilitate your work significantly. Trial version is outdated now. https://autolispprograms.wordpress.com/water-supply-2/
mhupp started following TAKEOFF PIPE OF DIFFERENT SIZES
I would just have a menu to pick what type then loop a polyline picking points. creating the polyline on that layer with the color code maybe a thickness as well. and have the ability to switch type.
leerken joined the community
FRATRI joined the community
Mitsue joined the community
100% recomended, you saved my day. I tried everything without success, then based on your comment I finally got the drawing saved. Thank you so much!
i need to duplicate the original layer and for each size assign a color instead of redrawing them manually
EnM4st3r started following Hello everyone!
dont know if thats what you want, but this code creates a Layerfilter/group with all layers of a object selection. Layerfilter.lsp
Welcome aboard. Yes need a sample dwg showing a before and after, breaking at intersections various examples are out there. When asking for help you nearly always should provide a sample dwg or some images.
NicholasS joined the community
AutoLISP routine not working in German AutCAD
mhupp replied to Vittorio's topic in AutoLISP, Visual LISP & DCL
This will toggle between states using ldata to remember last state. Defaults to turning off if the command hasn't been run before. ;;----------------------------------------------------------------------------;; ; Toggle Freeze state of layers with -PT suffix ; https://www.cadtutor.net/forum/topic/99073-autolisp-routine-not-working-in-german-autcad/ (defun c:foo (/ frz) (or (setq frz (vlax-ldata-get "frz" "toggle")) (setq frz "Off")) (if (eq frz "Off") (progn (vlax-ldata-put "frz" "toggle" "On") (command-s "_-layer" "_freeze" "*-PT" "") (command-s "_-layer" "_off" "*-PT" "") ) (progn (vlax-ldata-put "frz" "toggle" "Off") (command-s "_-layer" "_thaw" "*-PT" "") (command-s "_-layer" "_on" "*-PT" "") ) ) (princ) ) -
CivilTechSource replied to ababs's topic in AutoLISP, Visual LISP & DCL
Can you upload an example *.dwg file please to see how we can help. -
AutoCAD suitable laptop for a Mechanical Engineering freshman
mhupp replied to BenG54's topic in Hardware & Operating Systems
I think lisp is very limited in mac as well. most of the vla and vlax functions are not there. -
mhupp started following Mtext editor changes font and size and AutoCAD suitable laptop for a Mechanical Engineering freshman
don't limit yourself to just AutoCAD. It would be in your best interest to learn or at least be familiar with other software. I know onshape is a web-based design software that you can check out right now. That seems to be on pair with SolidWorks and doesn't require massive hardware to run. -
ababs joined the community
Hello everyone, I’m trying to create a LISP to help with pipe takeoffs in AutoCAD. Here’s what I want it to do: I have a plan with pipes of different sizes drawn as lines or polylines. I want to create a takeoff layer (e.g., "M-TakeOff-CWS"). Instead of redrawing, I just select a line or polyline segment and choose a pipe size. The code should automatically split the selected segment at all intersections with other lines or polylines. Each resulting sub-segment is duplicated in place on the takeoff layer. The duplicated segments get a color based on the chosen size. The original line or polyline stays intact. Later, I want to filter by color/size to calculate total lengths. I’ve tried several approaches, but I’m struggling with: Splitting segments automatically at intersections. Duplicating them on a new layer. Assigning colors by size. Does anyone have a simple LISP example or guidance for this workflow? Thanks in advance!
engmhelal82 joined the community
Could it be? The way to reverse one inexplicable error is to reverse another inexplicable error. CGI movie coming soon: AutoCAD: Into the Errorverse !
Turning off formatting seems to have worked. Thanks.
in good programming its harder to know when code will fail or do things you don't want. If your ok with turning off all layers that end in -PT. might have some layer that doesn't have points or something. The command might do this already cant test right now but list out all layers that were turned off as a double check. and while command is slower than vla or entmake and has some other quarks its often times simpler/easier to use. as this for example two lines of code vers what i just posted. (defun c:foo ( / doc layers lay name laylist) (vl-load-com) (setq laylist '()) (vla-StartUndoMark (setq doc (vla-get-ActiveDocument (vlax-get-acad-object)))) (setq layers (vla-get-Layers doc)) (vlax-for lay layers (if (wcmatch (setq name (strcase (vla-get-Name lay))) "*-PT") (progn (setq laylist (cons name laylist)) ;build list of layer names (vla-put-Freeze lay :vlax-true) (vla-put-Off lay :vlax-true) ) ) ) (vla-EndUndoMark doc) (if laylist (progn (princ (strcat "\nLayers frozen and turned off (" (itoa (length laylist)) "):\n")) (foreach n (reverse laylist) (princ (strcat " " n "\n")) ) ) (princ "\nNo Layers Matching *-PT found.") ) (princ) ) You could probably combine those two functions into one using ldata as a toggle between on and off. ill post later tonight. -
Vittorio replied to Vittorio's topic in AutoLISP, Visual LISP & DCL
Oh dear, my mistake. I didn't think it through. It's obvious that objects cant be frozen or turned off so I rewrote and shortened my functions to this: ; Freeze and turn off layers with -PT suffix (defun c:zOff () (command-s "_-layer" "_freeze" "*-PT" "") (command-s "_-layer" "_off" "*-PT" "") (princ) ) ; Thaw and turn on layers with -PT suffix (defun c:zOn () (command-s "_-layer" "_thaw" "*-PT" "") (command-s "_-layer" "_on" "*-PT" "") (princ) ) Now they do exactly what I need them to, but is that foolproof? I tested the function in a drawing that contains at least one of the above mentioned layers and on a drawing that doesn't. No issues, only a message like "no matching layers found". That should be fine. I've read that VL(A(X))-functions are faster, but the code code would be bulky. Do you recommend something different from my code? Best regards -
adry joined the community
I'm assuming its the new Notepad and not the one from 1995. it defaults to copy text with formatting. You have three options. You can change the default font and size in notepad settings, disable formatting also in settings ,or use Ctrl + Shift + V to paste as plain text. there also might be a right click paste as plain text option.
Avoiding Copy and Paste to secure clipboard data progress!
ScottMC replied to ScottMC's topic in AutoLISP, Visual LISP & DCL
much easier to use the coords pastable.. I use them mid command with !pp <prev.point>... and needed to comment line '056' - Last week
pkenewell started following Steven P
Steven P started following Avoiding Copy and Paste to secure clipboard data progress!
Steven P replied to ScottMC's topic in AutoLISP, Visual LISP & DCL
A couple more comments: Collected the defuns together at the top of the routine - easier to spot them that way Used vl-princ-to-string for the coordinates to string, looses the ',' though but the reverse shouldn't need that Added a check that the layer exists before making it new (could be an error) Reset system variables to as they were (eg cmdecho_old) rather than specifying a value Just tidied up the indenting a touch - my ADHD - and added some annotations for closing brackets Do you need to use the selection set for anything else (ss) In the entmakex point, do you need to set 210 ? (defun c:4x (/ *error* pt1 ss ) (vl-load-com) (defun *error* ( msg ) (setvar 'cmdecho 0) (vla-endundomark (vla-get-activedocument (vlax-get-acad-object))) (if msg (prompt (strcat "\n" msg)) ) (setvar 'cursorsize Cursor_Old) ;; reset (setvar 'cmdecho CmdEcho_Old) ;; reset (princ) ) ; end *errror* (defun zPoint ( pt1 / exv) ;; 3d point mfg ;; added pt1, usually better to specify (setq pt1 (trans pt1 1 0)) (setq exv (trans (list 0 0 1) 1 0 T)) (entmakex (list (cons 0 "POINT") (cons 10 pt1) (cons 210 exv) ;; do you need to use 210? )) ; end entmakex, end list ) ; end zpoint (defun cdd ( pt1 / pp) (princ "\n") (setq pp (vl-princ-to-string pt1)) (princ pp) ; (princ ; (setq pp ; (strcat ; (rtos (car pt1) 2 4) "," ;; 'p' -- vertex from pgm /\ getpoint,... ; (rtos (cadr pt1) 2 4) "," ; (rtos (caddr pt1) 2 4) ; ) ; end strcat ; ) ; end setq ; ) ; end princ (princ " cucs ");; ; (entmakex (list (cons 0 "POINT") (cons 10 pt))) ;; clean point (setenv "pp" pp) ;; crash saved coords ) ; end defun cdd (vla-startundomark (vla-get-activedocument (vlax-get-acad-object))) ;; Start Undo (if (tblsearch "LAYER" "XLINE") (princ "\nLayer Exists") ;; Layer exist. Do nothing (entmakex '( (000 . "LAYER") (100 . "AcDbSymbolTableRecord") (100 . "AcDbLayerTableRecord") (002 . "XLINE") ;; Layer Name (070 . 0) ;; Layer Status (bit-coded) (006 . "Continuous") ;; Layer Linetype (must be loaded) (062 . 252) ;; Layer Colour (1-255) (290 . 0) ;; Non-Plot Flag (0=Plot, 1=NoPlot) (370 . -3) ;; Layer Lineweight (-3=Default) )) ; end list, end entmakex ) end if layer (princ (strcat "\n 45"(chr 186)"/135"(chr 186)" 3D.XLines <!pp>")) (setq Cursor_Old (getvar 'cursorsize)) (setvar 'cursorsize 1) ;; Get the initial placement point (setq CmdEcho_Old (getvar 'cmdecho)) (setvar 'cmdecho 0) (while (setq pt1 (getpoint "\nSpecify Point for XLines: ")) (progn ;; Create a new empty selection set (setq ss (ssadd)) ;; do you need this if it is a local variable - or is there more code later? ;; Create horizontal xline and add to selection set (command "_.xline" "_a" 45 pt1 "") (command "_.chprop" "_L" "" "_la" "XLINE" "") ;; make xline grey (ssadd (entlast) ss) ;; likewise, do you need this ;; Create vertical xline and add to selection set (command "_.xline" "_a" 135 pt1 "") (command "_.chprop" "_L" "" "_la" "XLINE" "") ;; make xline grey (ssadd (entlast) ss) ;; and this (cdd pt1) ;; post coords (zPoint pt1) ;; point at 'pick.point ) ; end progn ) ;; end of while ;;--reset variables--;; (setvar 'cmdecho CmdEcho_Old) (setvar 'cursorsize Cursor_Old) (vla-endundomark (vla-get-activedocument (vlax-get-acad-object))) ;; End Undo (princ) ; exit quietly ) -
bustr started following Mtext editor changes font and size
I call up an existing block of MTEXT. The style and font are both simplex. When I paste new text from a notepad file the editor changes the size and font. This is getting to be a big headache. Does anyone know how to fix this?
BigDawg joined the community
I was having an issue editing an alignment within 2026. I did not set up the file, or the alignment. I was trying to update the stationing but everything was locked/greyed out. I opened Geometry Editor, and unlocked the Parameter Constraints, no luck. I closed CAD, and even restarted my computer, still no luck. After selecting the alignment, it appeared to be data referenced into the file, when looking within my toolspace at data shortcuts, I did not see any such reference. With the alignment selected, I then selected Promote Data Reference under Modify within the menu, lo and behold, the alignment was editable! Maybe this is the case for you, maybe its not. Good luck!
mhupp started following TEXT REQUIRED
https://www.zwsoft.com/support/zwcad-base-faq/517
Suggestions received, posted and updated. As with the coords, the point is a reference entity. Thanks (defun c:4x (/ *error* pt1 pt2 ss ) (princ (strcat "\n 45"(chr 186)"/135"(chr 186)" 3D.XLines <!pp>")) ;; ai: https://www.google.com/search?q=saving+2+lines+selection%2C+autolisp&client=firefox-b-1-e&hs=AnK&sca_esv=3c4c5acec5573df9&biw=1198&bih=593&ei=JazVaZ2GN-3fp84P46_CyAM&ved=0ahUKEwjdrJWQit2TAxXt78kDHeOXEDkQ4dUDCBE&oq=saving+2+lines+selection%2C+autolisp&gs_lp=Egxnd3Mtd2l6LXNlcnAiInNhdmluZyAyIGxpbmVzIHNlbGVjdGlvbiwgYXV0b2xpc3AyBRAAGO8FMgUQABjvBTIFEAAY7wUyCBAAGKIEGIkFSKOCAVDmIlj5PHABeACQAQCYAakBoAHdCKoBAzEuN7gBDMgBAPgBAZgCCaACqAvCAg4QABiABBiwAxiGAxiKBcICCBAAGLADGO8FwgILEAAYsAMYogQYiQXCAgoQIRigARjDBBgKwgIIECEYoAEYwwSYAwCIBgGQBgqSBwUxLjYuMqAHwSSyBwUwLjYuMrgHzwrCBwczLTYuMi4xyAfBAYAIAA&sclient=gws-wiz-serp (vl-load-com) (defun *error* ( msg ) (setvar 'cmdecho 0) (vla-endundomark (vla-get-activedocument (vlax-get-acad-object))) (if msg (prompt (strcat "\n" msg))) (setvar 'cursorsize 100) ;; reset to my prefer (setvar 'cmdecho 1) (princ) ) (vla-startundomark (vla-get-activedocument (vlax-get-acad-object))) ;; (setvar 'cursorsize 1) (entmakex ;; <LM '( (000 . "LAYER") (100 . "AcDbSymbolTableRecord") (100 . "AcDbLayerTableRecord") (002 . "XLINE") ;; Layer Name (070 . 0) ;; Layer Status (bit-coded) (006 . "Continuous") ;; Layer Linetype (must be loaded) (062 . 252) ;; Layer Colour (1-255) (290 . 0) ;; Non-Plot Flag (0=Plot, 1=NoPlot) (370 . -3) ;; Layer Lineweight (-3=Default) ) ) (defun zPoint ( / exv) ;; 3d point at xline _mid (not on 'xline layer) (setq pt1 (trans pt1 1 0)) (setq exv (trans (list 0 0 1) 1 0 T)) (entmakex (list (cons 0 "POINT") (cons 10 pt1) (cons 210 exv))) ) (defun cdd () (princ "\n") (princ (setq pp ;; make/prints coords & paste usable (strcat (rtos (car pt1) 2 4) "," ;; 'p' -- vertex from \/ getpoint (rtos (cadr pt1) 2 4) "," (rtos (caddr pt1) 2 4) ) ) ) (princ " cucs ");; (setenv "pp" pp) ;; crash saved coords in reg ) ;;// ----------------------------------------------------------------------------------------------------------- ;; Get the initial placement point ;; (while (setq pt1 (getpoint "\nSpecify Point for XLines: ")) (setvar 'cmdecho 0) (progn ;; Create a new 'usable' empty selection set (setq ss (ssadd)) ;; Initialize an empty set: ;; Create horizontal xline and add to selection set (command "_.xline" "_a" 45 pt1 "") (command "_.chprop" "_L" "" "_la" "XLINE" "") ;; make xline grey (ssadd (entlast) ss) ;; adds 'xline to empty 'ss selection set ;; Create vertical xline and add to selection set (command "_.xline" "_a" 135 pt1 "") (command "_.chprop" "_L" "" "_la" "XLINE" "") ;; make xline grey (ssadd (entlast) ss) ;; adds another 'xline to 'ss selection set (cdd) ;; post coords of 'pick.point (zPoint) ;; point at 'pick.point ) (setvar 'cursorsize 100) ;; reset to my prefer (setvar 'cmdecho 1) ) ;; end of while (vla-endundomark (vla-get-activedocument (vlax-get-acad-object))) (*error* nil) (princ) ) -
pkenewell replied to ScottMC's topic in AutoLISP, Visual LISP & DCL
@ScottMC P.S. - I see now what the "zpoint" function intent is; for using (entmake) to create the points. I tried it out in a 3D drawing file, changing the current UCS, and it seems to work. fine. -
I didn't read the other responses, changing the value for LISPSYS worked. Thank you @mhupp @pkenewell
Oh yes - I forgot about that little detail
