  2. The blue dimension should become the same as the red one.
  3. Today
  4. I Really need to start using grread and grdraw more. seen some really nice things the past few week on here. what happens if you take out LM:rounddown function call? -edit i haven't run the code but might be something in the (if (< dst dse) that isn't updateing the cpt point correctly. that is making "outside" the other line.
  5. alanjt
    Curb offset
    I thought about using MLines, but decided against it because once I offset, I'm generally modifying to draw in curb ramps, etc. I've considered using different layers, but I've never been able to get other people on board. Might be time to give it another attempt. For grading, I have a separate program I wrote that creates my featureline curb offsets based on a selected featureline.
  6. Sometimes the extension lines of associative dimensions are stretched (for example, to the origin of coordinates ) when inserted into another drawing. Now I've found a way to disable size associativity, but I don't really like it. I only find out that the dimensions have lost their connection with the object when I insert them into another drawing (or turn on the annotation monitor). So I thought it would be possible to align the extension lines to a smaller extension line. Maybe there is a better way... ; disable associativity of only selected sizes (defun c:DimAssOf ( / ss) (vl-load-com) (prompt "\nSelect DIMENSION to disable associativity: ") (setq ss (ssget '((0 . "DIMENSION")))) (if ss (progn (command "_.DIMDISASSOCIATE" ss "") (prompt (strcat "\nDone: associativity is disabled for " (itoa (sslength ss)) " dimensions." ) ) ) ) (princ) ) extension lines.dwg
  7. I'm guessing they have a drawing and want all the long blue dim extension lines to be shortened to where the dimension is. but the top blue one looks like its pulling from the right and left like the dimension itself is inside the feature its measuring. were the bottom red is only pulling from the right.
  8. I don't think we've understood your question yet (at least I haven't). You might need to elaborate a bit and add some more images.
  9. I only did a quick peek since I am busy and haven't used SolidWorks in quite a while, but it looked like a pretty easy change. I am sure a deeper dig on the forums would show the process for updating, but I really didn't have time to look harder into it.
  10. Another way. this doesn't repeat but uses ldata so the user can just hit enter if they aren't changing the offset from last value inputted. Has to have an existing polyline to run and the new end point. will only update the last two closest points of the old polyline to the new end point. Route.mp4 Route.lsp
  11. Yesterday
  12. BIGAL
    Trying to adjust point marker location
    This is cut out of a CIV3D lisp for write text height of a cogo point. (alert "Pick CIV3D points press ESC or pick nothing to exit") (while (setq obj (vlax-ename->vla-object (car (entsel)))) ; vl 3d point convert to plain lisp (setq pt1 (vlax-safearray->list (vlax-variant-value (vlax-get-property obj "Location")))) Not sure but you may be able to put "Location".
  13. Added to my to do list may be a couple of days. 1st comment would do alphabetically for objects. So Mtext is before Text. You are lucky that I have get objects properties code.
  14. Err now i don't want to update to 2026 have alot of save macros that work alongside PDM.
  15. Hi, How can I ensure that vlax-curve-getClosestPointToProjection returns the closest point in every case? I suspect that the curve is merging in the projected plane and therefore it does not always return the closest point in the desired direction. Alternatively, I could probably use vla-IntersectWith method with a line object and find the closest point, but I'm using grread where vlax-curve-getClosestPointToProjection will be more appropriate, I don't have to create and delete line objects in while loop. Animation.apng Drawing1.dwg sline2_dev_v2.lsp
  16. Hello everyone. You need to select several sizes and align the extension lines to the short line of each selected size. Maybe there is such a program?
  17. From what I quickly look into on the Dassault Systems (SolidWorks) site, among other changes for SolidWorks 2025 API, there was a change in the methods for saving a drawing. My WAG is that's where the VBA is failing on SolidWorks 2025, could be another change as well.
  18. I would start by drawing five circles R10. Then two circles R4 using TTR. Then trim to suit.
  19. We use point styles with markers (which are blocks) instead of separate entities (which are also blocks) to show utility equipment like hydrants and valves. At least, the surveyors do. The engineers turn off the markers and insert blocks nearby to reduce clutter. That seems clunky to me. I would like to be able to offset a marker, the way you can rotate a marker, and put it somewhere nearby. I get that you can't just add a property to a Civil3D object, so we'd add user-defined properties for X and Y. So far so good. Where I get stuck is changing the position of the marker in relation to the point. You can change the insertion point of the block, but that applies to every instance. Dynamic blocks might work, but there would have to be a way to protect the dynamic parameters and actions from anyone who tries to change the block. You'd have to adjust the rotation every time you changed the position, and vice versa. It seems like more trouble than it's worth, but if there's something simple I'm missing, I'd appreciate any suggestions.
  20. How far should the centers of the radius-10 circles be from the center? In other words, how do you place the tabs (or whatever you call those circular protrusions)? It looks like the left and right sides of the central tab are different. Should they be symmetric? Once you place the tab circles, you should be able to draw the radius-4 circles as tangent to two of the tabs. Then it's just a matter of trimming. Here's what I got with the tabs placed on the diameter-80 arc:
  21. dexus
    Hybrid parallel
    In the voronoi version some error checking before trying to call _polyline should be added indeed. And this function is dependent on how well the points are distributed over the line (ent->pts function). For the lines close together, more points should be given and with crossing lines it will not work at all. It only works if the lines stay in between the two polylines, and it doesn't in the example from OP:
  22. dexus
    Hybrid parallel
    Thanks. The animation in the GIF is from the calculations made in _cornerOffset. When it was (finally ) working I replaced the animation code with error checking. Didn't take the time to make it do both, but I did want to show how it worked here.
  23. GLAVCVS
    Hybrid parallel
    I think you're doing a very good job. PS: The animation in the GIF doesn't look the same as the one in the code.
  24. Aftertouch
    @SLW210 here is a sample DWG Sample.dwg There are 4 'Object Data' tables in this DWG. I'd like to see each 'AutoCAD layer' on its own 'QGIS' layer, including only the assigned Object DATA'. MAPEXPORT only seems to allow to export all object data for some reason.
    When will this awesome tool be available for AutoCAD 2026?
  25. Yea with the resent forced update in windows 11 some things went funky for people.
  26. Also noticed the CopyToClipboardAPI can be replaced with three lines if you add a reference to Microsoft Forms 2.0 Object Library Dim obj As New MSForms.DataObject ... If description <> "_" Then obj.SetText description obj.PutInClipboard MsgBox "Description '" & description & "' copied to clipboard." Else
