  2. mhy3sx
    Auto dimension lisp
    I find a solution. I craete a polyline ,then auto dimension the polyline and delete the polyline. Beter tahn nothing Thanks
  3. Today
  4. You are starting from the benchmark are you not? To create lines by bearing and distance enter the LINE command, pick a start point, let go of your mouse and at the command prompt type in the @ symbol first followed by the distance and the bearing. Example: @50.00'<N80d04'30"E. By the way, I suggest you ask your questions in the thread I mentioned to you yesterday in our private message exchange. Please do not start a new thread. Thank you.
  5. mhupp
    Auto dimension lisp
    Drawing the line would also pick up 4 lines across the block. would maybe have to do a fence ssget. and if block draw a bounding box to pick up lines but even then could be inaccurate if not a square.
  6. That may be part of it, but I think some of it has to do with the answers to many inquiries is available without a login, and yes AI sometimes gives that in the answer to a search. Any search I do with the search engine (DuckDuckGo) gives an AI response at the top, or supposedly a summary of the results, the AI results can be inaccurate to say the least. I do see some posting on this and other forums for correct answers after the AI sends them down the wrong road. I seldom login to AUGI and Autodesk Forums, Autodesk rearranges their forum so much many links, some not even very old, go to a dead end now.
  7. SLW210
    TotalBoundary • Outline creation tool
    As I mentioned already, you need to start a new thread in the AutoLISP, Visual LISP & DCL Forum.
  8. Ankit Pandit
    HIPPED ROOF ROUTINES
    Thank you for the plugin it worked well
  9. mhy3sx
    Auto dimension lisp
    Hi BIGAL, I have try QDIM but working as The QDIM don't dimension the block (look the image) I want to draw a line by specifying two points, to indicate where dimensions should be placed. This line should only appear on the layers named WALLS-2D and CLOSETS-2D. The WALLS-2D layer contains both lines and polylines, while the CLOSETS-2D layer contains blocks. Thanks
  10. Ankit Pandit
    Hello, Anyone knows any tool or CAD plugin that extracts 2D boundary for drawings? i tried the total boundary but my trail period is over and I am not able to purchase the total boundary please help me find a tool
  11. Yesterday
  12. BIGAL
    Auto dimension lisp
    Yes I have something done like 40 years ago, but did you try QDIM is that in ZWCAD ?
  13. I am searching for a lisp code to recognizes and dimensions LINE or ARC objects located in the Wall-2D layers and blocks in the CLOSETS-2D layer. like the image The dimension layer is DIM The idea is to pick 2 points like a line and automatic insert the dmensions. I use ZWCAD. Thanks
  14. I am having issues with the beginning steps of the final project. I have been prompted to enter survey data, but every time i press enter to place the line down, it will just put a line down at where my cursor is.
  15. This is sad news and a little concerning that no explanation is being given. On the face of it, it looks like a complete disregard for the community - I hope that's not true. What is true is that community engagement on forums like this has declined in recent years. Some of that decline is a result of AI. I know that this site has been scraped by LLM bots and, as a result, people seeking answers don't need to visit the site if an AI agent can provide the answer. Just to let you know, I have no intention of closing or suspending this forum any time soon.
  16. Last week
  17. Tired to squeeze three lines into one from lee's code converted it back.
  18. Did crash upon: 'repeat.. changed my working 'C2 with the while cmdecho. Thanks -- Actually nice but the osnaps don't work with grrrr, the crash was from 'ctan:res var being unfilled (40..) true, an interesting alternate. Thanks mhupp.
  19. Thanks, I'll try it. There is another option, but it does not work for all formats. ;; A3x3 (420x891) ((and (<= SideS 425) (<= SideL 896)) (vla-put-CanonicalMediaName Layout "UserDefinedMetric (891.00 x 420.00мм)"))
  20. @Nikon The "COND" statement will stop as soon as it meets the criteria for the square area range, so if something else meets the that area range before getting to your desired state, it will never get there. You will have to do a different comparison that is unique to the criteria. Maybe to change the criteria for the conditional statement to comparing the Length and width specifically, rather than with the area, or a combination of the area and the width, or something else, like a unique layer or color. Maybe something like this instead (you can alter to suit the fudge factor for the viewport height and width): (cond ((and (> 290.0 ViewPortHeight 300.0) (> 600.0 ViewPortWidth 650.0));; Compare the width and height directly! (vla-put-ConfigName Layout "DWG To PDF.pc3") (vla-put-CanonicalMediaName Layout "UserDefinedMetric (297.00 x 630.00мм)") ) ((and (> 290.0 ViewPortHeight 300.0) (> 835.0 ViewPortWidth 845.0)) (vla-put-ConfigName Layout "DWG To PDF.pc3") (vla-put-CanonicalMediaName Layout "UserDefinedMetric (297.00 x 841.0мм)") ) ... ;; Repeat for all desired sizes ) NOTE: You would also have to do both a landscape version and a Portrait version if you need both. Perhaps a bit more sophisticated comparison: (cond ((or (and (> 290.0 ViewPortHeight 300.0) (> 600.0 ViewPortWidth 650.0)) (and (> 290.0 ViewPortWidth 300.0) (> 600.0 ViewPortHeight 650.0)) ) (vla-put-ConfigName Layout "DWG To PDF.pc3") (vla-put-CanonicalMediaName Layout "UserDefinedMetric (297.00 x 630.00мм)") ) ((or (and (> 290.0 ViewPortHeight 300.0) (> 835.0 ViewPortWidth 845.0)) (and (> 290.0 ViewPortWidth 300.0) (> 835.0 ViewPortHeight 845.0)) ) (vla-put-ConfigName Layout "DWG To PDF.pc3") (vla-put-CanonicalMediaName Layout "UserDefinedMetric (297.00 x 841.0мм)") ) ... ; Repeat for all desired sizes (T (vla-put-ConfigName Layout "None")) ; Default to No plotter for non-standard sizes ) NOTE: I can't test this directly without a "real world" sample drawing to compare, along with your pc3 file, so I'm trying to give you the knowledge to do it yourself, which is preferrable anyway.
  21. Artem
    Segments of polylines
    Hi, you did a fantastic job. The few options is realy good, and handy to use. I have only 1 question left - can that tool not create a clone of polyline, but edit current? To transform polyline with all parameters and e.t.c. If you will be doing that, its nessesary obly for lw_orth_2 (2nd version) it works better for cases i have faced. Does it even possible to transform line like it doing it not with clone? Thanks you very much already!!!
  22. (setq ss (ssget "X" '((-4 . "<OR") (62 . 40) (62 . 33) (62 . 25) (62 . 179) (-4 . "OR>")))) https://www.lee-mac.com/ssget.html#logical
  23. just FYI for @ScottMC That while loop is running 1000's times a sec and is intended to only pause waiting for user input to be completed. Can be simplified to this. (while (> (getvar 'CMDACTIVE) 0) (Command "\\") ) Another option would be to use grread and grdraw to show a visualization of a circle but not actually add it to the drawing (in red). Tho I found out it can only draws lines and you need to trick it to make segmented circles. will post something later tonight. -- Edit This doesn't have any command so doesn't need above code or to toggle CMDECHO. ;;----------------------------------------------------------------------;; ;; 2 Point Circle ;; grcircle function from https://lee-mac.com/circletangents.html (defun c:C2 (/ *error* cr P1 P2 P3 rad ev oe os doc) (defun *error* (msg) (setvar 'OSMODE os) (vla-endundomark doc) (princ (strcat "\n" msg)) ) (defun grcircle (cen rad / ang) (setq ang 0.0) (repeat ctan:res (grdraw (polar P3 ang rad) (polar P3 (setq ang (+ ang ctan:inc)) rad) 1) ) ) (setq doc (vla-get-ActiveDocument (vlax-get-acad-object))) (vla-startundomark doc) (setq ctan:res 40 ;; arc resolution (int > 0) ctan:2pi (+ pi pi) ctan:inc (/ ctan:2pi ctan:res) ) (setq os (getvar 'OSMODE)) (while (and (setvar 'OSMODE (boole 7 os 512)) (setq P1 (getpoint "\nSpecify 1st Point of 2P.Circle: ")) ) (setvar 'osmode os) (prompt "\nSpecify 2nd Point: ") (while (progn (setq ev (grread t 13 0)) (= (car ev) 5) ) (redraw) (setq P2 (cadr ev)) (setq rad (/ (distance P1 P2) 2.0)) (setq P3 (Polar P1 (angle P1 P2) rad)) (grcircle P3 rad) ) (if (= (car ev) 3) (progn (setq P2 (cadr ev)) (setq rad (/ (distance P1 P2) 2.0)) (setq P3 (polar P1 (angle P1 P2) rad)) (setq cr rad) (redraw) (princ (strcat "\n Coordinates: " (setq C2:pp (strcat (rtos (car P3) 2 4) "," (rtos (cadr P3) 2 4) "," (rtos (caddr P3) 2 4))) "\n Diameter: " (rtos (* cr 2) 2 4) " | Radius: " (rtos cr 2 4))) (entmakex (list '(0 . "POINT") (cons 10 P3))) (entmakex (list '(0 . "POINT") (cons 10 P2))) (entmakex (list '(0 . "CIRCLE") (cons 10 P3) (cons 40 cr) (cons 8 (getvar "CLAYER")))) ) ) ) (setvar 'cmdecho 1) (vla-endundomark doc) (princ) )
  24. I use polar tracking and osnaps in AutoCAD. Looks like nanoCAD has similar... Precision tools. Object Snap tracking mode. Download CAD software
  25. take a look at this : https://help.autodesk.com/view/ACD/2025/ENU/?guid=GUID-DD9B3216-A533-4D47-95D8-7585F738FD75
  26. Thanks PK for finding that. Something I've never found or got direct connection to error but now will have that as an understood rule. Will certainly look for that in my troubleshooting.
  27. sinergy2020
    Not sure I totally understand this last .....is there a listing of osmodes somewhere? When I type osmode I get (by default) 549 ... what does it mean??? And, can I write lisp code in nanocad?
  28. Non-standard formats are often required for drawings.
  29. I don't understand why your using non standard size sheets ? A2 can be shown as 4 A4's same with 3 to be used but 4th blank. A A4x2 is a A3, the internal linework would be on a non plot layer. You could have 4 viewports shown.
