  2. It's called purchasing the previously posted Drawing Tree | AutoCAD | Autodesk App Store. It has a free trial. Other than that, just need to ask around and see if someone will make you something for free. What permissions do you have for installing software?
  3. I'll see what this week brings for extra playtime.
  4. Today
  5. This weekend I spent some time alone with CrazyHorseSubTangentsArc. I want to share some snapshots of this memorable encounter. Beautiful! But I guess I should be able to show some even better images soon.
  6. Likewise, I have a couple of LISPs, "SetUpWorkSpace" that does all the basic settings I like (screen colours and stuff), also turns the ribbon off - runs it at a new CAD version and also "NewDrawing" runs at each drawing opened that also turns off the ribbon if I've turned it on by mistake (also resets snaps, grid, linetypes and so on for the new drawing from what I had last). Not a fan of ribbons and I don't think they are as popular - lots of software I see has a more classic toolbar or back to menus now
  7. Interesting site but isn't there any system for people like me who are not familiar with coding, for example a system that graphically does what you are looking for?
  8. jim78b
    Detail circle in MS
    Hello Slw i test your lisp today and works !!! seem all ok. thanks a lot!
  9. agree , ribbons itself are nice & pretty and so , but half of it I have never used in my life nor will I so the classic menu will do nicely thank you , easy to change , clean and simple. So every new AutoCad version : ribbon off , menuload , rlxmenu... done.
  10. masterfal
    Just a funny / basic toolbar
    i'm also not a fan of ribbon. don't really use buttons either. i use the command line for pretty much everything. ribbon uses too much space and have always found it unnecessary. having it closed ensures i've got maximised screen space for my drawings
  11. Yesterday
  12. Win10 16gigaram acad2025 Nvidia quadro p2000 Intel core i7
  13. Speaking of installing permissions, what can you download and install at your workplace? Also what are your computer specifications, graphics card, etc. and most important your Windows version and AutoCAD version?
  14. That only works if they can install programs at their workplace. And it would still be similar to Jeffery P. Sanders program, with a prettier Dialog Box. Python would be much better for the OP, even better would be a .NET solution.
  15. I moved your thread to the .NET, ObjectARX & VBA Forum in case some one feels like making a program for FREE.
  16. You might want to check out OpenDCL, it has pallets, block preview … all the tools you would need create a block + group manager
  17. Yes like this. But i don't know python and programming. It Is cool of you can select in the gui the blocks ...create ones etc
  18. You want to create a GUI? There’s a sample in python creating a palette with block names and preview https://github.com/CEXT-Dan/PyRx?tab=readme-ov-file#features you’d have to roll it yourself. There’s also opendcl if you feel more comfortable with lisp
  19. Last week
  20. jim78b
    Detail circle in MS
    Monday i Will test It and i tell you .thanks a lot
  21. SLW210
    Detail circle in MS
    Did you get a chance to see how this was working for you?
  22. You asked in the AutoLISP, Visual LISP & DCL Forum, something like what @mhupp posted is the best solution with FREE LISP, IMO. You need to look at asking this in some .NET forums, though not sure the FREE will happen.
  23. I just use -. 1'2-3/4 will work, just a fraction all you need is 3/4, no need for 0'0-3/4, for just fractional inches just 2-3/4 works. The 0'-0 1/16" was referencing a selection example in the precision for Architectural Units.
  24. AutoCAD will correctly interpret fractions if the type of UNITS is set to Architectural.
  25. Great thank you . i am planning to add into the startup folder and give a go but got distracted today .
  26. Yes i don't mean lisp. I ask if there was something way to do this free .
  27. when there is no space ! then how autocad identifies fractional part ?
  28. When you print/plot to PDF make sure that the setting to print with transparency is turned on.
  29. Just get that one then. Drawing Tree | AutoCAD | Autodesk App Store I am pretty sure, that is not a LISP.
