Copying a Value into the Clipboard without using Active-X so it can work on LT
Hi @BIGAL I have tried the getpropertyvalue and it works in LT! Which is good news as that means the lisp can be reduced. @Saxlle that could be a solution, but the whole point is to automate it as much as possible. I had a think about it before and the most effective way for out team is to just type print me and then the drawing name gets generated and saved on the clipboard and then when they setup the plot settings they can paste the name in the dialogbox. So pausing to copy the name, will add extra steps which I am trying to reduce. @Steven P that would be the final step making sure that it is completely automated. But fearing some might not be comfortable with it yet, I just want to slowly introduce these little automations. With your suggestion, how does it work in terms of where to save the pdf file? -
ILoveMadoka started following Drag Units?
When I am making a new component and drag, the dimensions are in 128ths... My units are set to the nearest 1/4" (so I thought) Where do I set my units such that dragging constrains to the nearest 1/4"
SuperBoundary • The superior boundary creation tool
SLW210 commented on Debalance's file in Programs and Scripts
- 2 comments
Penn Foster AutoCAD Applications-Construction assistance (Residential House Project)
ReMark replied to TimC's topic in Student Project Questions
Try using a scale factor of 60. That equates to an architectural scale of 1"=50". -
SLW210 replied to TimC's topic in Student Project Questions
Almost every project should be on here AFAIK. Student Project Questions - AutoCAD Forums Here is the Oleson Village... Penn Foster Student Suffering with Oleson Village Map!!! - Student Project Questions - AutoCAD Forums - Today
OK folks, new guy here. So far in my research it sounds like Penn Foster should have their own dedicated forum. I was wondering if there was somewhere projects are posted so we can compare to be sure we've done stuff correctly? I submitted my "Oleson Housing Development" project and received a 15% because "the scale was off". Needless to say, I was less than impressed. I've sent weeks working on this project for the third semester between working overtime and sleep so I want to be sure I don't get a grade like that again. Thank you in advance for any help
TimC joined the community
Alternative option. You can use a dynamic block with a selection of different states. You can change the block scale. Breakline.dwg
Akash_SAK replied to EVGA Buzzer's topic in AutoCAD Beginners' Area
Thankyou Bigal for the information and may i know that where would be the autocad Lisp package file is available on PC ? -
@bigal, Reminds me of the days of HP9830, used to work on preliminay studies in the James Bay area. I would start calculating a long polygon in geodetic coordinates then go in the tent where we had a pool table and shoot two racks. Go back to the office tent still had to wait some. The hp9830 had but 8k core memory and a cassette tape. So the need for speed depends on the situation. For the basic A* it's all about it and the hack proposed by @GLAVCVS is totally worth it. The polygon making not so much, but I tend to be biased in favor of vanilla autolisp. -
lowebowski commented on Debalance's file in Programs and Scripts
Does anyone know how to get a hold of the developer of this app? It does exactly what I want, but am unable to purchase a license through the app as the link no longer works and I have had no luck contacting the developer from their company page. Their company page at www.debalance.com also pops up a warning that it may not be safe upon opening, and is not a secure site. Do the mods at CADTutor have any way to contact the author? It seems he used to be quite active on the boards here. Anyways, great little plugin, it just seems too bad there is no way to buy a license!- 2 comments
BIGAL replied to heschr's topic in AutoLISP, Visual LISP & DCL
We talk a lot about speed but does it matter, if it take seconds or a minute, a task I worked on could take up to 3 hours manually it takes 2 minutes now. I improved the speed 3 times by recoding. Yes if have thousands of lines go get a coffee. still faster than having a go manually. I guess what I am saying are we talking seconds, minutes or hours ? 13 seconds for 5000, I would call that fantastic. If worried about time add a progress bar it's a Acet function. The task above started at like 25 minutes to do, so 2 minutes as final version is considered acceptable by me. Yes talking thousands of changes. -
Like @Steven P my Autoload.lsp has around 35 defuns in it plus some setvar's and uses the Appload add to Startup suite, Acad or Bricscad works.
ronjonp started following Breakline in lines...help
Here's an old one CAB wrote. dz.lsp
As @Steven P suggested you can have as many plot predefined settings as you want. Did you test the "getpropertyvalue" code in your LT as per my request above. I don't have LT so can not test. -
leonucadom started following Breakline in lines...help
hello: Does anyone have something that does this or something similar? Break the lines and draw those symbols Any comments are welcome, thank you.
Text disappears behind viewport
BIGAL replied to Samr1979's topic in AutoCAD 3D Modelling & Rendering
Admin posted twice. -
BIGAL replied to Samr1979's topic in AutoCAD 2D Drafting, Object Properties & Interface
When I plotted the layout to PDF the table came out Ok. Tried a couple of things like draworder etc but they had no effect. Ok a way around it, copy the table to clipboard and paste in MODEL, go back to layout make a new viewport in layout set UCS W PLAN zoom in on table etc and set a suitable scale, shrink the viewport close to the table move the viewport over the two other viewports. I am sure if I played more could work out viewport scale so correct text height. Ps set viewport outline to "No Plot". -
I don't know but I used "Benchmark.lsp | © 2005 Michael Puckett " to do the testing. Logically yours has to be slower because you run through the list so many more time either with apply (function append plus a mapcar for each element of the list to to Float the coordinates. Bear in mind it will only matter if the path found has a lot of coordinates. ymg -
I use that code to create 3D polylines because it’s shorter, although I know that 'apply' slows it down a bit. However, I didn’t think it would be as much as you say. I was just about to reply with that. But at the last moment, I managed to find a bit of time — and curiosity — to run a test. And my results are somewhat different from what you describe. I should mention that my test was carried out in AutoCAD 2002, using a list of 93 points previously stored in the variable 'plst'. The code I used for this test is attached below. (defun Original_f3Dpol (pts / tmp f3Dpol) (defun f3Dpol (pts / ep ll la e) (setq ep (if (= 1 (getvar (quote cvport))) (vla-get-PaperSpace (vla-get-activedocument (vlax-get-acad-object))) (vla-get-modelSpace (vla-get-activedocument (vlax-get-acad-object)))) ll (apply (function append) pts) la (vlax-safearray-fill (vlax-make-safearray vlax-vbDouble (cons 0 (1- (length ll)))) (mapcar (function float) ll)) e (vla-Add3DPoly ep la) ) (vla-put-Color e 1) (vla-put-Layer e "0") (vla-put-Lineweight e 0.4) ) (setq tmp (car (_vl-times))) (repeat 5000 (f3Dpol plst) (entdel (entlast)) ) (prompt "\nOriginal \'f3Dpol\' Elapsed time (5000 iterations): ") (princ (rtos (/ (- (car (_vl-times)) tmp) 1000.0) 2 50)) (prompt " seconds.") (princ) ) (defun ymg_f3Dpol (plst / tmp f3Dpol) (defun f3Dpol (plst / sa i p element sa obj ) (setq sa (vlax-make-safearray vlax-vbDouble (cons 0 (1- (* (length plst) 3))))) (setq i 0) (foreach p plst (foreach element p (vlax-safearray-put-element sa i (float element)) (setq i (1+ i)) ) ) (setq obj (vla-Add3DPoly (vla-get-modelSpace (vla-get-activedocument (vlax-get-acad-object))) sa)) (vla-put-Color obj 1) (vla-put-lineweight obj 0.4) ) (setq tmp (car (_vl-times))) (repeat 5000 (Y3Dpol plst) (entdel (entlast)) ) (prompt "\nModified @ymg3 \'f3Dpol\' Elapsed time (5000 iterations): ") (princ (rtos (/ (- (car (_vl-times)) tmp) 1000.0) 2 50)) (prompt " seconds.") (princ) ) (defun ymg_mk_3dp (lst / tmp mk_3dp) (defun mk_3dp (lst / vtx) (if (and (> (length lst) 1)) (progn (entmakex (list '(0 . "POLYLINE") '(10 0. 0. 0.) (cons 8 "0") (cons 62 1) (cons 370 40) '(70 . 8) ) ) (foreach vtx lst (entmakex (list '(0 . "VERTEX") (cons 10 vtx) '(70 . 32) ) ) ) (cdr (assoc 330 (entget (entmakex '((0 . "SEQEND")))))) ) ) ) (setq tmp (car (_vl-times))) (repeat 5000 (mk_3dp plst) (entdel (entlast)) ) (prompt "\n\'nmk_3dp\' Elapsed time (5000 iterations) : ") (princ (rtos (/ (- (car (_vl-times)) tmp) 1000.0) 2 50)) (prompt " seconds.") (princ) ) The execution times for each version can be seen in the following image: Your modification of 'f3DPol' actually seems to be even slower. And 'mk_3dp' is only about 20% faster. What's going on? -
Steven P started following Copying a Value into the Clipboard without using Active-X so it can work on LT and Setting HPANNOTATIVE
Create a LISP file - a blank notepad file if you want, saved as "MyStartUpLisps.LSP" remembering to change the file type from *.txt to *.* (or whatever name you want). Save this in a 'Trusted location', or somewhere else - I tend to use my personal company space, won't change if AutoCAD changes where trusted Locations are or when my laptop is replaced. If using somewhere other than a trusted location go to AppLoad - StartUp Suit Contents and add the file to start up suit. There in the file anything you want to control at start up, these don't need to be contained in a function, just the commands and when the file loads they are read and applied Add: (setvar 'HPANNOTATIVE 1) I might also add in my preferred snaps and other variables, open a drawing and set snaps to on and ortho
Generally if I am plotting it is much quicker to get a LISP to do all the 'hard' work going through the dialogue box - more so with PDFs where it wants you to select folders to plot to. If these are all standard 90% of the time like BigAl says, go straight to plot. Might be that the most efficient way would be 4 functions to plot to PDF: 'PlotPdf' 'PlotPdfTr' - Transparency 'PlotPdfLW' - Lineweight 'PlotPdfTrLw' - Transparency and lineweight, (or 5th one PlotPDFLwTr to cover it going the options entered in reverse) All call the same basic function passing the required data for example: (defun c:plotpdf ( / )(plotPDF (list 0 0))) ;; List: TR, LW (defun c:plotpdfTr ( / )(plotPDF (list 1 0))) ;; List: TR, LW (defun c:plotpdfLw ( / )(plotPDF (list 0 1))) ;; List: TR, LW (defun c:plotpdfTrLW ( / )(plotPDF (list 1 1))) ;; List: TR, LW (defun c:plotpdfLWTr ( / )(plotPDF (list 1 1))) ;; List: TR, LW (defun PlotPDF ( MyControls / .....) .... ... (if (= (nth 0 MyControls) 1) (setq DoTransparency "Yes")) ... (if (= (nth 1 MyControls) 1) (setq DoLineWeight "Yes")) .... ) I use a similar thing: PlotA0, PlotA1.... for different papersizes, plotpdfmsc (plot PDF Mono Save Close) as examples, easy to remember (can do the 'code' part of the functions backwards too, eg, PLotPDFCS - Close Shave) I tend to pass the controls as a list so that if you want to add more functions later you only need to change the main function and anything new afterwards, for example c:plotpdfPr where Pr might be 'show preview' and that list might be (plotPDF (list 0 0 1)) noting that shorter lists will just return a 'nil' in the if statements / conds so have no effect -
Mondo started following Setting HPANNOTATIVE
Ideas on how to set hpannotative to 1 at drawing opening? I have done multiple startups setting the variable to 1 in the acaddoc.lsp to no avail.
SKID.dwg
lowebowski reviewed Debalance's file in Programs and Scripts
Great little app, and does exactly what I am looking for but I am unable to purchase a license. The in app purchase button takes the user to a Malware filled popup site, and visiting https://debalance.com/ or www.superboundary.com likewise popup a security warning and ask permission to allow notifications that if allowed spams the computer with pop ads for McAfe antivirus software. Is there any other way to purchase this? I have tried sending an email through their contact form with no luck.- 2 comments
Samr1979 started following Text disappears behind viewport
Samr1979 posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Hope someone can help me with this. When I have a Viewport with the object shown as shaded any text I type in the layout tab inside that viewport disappears behind the viewport. In the drawing I attached you can see a schedule behind the viewports. I have to have those objects as shaded. Is there anyway to have the text not disappear if its in the viewport area? SKID.dwg
