2 Screenshots
About This File
AutoCAD users often have to deal with the BOUNDARY (BPOLY) command, which allows creating boundaries (mostly enclosed polylines) from existing objects forming an enclosed area around the point specified. Unfortunately, its performance as well as the quality and the accuracy of the boundaries (contours) created when run in complex drawings leaves much to be desired. To eliminate these common drawbacks of the standard BOUNDARY command, a project called "SuperBoundary" was implemented.
While BOUNDARY command generates simple contours quite efficiently in relatively simple drawings with a small number of objects on screen, SuperBoundary is intended to provide the user with comfortable workflow in drawings of any complexity. In other words, SuperBoundary is the utility based on the BOUNDARY concept supplemented by super-speed and some super-features.
Key features:
  • High performance. A powerful program engine allows analyzing and generating thousands of boundaries in seconds.
  • High accuracy. When generating a boundary, all elements larger than the specified tolerance factor are considered.
  • The possibility to create boundaries in areas having significant gaps between adjacent objects.
  • The possibility to quickly detect and generate all the enclosed areas in the selected drawing or its part.
  • Easy and accurate external outlines generation in complex drawings.
  • Polylines generation from spline- and ellipse-based boundaries using piecewise-linear approximation
  • Flexible adjustment of the boundaries generated. These are width, color and layer.
  • Simple and convenient installation with classic installer.
List of commands:
  • _SBND - launch the app in classic mode
  • _SBND_PICK - for quick usage in "pick point" mode
  • _SBND_ALL - for quick usage in "build all" mode
  • _SBND_CONFIG - for export / import current settings data as an external INI file
Edited by Debalance
What's New in Version 2.5.36.0   See changelog
Released
Added support AutoCAD 2025
  • Like 2
User Feedback
  • This will not be shown to other users.
  • Unfortunately, your content contains terms that we do not allow. Please edit your content to remove the highlighted words below.
    Add a review...
효천순천
아주 좋은 프로그램입니다 저는 이프로그램의 라이센스를구입하려하는데 방법을모르겠네요 알려주세요
mcweb
   2 of 2 members found this review helpful 2 / 2 members
This is an awesome application. The problem is I need another license. I have purchased a couple in the past and need another for a new computer. I can't get through the checkout without an error - "We're sorry, your session has expired. Please go back to the vendor website and place your order again."
I have tried dozens of times, different browsers, devices, etc. Tried contacting debalance.com, 2Checkout says contact debalance, tried emailing Alexey. Can't get any help.
  • Like 2
Jaclyn Adriatico
This add-in is SO helpful. Thank you to those who contributed to this. This saves me so much time when I have to hatch stormwater drainage areas! Thank you!!
Response from the author:
Happy to help. Thank you for your positive feedback.
  • Like 2
