Showing results for tags 'acad 2011'.
  1. Hi All, I am having a problem with AutoCAD 2011. Here's the problem step by step: 1. Select a line 2. Right click and select polyline 3. Select width Here's where the problem arises. ACAD used to prompt for a width now it runs the PEDIT command and asks me to select a line and then gives the usual pedit commands via the command line. Not sure what has happened here but would appreciate any advice on how to reset this.
  2. Hi all I have this reoccurring issue with ACAD. It appears randomly and whenever we upgrade to newer versions of ACAD also. Now that we are upgrading to 2012 it has reared its ugly head again. Heres the issue; when I go to publish a set of drawings from sheet set manager it refuses to do so. It does not even show my page setups. So to get around this i will plot the drawings individually or create a DWF and plot them that way. Another way is to delete all the sheets within the sheet set and add them all again which fixes it, but its time consuming and quiet annoying having to do this all the time. Anyone come across this issue themselves and what can be done to stop it?? Cheers! p.s - I am currently working on 2011 but will be upgrading to 2012 asap, would like to solve this first though. Any help appreciated
