Showing results for tags 'bending linetype'.
Hi All, Generally for drawing cable, I use a p-line (generally curve or spline fit) and change my global width to the diameter of that cable. This is usually exactly what I need to show. HOWEVER, when a complicated drawing arises with several different types of cable in one particular area, I have to differentiate the cables by altering their appearance for ease of tracing that wire in a black and white printout. Before, I would offset the polyline to either side, close in the ends and fill with a hatch. This works ok, but is time consuming and the hatch doesn't rotate relative to the line. I tried to be clever with the express tools linetype creator, but autocad won out. See Pic for my attempt. It looks ok zoomed out (except for the dots in the center of the line, which need to go). However, when zoomed in, the curve is actually an assembly of straight segments that overlap on the inside and don't meet up on the outside of the curve. Can someone point me in the right direction for instructions, tips, pointers for creating "bending" linetypes? I've already accepted that I'm probably going to have to somewhat learn lisp... hit me with it. Thanks! Kyle
- 7 replies
- linetype
- bending linetype
