Showing results for tags 'change arrow head'.
  1. I have a legacy drawing where someone has changed some of the leader arrows to dots but they are using the wrong symbol and wrong size. I can select the leader in question and change the properties of these two items in the Properties dialog. Can this be accomplished via lisp? (Command "xxxx" "Dot") ; Or (Setvar "xxxx" "Dot") (Command "dimasz" .09375) Properties says it is a Leader I really would prefer to not make a whole new Style for these items but there are so many that need to be changed scattered across the many sheets, that it would be a huge time saver with a small routine.. I don't see it here.. (setq XD (entget (car (entsel)))) * List in AutoLISP format *((-1 . <Entity name: 29f052416f0>) (0 . LEADER) (330 . <Entity name: 29ed564db80>) (5 . C0C37) (100 . AcDbEntity) (67 . 1) (410 . SH65H) (8 . Text) (100 . AcDbLeader) (3 . STANDARD) (71 . 1) (72 . 0) (73 . 3) (74 . 1) (75 . 0) (40 . 0.0) (41 . 0.0) (76 . 3) (10 4.33416 8.92996 0.0) (10 4.61755 10.2826 0.0) (10 4.73268 10.2826 0.0) (340 . <Entity name: 0>) (211 1.0 0.0 0.0) (210 0.0 0.0 1.0) (212 0.0 0.0 0.0) (213 0.0 0.0 0.0)) Variable name is ENT or here.. (entget (car (entsel)) '("ACAD")) Select object: ((-1 . <Entity name: 29f052416f0>) (0 . "LEADER") (330 . <Entity name: 29ed564db80>) (5 . "C0C37") (100 . "AcDbEntity") (67 . 1) (410 . "SH65H") (8 . "Text") (100 . "AcDbLeader") (3 . "STANDARD") (71 . 1) (72 . 0) (73 . 3) (74 . 1) (75 . 0) (40 . 0.0) (41 . 0.0) (76 . 3) (10 4.33416 8.92996 0.0) (10 4.61755 10.2826 0.0) (10 4.73268 10.2826 0.0) (340 . <Entity name: 0>) (211 1.0 0.0 0.0) (210 0.0 0.0 1.0) (212 0.0 0.0 0.0) (213 0.0 0.0 0.0) (-3 ("ACAD" (1000 . "DSTYLE") (1002 . "{") (1070 . 41) (1040 . 0.09375) (1070 . 40) (1040 . 1.0) (1070 . 49) (1040 . 0.1875) (1070 . 341) (1005 . "5AE25") (1070 . 345) (1005 . "12") (1070 . 346) (1005 . "12") (1070 . 347) (1005 . "12") (1002 . "}")))) Arrow size? (1040 . 0.1875) Do you use (entmod) to change?? I've looked here for some insight (It is not obvious to me..) Autocad 2018 DXF Group Codes This is beyond me I'm lost... (I am trying though) Help please?
