Showing results for tags 'change default text layer'.
  1. Hey, I am trying to create new drawing templates for 3 different professional disciplines that will be working together on a project using National CAD Standards. I have the layers, text styles, and dim styles created that will be used, and it's all saved to a .dwt file. The issue is that when I want to add text or a dimension, it inserts on a specific (rogue) layer and you have to match properties or manually change it to put it on the correct layer. I need to know how to change that default so that it inserts on the correct layer FIRST. The current default layer is only accepted by th
