Showing results for tags 'copy field'.
  1. Hello, I am looking for a .lsp that will allow me to insert a titleblock of a different size and run a command on the existing titleblock and click on the new titleblock and it will retain all the same information (even with text fields) and copy over the information into the new titleblock without having to fill out the new titleblock. Our titleblocks use mostly fields but the project name, address, drawing number and drawing name have just regular attribute text objects. This would be a huge time saver if I have to take something that was originally on a 22x34 titleblock and resize the viewport and insert a new 8-1/2x11 titleblock quickly without having to re-enter all of the information. This would be a tremendous time saver! Thank you in advance
