Showing results for tags 'repeat last input'.
  1. Hi All, I'm having a little trouble figuring out how to center my text in the middle of the rectangle after its created. Here's what I have so far, it works but it waits for me to place it. Also I do a lot of panels that are the same size so I also want the lisp to remember the last input so I can continue to use it until I hit escape or return. If I could get some help I would appreciate it. (defun C:CRP7() (setq cmdold (getvar "cmdecho")) (setvar "cmdecho" 0) (setq PL (getstring "Enter a Panel Label :")) (setq PA (getpoint "Select Panel Area :")) (command "-boundary" "Advanced" "Island" "No" "Nearest" "" pa "") (command "_.change" (entlast) "" "_p" "_la" "Router - Green - V groove" "") (setq ts(getvar "textsize")) (setq tsty(getvar "textstyle")) (if(= 0 (cdr(assoc 40(tblsearch "style" tsty)))) (progn (command "text" "Justify" "Center" pa ts 0 PL))) (setvar "cmdecho" cmdold) (princ) ) Thanks Brian
