Showing results for tags 'return_value'.
Checking Rectangle height with if Statement not working
Brok posted a topic in AutoLISP, Visual LISP & DCL
Hi, I want to check for the width and height of a Rectangle. I got this code (defun getRect () (if (setq rec (ssget "_X" (list '(0 . "LWPOLYLINE") '(8 . "LAYOUT") '(90 . 4) (cons 410 (getvar "ctab")) ))) (progn (setq e (ssname rec 0)) (setq coords (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget e)))) (setq height (distance (car coords) (nth 3 coords))) (setq width (distance (car coords) (nth 1 coords))) (if (= height 594.0) T (princ height) ) ) ) (princ) ) If I check for the Width it works and it returns T But If I try to get the height it returns false and prints 594.0 Why does this not return True as well?- 9 replies
- if function
- rectangle
Make a loop return the result for each time its body is obeyed
dak posted a topic in AutoLISP, Visual LISP & DCL
Hi everyone, Just trying to pass a list of points to a "pline" command. The problem is num of points is initially unknown, though being calculated within a routine. The following code (as smth to start with) evolves known num of points. (defun c:pltest6 () (setq pts (list '(0 0) '(0 10) '(10 10) '(10 20) '(20 20) '(20 30) '(30 30))) (setq ptqty 7) (setq ptnum 0) (command "pline" (car pts) (pt_retr pts) (pt_retr pts) (pt_retr pts) (pt_retr pts) (pt_retr pts) (pt_retr pts) "" ) ) (defun pt_retr (lst) (setq ptnum (1+ ptnum)) (repeat ptnum (setq lst (cdr lst)) ) (setq pt (car lst)) ) Repeat/foreach don't do, 'cause they return the value of the last iteration.. Now my Q is, is it possible to modify the code above to use loop instead of repeat one and the same line (moreover, unknown number of times ), OR some other approach would rather fix the task? Thank you in advance, Dmitro
