Showing results for tags 'solidworks api'.
More search options
  1. nagendra vr
    Macros in solidworks (Please Help)
    hello EveryoneI wanted to save my sheet metal parts as flat pattern into Dxf file. So I created a macro for this.I have more than 50 files and wanted to run this macro on every file.I tried using Run custom task under task scheduler but its asking for exe file as program Path.Please help me with this problem and suggest an easier way to do the same job.Thanks
  2. Check out this new Engineering & CAD automation service. AutoEngr.com. Our services include CAD API programming and parametric modeling services for zero up-front costs. We create custom automation to match you needs, then run it whenever you need to complete the task. It's a hassle free low cost solution to automation. Request a custom service or use an existing off-the-shelf service today!
  3. hayyagahoy
    SolidWorks API - Copy part name text
    Hello, I am fairly new to SolidWorks and even newer to scripting. Our design department recently came to me wondering if there was a way to create a macro that when they selected a part in the feature tree on the left hand side, and pushed the macro hotkey, if the name could be copied to the clipboard to be pasted in other programs. We have various documents that they need the name of, and right now they are right clicking on the part name and selecting properties, and getting to the name that way to copy it. It would be a lot easier for them if they could just do a quick key similar to ctrl+c to copy it. It would be even better if they could select multiple parts at a time, and have it copy each part name on a different line so when you pasted it, it would look similar to: part1 part2 part3 If anyone has anyone could help me out it would be very much appreciated. Even if all you can give me is pointers or suggestions. Thanks very much!!
