OK - that worked. Having never really worked with shape files before I wasn't sure how all the associations worked. When I select the style name (in the Text Style" editor) that created the need for an error dialog box - I can eliminate my problem two ways. I can either uncheck the "Use Big Font" dialog box and eliminate the "Font Style" requirement, or I can check the "Use Big Font" and reassociate the "Font Style" to bigfont.shx.
So am I correct then thinking that the "fake" file I could create would be called mpspcbar.shx?
  • Replies 22
  • TroutKing
    10
  • SLW210
    7
  • Tiger
    2
  • chulse
    1
Posted Images
Right on! Thank you for all your help. I mighta actually even learned something today! lol
  • 2 years later...
I had this same issue for some time. When I typed int _Fontalt in the command prompt, I was given the following:
Enter new value for FONTALT, or . for none :
Giving the impression that fontalt was turned on and anything that I didn't have would automatically resort to "simplex". Well, I typed in simplex and hit enter anyways...low and behold, I have not had the problem since. I think if you're having this issue, you can type _fontalt, enter, simplex, enter and you'll be set. Worked for me :P
~Niko
