Once you mastered all of them we will designate you as our system variables guru for LT. Then you can answer all the related questions while we go fishing.
  • Replies 23
  • ReMark
    7
  • GE13579
    7
  • MisterJingles
    6
  • Tiger
    2
Popular Days
I was recently told that ATTSYNC wasn't available on LT.
I don't expect that many off us know more than a few commands so don't be distracted by the number off them. If you find yourself hitting the same button often, press F2 to see what command AutoCAD used. This can be typed directly on the command line for a far more rapid throughput than pressing buttons will give you. All commands have a one or two letter alias that can be used instead and you can create your own if you don't like the supplied ones.
ReMark - Id be honoured. When its your shift Ill pop out for a spot of snake collecting, my preferred pastime.
dbroada - You are correct, ATTSYNC is not available on LT. Point taken RE commands, Ill start with the ones Ill be using often and see how it grows from there.
Regards
Thanks. I prefer my snake braised on an open fire. Pass the salt please.
