OK.
As I say, if AfraLISP doesn't help you, the Visual LISP Editor has got some indispensible help files that explain a great deal.
You can look up any function you are unsure of. :wink:
  • Replies 24
  • Lee Mac
    13
  • MarcoW
    10
  • David Bethel
    1
  • alanjt
    1
Posted Images
Aarrgghh.. I'm making a mistake and I can't locate where that is. I tried hard but im too stu.. no, too novice :-)
Please look to the code below, when entering L for left side it works, when entering r or enter, it draws only 1 circle wicht doesn't come in the ss (with ssadd).
What am I doing wrong? I am convinced the parenthesis are good... but who am I...
Code:
(defun c:box1  (/ *error* vlst ovar ss len leng dist pt1 pt2 pt3 pt4 pt5 pt6)
 ; Error Handler
 (defun *error*  (msg)
   (if ovar
     (mapcar 'setvar vlst ovar)) ; If old variables are stored, reset them.
   (if (not (member msg '("Function cancelled" "quit / exit abort")))
 ; If the msg isn't one in this list
     (princ (strcat "\n<!> Error: " msg " <!>"))) ; then print it.
   (princ))
 (setq vlst '("CMDECHO" "OSMODE" "ORTHOMODE")
       ovar (mapcar 'getvar vlst)
       ss (ssadd)  ; Create an Empty Selection Set
 ; Define Functions and Localise Variables
       len (getdist "\nLength1:  ")
       leng (getdist "\nLength2:  ")
 ; I'd be more inclined to use "getdist"
 ; so that the user can pick the distance.
       dist (getdist "\nDistance:  ")
       dia (getreal "\nDiameter: ")
       pt1 (getpoint "\nInsertion:  ")
       pt2 (polar pt1 0 dist)
;;;                    pt1 +-----+
;;;                             pt2
       pt3 (polar pt2 (/ pi 2) (* len 0.5))
;;;                             pt3
;;;                    pt1 +-----+
;;;                             pt2
       pt4 (polar pt3 0 leng)
;;;                             pt3   pt4
;;;                    pt1 +-----+
;;;                             pt2
       pt5 (polar pt4 (* pi 1.5) len)
;;;                             pt3   pt4
;;;                    pt1 +-----+     |
;;;                             pt2    |
;;;                                   pt5
       pt6 (polar pt5 pi leng)
;;;                             pt3   pt4
;;;                    pt1 +-----+     |
;;;                             pt2    |
;;;                             pt6   pt5
;; calculating points to right
     pt7  (polar pt3 0.0 (* 0.5 leng))
pt8 (polar pt7 (* pi 0.5) 100) ; 100 is distance between box and circle
  pt9 (polar pt8 (* pi 0.5) 60) ; 60 is distance between first and second circle
;; calculating points to left
    pt10 (polar pt6 0.0 (* 0.5 leng)) ;
      pt11 (polar pt10 (* pi 1.5) 100) ; 100 is distance between box and circle
 pt12 (polar pt11 (* pi 1.5) 60) ; 60 is distance between first and second circle
;;;         pt9 0
;;;         pt8 0
;;;        pt3+-+-+ pt4
;;;    | 7 |
;;;   pt1 pt2 |
;;;    pt10|
;;;        pt6+-+-+pt5
;;;        pt11 0
;;;        pt12 0
    ) ; End Setq
 (mapcar 'setvar vlst '(0 0 1))  ; Set the Variables to how we want them
 (command "_.pline" pt3 pt4 pt5 pt6 pt3 pt5 "")  ; Make the Polyline
 ; Remember to use "_." prefix to make it
 ; compatible for all language versions.
 (ssadd (entlast) ss)  ; Add the polyline to the selection set
[color=red];; select side of wich the circle should appear[/color]
[color=red]   (initget "L R")[/color]
[color=red]   (setq side (getkword "\nCircle Left or Right? (L/R) <R>:  "))[/color]
[color=red];; only L or R can be given while <Enter> is same as R[/color]
[color=red](cond[/color]
[color=red]((= side "L")[/color]
[color=red];; when given L[/color]
[color=red];; ------------[/color]
[color=red]  (command "_.circle" pt11 "_D" dia)  ; Create the first Circle[/color]
[color=red]  (ssadd (entlast) ss)  ; Add the Circle to the selection set[/color]
[color=red]  (command "_.circle" pt12 "_D" dia)  ; Create the second Circle[/color]
[color=red]  (ssadd (entlast) ss))  ; Add the Circle to the selection set[/color]
[color=red];; when given R or <Enter> [/color]
[color=red]([/color]
[color=red] (command "_.circle" pt8 "_D" dia)  ; Create the first Circle[/color]
[color=red]  (command "_.circle" pt9 "_D" dia)  ; Create the second Circle[/color]
[color=red] )[/color]
[color=red])[/color]
(command "_.rotate" ss "" pt1 pause)
 (mapcar 'setvar vlst ovar) ; Reset System Variables
 ; Exit Cleanly
 ) ; End box1
Just looking quickly, you have missed the "t" from your second COND statement:
([color=Blue][b]t[/b][/color]
Lee, you are right... I checked the lisp file in wich i sniffed around and there is no " t " in it. Strange ...
Anyway, yes it works and again we are grateful !
I'm not a lover of using loads of variables, but just as a variation, you could also write it like this:
                 pt5 pt6 pt7 pt8 pt9 pt10
                 pt11 pt12 tmp)
   (if ovar (mapcar 'setvar vlst ovar))
     (princ (strcat "\n<< Error: " msg " >>"))
     (princ "<<-- Cancelled -->>"))
   (princ))
 (or box:def (setq box:def "Right"))
       ss   (ssadd)
       pt12 (polar pt11 (* pi 1.5) 60))
 (initget "Left Right")
 (setq tmp (getkword (strcat "\nCircle Left or Right? (L/R) <" box:def ">: ")))
 (or (not tmp) (setq box:def (strcase tmp)))
 (if (= box:def "Right")
    (ssadd (entlast) ss)))
 (princ))
