ronjonp Posted August 12, 2009 Posted August 12, 2009 Do the polylines have more than two vertice? Quote
ReMark Posted August 12, 2009 Posted August 12, 2009 Looks like you fell for the trap. Don't give us what we want...give us what we need! Quote
ronjonp Posted August 12, 2009 Posted August 12, 2009 Funny how that happens...the code will start with a few lines and end with hundreds Quote
ReMark Posted August 12, 2009 Posted August 12, 2009 It's like a vortex or a black hole. Once they suck you in there's no escaping! You're doomed. Quote
Eatonpcat Posted August 12, 2009 Posted August 12, 2009 Wow...I didn't think this was for a structural drawing. Being a structural designer myself, I don't think this command/lisp would be all that useful, but to each his own Quote
ReMark Posted August 12, 2009 Posted August 12, 2009 Same here. The line between columns could be started/ended using the M2P command. Depending upon the interior length of the flange the result would be pretty close to what the OP described. But, he is doing all this after-the-fact. Quote
nukecad Posted August 12, 2009 Posted August 12, 2009 Surely something easy must be possible here? After all dimension leader lines have a gap (and extension) generated automaticaly; so this should be possible with normal lines??? (PS. I use LT most of the time so am not very familiar with lisp / vba). Quote
ronjonp Posted August 12, 2009 Posted August 12, 2009 I'm still not sure how this helps...perhaps a sample drawing? Quote
David Bethel Posted August 12, 2009 Posted August 12, 2009 Here is something that should work even on 3D lines. [b][color=BLACK]([/color][/b]defun c:lline [b][color=FUCHSIA]([/color][/b]/ add ss i en ed p10 p11 p20 p21[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]initget 1[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]princ [color=#2f4f4f]"\nPositive to Add Length - Negative To Subtract Length"[/color][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]setq add [b][color=NAVY]([/color][/b]getdist [color=#2f4f4f]"\nDistance To Change Each End Of The LINE: "[/color][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]setq add [b][color=NAVY]([/color][/b]- add[b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]and [b][color=NAVY]([/color][/b]setq ss [b][color=MAROON]([/color][/b]ssget [b][color=GREEN]([/color][/b]list [b][color=BLUE]([/color][/b]cons 0 [color=#2f4f4f]"LINE"[/color][b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]if [b][color=RED]([/color][/b]getvar [color=#2f4f4f]"CTAB"[/color][b][color=RED])[/color][/b] [b][color=RED]([/color][/b]cons 410 [b][color=PURPLE]([/color][/b]getvar [color=#2f4f4f]"CTAB"[/color][b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b]cons 67 [b][color=PURPLE]([/color][/b]- 1 [b][color=TEAL]([/color][/b]getvar [color=#2f4f4f]"TILEMODE"[/color][b][color=TEAL])[/color][/b][b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]setq i [b][color=MAROON]([/color][/b]sslength ss[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]while [b][color=MAROON]([/color][/b]not [b][color=GREEN]([/color][/b]minusp [b][color=BLUE]([/color][/b]setq i [b][color=RED]([/color][/b]1- i[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]setq en [b][color=GREEN]([/color][/b]ssname ss i[b][color=GREEN])[/color][/b] ed [b][color=GREEN]([/color][/b]entget en[b][color=GREEN])[/color][/b] p10 [b][color=GREEN]([/color][/b]cdr [b][color=BLUE]([/color][/b]assoc 10 ed[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] p11 [b][color=GREEN]([/color][/b]cdr [b][color=BLUE]([/color][/b]assoc 11 ed[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] p20 [b][color=GREEN]([/color][/b]point_on_line p10 p11 add[b][color=GREEN])[/color][/b] p21 [b][color=GREEN]([/color][/b]point_on_line p11 p10 add[b][color=GREEN])[/color][/b] ed [b][color=GREEN]([/color][/b]subst [b][color=BLUE]([/color][/b]cons 10 p20[b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]assoc 10 ed[b][color=BLUE])[/color][/b] ed[b][color=GREEN])[/color][/b] ed [b][color=GREEN]([/color][/b]subst [b][color=BLUE]([/color][/b]cons 11 p21[b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]assoc 11 ed[b][color=BLUE])[/color][/b] ed[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]entmod ed[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] [color=#8b4513];;;point_on_line - a point on the line p1,p2 at a specified distance from p1[/color] [color=#8b4513];;;ARG -> StartPt EndPt Distance[/color] [color=#8b4513];;;RET -> PointList[/color] [b][color=BLACK]([/color][/b]defun point_on_line [b][color=FUCHSIA]([/color][/b]p1 p2 dist[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]mapvec '+ p1 [b][color=NAVY]([/color][/b]mapvec '* [b][color=MAROON]([/color][/b]mapvec '- p2 p1[b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]/ dist [b][color=GREEN]([/color][/b]distance p1 p2[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] [color=#8b4513];;;Point Functions - Apply math & boolean Functions To Points With Float[/color] [b][color=BLACK]([/color][/b]defun mapvec [b][color=FUCHSIA]([/color][/b]f v1 v2[b][color=FUCHSIA])[/color][/b] [color=#8b4513];;;Quoted_Function value1_pt_list value2[/color] [b][color=FUCHSIA]([/color][/b]cond [b][color=NAVY]([/color][/b][b][color=MAROON]([/color][/b]null v2[b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]mapcar f v1[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b][b][color=MAROON]([/color][/b]not [b][color=GREEN]([/color][/b]listp v2[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]mapcar '[b][color=GREEN]([/color][/b]lambda [b][color=BLUE]([/color][/b]a[b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b][b][color=RED]([/color][/b]eval f[b][color=RED])[/color][/b] [b][color=RED]([/color][/b]float a[b][color=RED])[/color][/b] [b][color=RED]([/color][/b]float v2[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] v1[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]T [b][color=MAROON]([/color][/b]mapcar '[b][color=GREEN]([/color][/b]lambda [b][color=BLUE]([/color][/b]a b[b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b][b][color=RED]([/color][/b]eval f[b][color=RED])[/color][/b] [b][color=RED]([/color][/b]float a[b][color=RED])[/color][/b] [b][color=RED]([/color][/b]float b[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] v1 v2[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] -David Quote
pattyandme Posted August 14, 2009 Posted August 14, 2009 can you select all the lines and then change there length in properties? I work mostly in 3d so im not sure if you can do this with a line. I know it can be done with 3d objects. Quote
DWG Destroyer Posted August 18, 2009 Author Posted August 18, 2009 No, I’ve tried that to no avail, at least in 2D anyway. Not to worry, what I’ve got now is ample. Quote
DWG Destroyer Posted January 11, 2010 Author Posted January 11, 2010 Well, here we are again! Have been using this command for a while now and it has been of great, great use to me, but there is one last annoyance that is hindering its use... When I try to use the command through a view port, it simply does not recognise anything selected. It would be great if someone could offer their expertise to make a good command better! Many thanks Quote
Lee Mac Posted January 11, 2010 Posted January 11, 2010 Perhaps this, using Davids code: [b][color=BLACK]([/color][/b]defun c:lline [b][color=FUCHSIA]([/color][/b]/ add ss i en ed p10 p11 p20 p21[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]initget 1[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]princ [color=#2f4f4f]"\nPositive to Add Length - Negative To Subtract Length"[/color][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]setq add [b][color=NAVY]([/color][/b]getdist [color=#2f4f4f]"\nDistance To Change Each End Of The LINE: "[/color][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]setq add [b][color=NAVY]([/color][/b]- add[b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]and [b][color=NAVY]([/color][/b]setq ss [b][color=MAROON]([/color][/b]ssget [b][color=GREEN]([/color][/b]list [b][color=BLUE]([/color][/b]cons 0 [color=#2f4f4f]"LINE"[/color][b][color=BLUE])[/color][/b][b][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]setq i [b][color=MAROON]([/color][/b]sslength ss[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]while [b][color=MAROON]([/color][/b]not [b][color=GREEN]([/color][/b]minusp [b][color=BLUE]([/color][/b]setq i [b][color=RED]([/color][/b]1- i[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]setq en [b][color=GREEN]([/color][/b]ssname ss i[b][color=GREEN])[/color][/b] ed [b][color=GREEN]([/color][/b]entget en[b][color=GREEN])[/color][/b] p10 [b][color=GREEN]([/color][/b]cdr [b][color=BLUE]([/color][/b]assoc 10 ed[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] p11 [b][color=GREEN]([/color][/b]cdr [b][color=BLUE]([/color][/b]assoc 11 ed[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] p20 [b][color=GREEN]([/color][/b]point_on_line p10 p11 add[b][color=GREEN])[/color][/b] p21 [b][color=GREEN]([/color][/b]point_on_line p11 p10 add[b][color=GREEN])[/color][/b] ed [b][color=GREEN]([/color][/b]subst [b][color=BLUE]([/color][/b]cons 10 p20[b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]assoc 10 ed[b][color=BLUE])[/color][/b] ed[b][color=GREEN])[/color][/b] ed [b][color=GREEN]([/color][/b]subst [b][color=BLUE]([/color][/b]cons 11 p21[b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]assoc 11 ed[b][color=BLUE])[/color][/b] ed[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]entmod ed[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] [color=#8b4513];;;point_on_line - a point on the line p1,p2 at a specified distance from p1[/color] [color=#8b4513];;;ARG -> StartPt EndPt Distance[/color] [color=#8b4513];;;RET -> PointList[/color] [b][color=BLACK]([/color][/b]defun point_on_line [b][color=FUCHSIA]([/color][/b]p1 p2 dist[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]mapvec '+ p1 [b][color=NAVY]([/color][/b]mapvec '* [b][color=MAROON]([/color][/b]mapvec '- p2 p1[b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]/ dist [b][color=GREEN]([/color][/b]distance p1 p2[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] [color=#8b4513];;;Point Functions - Apply math & boolean Functions To Points With Float[/color] [b][color=BLACK]([/color][/b]defun mapvec [b][color=FUCHSIA]([/color][/b]f v1 v2[b][color=FUCHSIA])[/color][/b] [color=#8b4513];;;Quoted_Function value1_pt_list value2[/color] [b][color=FUCHSIA]([/color][/b]cond [b][color=NAVY]([/color][/b][b][color=MAROON]([/color][/b]null v2[b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]mapcar f v1[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b][b][color=MAROON]([/color][/b]not [b][color=GREEN]([/color][/b]listp v2[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]mapcar '[b][color=GREEN]([/color][/b]lambda [b][color=BLUE]([/color][/b]a[b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b][b][color=RED]([/color][/b]eval f[b][color=RED])[/color][/b] [b][color=RED]([/color][/b]float a[b][color=RED])[/color][/b] [b][color=RED]([/color][/b]float v2[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] v1[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]T [b][color=MAROON]([/color][/b]mapcar '[b][color=GREEN]([/color][/b]lambda [b][color=BLUE]([/color][/b]a b[b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b][b][color=RED]([/color][/b]eval f[b][color=RED])[/color][/b] [b][color=RED]([/color][/b]float a[b][color=RED])[/color][/b] [b][color=RED]([/color][/b]float b[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] v1 v2[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] Quote
DWG Destroyer Posted January 12, 2010 Author Posted January 12, 2010 And it works!! Thanks a bunch for helping me with this, I love this command Quote
Lee Mac Posted January 12, 2010 Posted January 12, 2010 And it works!! Thanks a bunch for helping me with this, I love this command You're welcome, but really it was all David Quote
