CADMASTER1128 Posted August 12, 2009 Share Posted August 12, 2009 Example: 7mm for walls and 2mm for electrical. I use mm settings because I came to CAD via manual drafting. Mechanical pencils came in 3mm, 5mm, 7mm and 9mm sizes. I think he talking about the color of the layer. At least that's the way I took it. Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 12, 2009 Share Posted August 12, 2009 He is plotting in monochrome not in color. While picking a layer color in the grayscale range will, in a few cases, result in a lighter looking line he can get the same affect by reducing the lineweight. Another option is to experiment with "dithering". Quote Link to comment Share on other sites More sharing options...
CADMASTER1128 Posted August 12, 2009 Share Posted August 12, 2009 dithering? What's that? Quote Link to comment Share on other sites More sharing options...
lpseifert Posted August 12, 2009 Share Posted August 12, 2009 Or as in my situation the teacher (and family) starts to hate and talk about you behind your back. Paranoia, the destroyer. (Ray Davies, The Kinks) Quote Link to comment Share on other sites More sharing options...
CADMASTER1128 Posted August 12, 2009 Share Posted August 12, 2009 Paranoia, the destroyer. (Ray Davies, The Kinks) HAHA, Well it doesn't help that I literally know more about CAD than he does. And he knows it to Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 12, 2009 Share Posted August 12, 2009 My bad. I should have said screening and not dithering. I stand corrected. Quote Link to comment Share on other sites More sharing options...
CADMASTER1128 Posted August 12, 2009 Share Posted August 12, 2009 My bad. I should have said screening and not dithering. I stand corrected. Well I didn't correct you, you technically you aren't standing corrected. Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 12, 2009 Share Posted August 12, 2009 We have devolved into semantics now? Skip it. I have. Quote Link to comment Share on other sites More sharing options...
CADMASTER1128 Posted August 12, 2009 Share Posted August 12, 2009 We have devolved into semantics now? Skip it. I have. Back on topic here... What is screening then? Quote Link to comment Share on other sites More sharing options...
lpseifert Posted August 12, 2009 Share Posted August 12, 2009 Screening by .ctb file, the lower the number, the lighter the 'screening' (grayness) Quote Link to comment Share on other sites More sharing options...
CADMASTER1128 Posted August 12, 2009 Share Posted August 12, 2009 Thanks for posting that. Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 12, 2009 Share Posted August 12, 2009 From your AutoCAD Help file. Screening "You can select a color intensity setting that determines the amount of ink placed on the paper while plotting. The valid range is 0 through 100. Selecting 0 reduces the color to white. Selecting 100 displays the color at its full intensity. Screening is effective only if your plotter is configured to plot colors or grayscale. Also, dithering must be enabled." Quote Link to comment Share on other sites More sharing options...
CADMASTER1128 Posted August 12, 2009 Share Posted August 12, 2009 That makes sense and I can see how that will change the color. Quote Link to comment Share on other sites More sharing options...
CadDan Posted August 12, 2009 Author Share Posted August 12, 2009 Thanks for that ReMark. So instead of changing the actual color so it would be brighter; since I'm plotting in monochrome; I can just do the screening and make it a different scale of gray? Let me know if I got that right. Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 12, 2009 Share Posted August 12, 2009 Yes, try screening the color. Or, as I first suggested, go with a much lighter lineweight. Quote Link to comment Share on other sites More sharing options...
CadDan Posted August 12, 2009 Author Share Posted August 12, 2009 I believe the lighter lineweight would be sufficient for this. Also, probably easier. Quote Link to comment Share on other sites More sharing options...
CADMASTER1128 Posted August 12, 2009 Share Posted August 12, 2009 I would agree with you CadDan. Quote Link to comment Share on other sites More sharing options...
CadDan Posted August 12, 2009 Author Share Posted August 12, 2009 Accidentally posted this in the heptagon house thread. Seeming to have another problem. In model space the lines are white, but when switched to paper space, the lines are gray, and when I go to change the color of the line while in paper space, I hover and click white, but then it appears black in the properties manager and the line is still gray. Quote Link to comment Share on other sites More sharing options...
CADMASTER1128 Posted August 12, 2009 Share Posted August 12, 2009 HAHA, see my reply in heptagon house. Quote Link to comment Share on other sites More sharing options...
CadDan Posted August 12, 2009 Author Share Posted August 12, 2009 Continuation of line talk from heptagon house thread. ------------------------------------------------------ I have yet to do either. But when switching between model and paper space the lines seem to go from white to gray and they are suppose to be black when appearing on paper space correct? Quote Link to comment Share on other sites More sharing options...
