Lee Mac Posted October 17, 2013 Posted October 17, 2013 Genius as always . thank you so much lee mac!!! That's some old code! - but thanks Daniel! Quote
sieu khung khiep Posted June 10, 2017 Posted June 10, 2017 Cbrk.lsp doenot worked in some case,i don't know why but when i modify this lisp,now it working for me,but i donot know my lisp modifed is that correct? can you update your code,lee (defun c:CBrk (/ ss tmp i j ent elst inc st s501 len R1 ) (vl-load-com) (or Cbrk:num (setq Cbrk:num 2)) (cond ((setq ss (ssget "_:L" '((0 . "ARC,CIRCLE")))) (initget 6) (and (setq tmp (getint (strcat "\nSpecify Number of Sections <" (itoa Cbrk:num) "> : "))) (setq Cbrk:num tmp)) (setq i -1) (while (setq ent (ssname ss (setq i (1+ i)))) (setq elst (entget ent) j -1) (cond ((eq "CIRCLE" (cdr (assoc 0 elst))) (setq inc (/ (* 2 pi) cBrk:num) st 0.));cond (t (progn (setq len (vla-get-arclength (vlax-ename->vla-object ent)) R1 (cdr (assoc 40 elst))) (setq s501 (abs (- (cdr (assoc 51 elst)) (setq st (cdr (assoc 50 elst))) ))) (if (<= len (* pi R1)) (if (> s501 pi) ;big angle but leng arc small (setq inc (/ (- (* 2 pi) s501) cBrk:num)) (setq inc (/ s501 cBrk:num));setq );if1 (if (> s501 pi) ;goc lon (setq inc (/ s501 cBrk:num));setq (setq inc (/ (- (* 2 pi) s501) cBrk:num)) );if1 );if );progn ));cond (repeat cbrk:num (entmake (list (cons 0 "ARC") (assoc 8 elst) (assoc 10 elst) (assoc 40 elst) (cons 50 (+ st (* (setq j (1+ j)) inc))) (cons 51 (+ st (* (1+ j) inc))))) (entmake (list (cons 0 "LINE") (assoc 8 elst) (assoc 10 elst) (cons 11 (polar (cdr (assoc 10 elst)) (+ st (* j inc)) (cdr (assoc 40 elst))))))) (if (eq "ARC" (cdr (assoc 0 elst))) (entmake (list (cons 0 "LINE") (assoc 8 elst) (assoc 10 elst) (cons 11 (polar (cdr (assoc 10 elst)) (+ st (* (1+ j) inc)) (cdr (assoc 40 elst))))))) (entdel ent)))) (princ)) Quote
