JerryG Posted October 23, 2009 Posted October 23, 2009 reset Filedia to 1? Also check to make sure that you are saving to 2010. Here is what the help file says When FILEDIA is set to 0 (zero), SAVEAS displays the following command prompts. Current file format: current Enter file format [R14(LT98<97)/2000(LT2000)/2004(LT2004)/ 2007(LT2007)/2010(LT2010)/Standards/DXF/Template] : Enter an option or press Enter Save drawing as : Enter a name or press Enter Hope that helps. Quote
desiree Posted October 27, 2009 Author Posted October 27, 2009 reset Filedia to 1? Also check to make sure that you are saving to 2010.Here is what the help file says When FILEDIA is set to 0 (zero), SAVEAS displays the following command prompts. Current file format: current Enter file format [R14(LT98<97)/2000(LT2000)/2004(LT2004)/ 2007(LT2007)/2010(LT2010)/Standards/DXF/Template] : Enter an option or press Enter Save drawing as : Enter a name or press Enter Hope that helps. I can not set my save type to CAD 2010 since there are a few different versions running in the office and if it happens to go out of office (unusual but happens) I can not be sure they are using the newest. Either way changing the Filedia doesn't seem to work. Anyone else? Quote
JerryG Posted October 28, 2009 Posted October 28, 2009 We were having so many problems saving from 2010 (civil 3d) to back versions that we finnaly switched everyone over to 2010. Quote
rkmcswain Posted October 28, 2009 Posted October 28, 2009 I am hitting save not save as.... FYI: The SAVE button (by default) executes the QSAVE command, not the SAVE command. QSAVE, SAVE, and SAVEAS are three different commands. More info: http://cadpanacea.com/node/81 Quote
