Miguel562 Posted October 22, 2014 Share Posted October 22, 2014 Windows 7 but apparently the owner of vtab.com died so im stuck having to use this older version with windows xp for now Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 22, 2014 Share Posted October 22, 2014 (edited) I'll need your email address. Include it in your next post in the following form: m y e m a i l a d d r e s s AT h o t m a i l DOT c o m I'll try to get it out to you today. BTW...I do not accept "Friend" requests from first time subscribers to this site. Nothing personal mind you but oft times the people that make these types of requests have no posts, have started no threads, nor do they show any commitment to sticking around and participating in the forum. Should you show me that is not true of you then down the road and I may change my mind. Edited October 22, 2014 by ReMark spelling Quote Link to comment Share on other sites More sharing options...
Miguel562 Posted October 22, 2014 Share Posted October 22, 2014 Totally understandable I just wanted to PM you since I saw you might be my only solution hehe, thank you so much btw hopefully I can get this digitizer to work so I can go back to scanning blueprints my email is M i g u e l 5 6 2 @ m s n Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 22, 2014 Share Posted October 22, 2014 An email has been sent. Let me know when/if it arrives. Sometimes things get lost in the mail. Quote Link to comment Share on other sites More sharing options...
barb2014 Posted November 4, 2014 Share Posted November 4, 2014 Hi, I have a CalComp Drawingboard III to use in a CAD software for shoes industry. It worked fine in XP but now we change our machines to Win7 x64 and I have some troubles with the Drawingboard. I installed the TabletWorks v10.09.24 and the Drawingboard conects fine and is recognized by CAD software but after a few seconds is diconected! I have to close TabletWorks controlPanel, unplug and plug the usb cable (here I use a serial to usb cable converter) and then execute TabletWorks again to reconect to Drawingboard. Is there any soulution for this situation? Thanks in advance Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 4, 2014 Share Posted November 4, 2014 I think the problem is the physical connection using the serial-to-usb connector. I used something similar when running an older plotter under a newer (Win7) OS and always suffered intermittent problems. You might be better off with a serial add-in card that one be installed in one of your vacant PCI slots. Quote Link to comment Share on other sites More sharing options...
barb2014 Posted November 4, 2014 Share Posted November 4, 2014 Good thought! My next step is to arrange a pci card that allows me to use the serial cable to conect. I will try and feedbakc the results. Thanks. Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 4, 2014 Share Posted November 4, 2014 I can't guarantee that it will work but it is worth a try. The only other option would be to run both AutoCAD and Tabletworks in XP compatibility mode. Quote Link to comment Share on other sites More sharing options...
