I agree that no-one would really set it to 1, but I have seen examples in the past where Fixo sets Sys Vars differently... o:)
Then I retract my statement. :)
  • Replies 32
  • Lee Mac
    11
  • cadman2009
    8
  • fixo
    6
  • SteveK
    3
Posted Images
Oh really, now I have to remember where all those drawings are saved I tried it on hehe
And actually I'd really like to know how to get "Command:" back?
I had to quit Acad and fire it up again to get "Command:" back.:x
Just type nomutt 1. You can't see it, but it will fix it.
Here is another one too big but with flowers :)
~'J'~
Dear fixo
Hi
when I use your code , after picking on a pline the below massage occurs :
Command: _appload PlineImport.LSP successfully loaded.
Command:
>>> Start command with PVI
Command:
Command: PVI
>>> Select polyline to import coordinates
*Cancel*
*Cancel*
why ?
Dear fixo
Hi
Command:
Command:
Command: PVI
*Cancel*
*Cancel*
why ?
See post #23
~'J'~
See post #23
~'J'~
Dear fixo
I make a 3dpoly and save it to c:\polytest.dwg and then load your code and type in command line pvi , after selecting polyline don't make any excel file and when I type nomutt 0 the command line appear and when I type nomutt in command line Disappear command line . However Is not made any excel file . I have this problem with 2 files :
plineImport.lsp and dwgtoexcel.lsp
please tell me how I can run these files step by step and where I must retrieved follow them .
thanks
Please try this instead CadMan, it works fastest if Excel is already open.
;; Polyline Vertex Exporter  ~   by Lee McDonnell  ~  27.11.2009
(defun c:pExp (/ *error* ObjRel ss col row ent tot j pt)
 (vl-load-com)
 (defun *error* (e)
   (ObjRel (list xlApp xlCells))
   (or (wcmatch (strcase e) "*BREAK,*CANCEL*,*EXIT*")
       (princ (strcat "\n** Error : " e " **")))
   (princ))
 (defun ObjRel (lst)
   (mapcar
     (function
       (lambda (x)
         (if (and (eq (type x) 'VLA-OBJECT) (not (vlax-object-released-p x)))
           (vl-catch-all-apply 'vlax-release-object (list x))))) lst))
 (if  (setq i -1 ss (ssget '((0 . "*POLYLINE"))))
     (setq xlApp     (vlax-get-or-create-object "Excel.Application")
           xlCells   (vlax-get-property
                       (vlax-get-property
                         (vlax-get-property
                           (vlax-invoke-method
                             (vlax-get-property xlApp "Workbooks")
                             "Add")
                           "Sheets")
                         "Item" 1)
                       "Cells") col 0 row 1)
     (mapcar (function
               (lambda (x)
                 (vlax-put-property xlCells "Item" row (setq col (1+ col)) x)))
             '("Point""X""Y""Z""Distance""Total"))
     (while (setq ent (ssname ss (setq i (1+ i))))
       (setq tot 0. row (1+ row) j (1- (vlax-curve-getStartParam ent)))
       (while (<= (setq j (1+ j)) (vlax-curve-getEndParam ent))
         (setq col 0 pt (mapcar 'rtos (vlax-curve-getPointatParam ent j)))
         (mapcar
           (function
             (lambda (x)
           (list   (rtos (1+ j) 2 0)
                   (car pt)  (cadr pt) (caddr pt)
                   (rtos (setq dis (- (vlax-curve-getDistatParam ent j)
                                      (if (zerop j) 0 (vlax-curve-getDistatParam ent (1- j))))))
                   (rtos (setq tot (+ dis tot)))))
         (setq row (1+ row))))
     (vlax-put-property xlApp 'Visible :vlax-true)
     (ObjRel (list xlApp xlCells))))
 (princ))
Dear fixo
thanks
Ok, I see where I'm wrong, sorry
This one is working for me nice
I use A2008 an Excel 2003
Try it again
(Refresh my memory where is dwgtoexcel.lsp)
~'J'~
PlineImport.LSP
 (vl-load-com)
 (defun *error* (e)
   (princ))
 (defun ObjRel (lst)
   (mapcar
     (function
       (lambda (x)
                       (vlax-get-property
                         (vlax-get-property
                           (vlax-invoke-method
                             "Add")
                           "Sheets")
                         "Item" 1)
     (mapcar (function
               (lambda (x)
         (mapcar
           (function
             (lambda (x)
 (princ))
Thanks LEE
it works correctly like your other programs
Thanks LEE
You're welcome CadMan :)
Try it again
~'J'~
Dear sir
I thanks very much , Please Excuse me as to why I insisted something I repeated questions .
Dear sir
No worries, please :)
Ask me again and again
You helped me too to find the mistakes
Regards,
~'J'~
  • 3 years later...
There is a way to associate info export with the name of layer like this; buts this only take area
(defun c:pline-area ( / *error* data-lst sorted-lst str-lst top-str polys
data cnt obj file-nm tmp item tmp-str fl)
(defun *error* (msg)
(if(= msg "quit / exit abort")
(princ "\nNo output file was selected")
(princ msg)
(setq top-str ""
file-nm (getfiled "Output File" "" "doc" 1)
(if(null file-nm)(exit))
(if(setq polys(ssget '((0 . "*POLYLINE"))))
(repeat(setq cnt(sslength polys))
(setq obj (vlax-ename->vla-object
(ssname polys
(setq cnt(1- cnt))
data-lst (cons
(list(vlax-get obj 'Layer)
(vlax-get obj 'Area)
data-lst
(while data-lst
(setq data (car data-lst)
data-lst (cdr data-lst)
tmp (list data)
(foreach item data-lst
(if(=(car item)(car data))
(setq tmp (cons item tmp)
data-lst (vl-remove item data-lst)
(setq sorted-lst(cons tmp sorted-lst))
(setq sorted-lst
(vl-sort sorted-lst '(lambda(a b)(
(foreach item (reverse sorted-lst)
(setq top-str
(strcat(caar item)"," top-str)
(setq str-lst (cons top-str str-lst)
cnt 0
(repeat(apply 'max(mapcar 'length sorted-lst))
(setq tmp-str "")
(setq tmp-str
(if(setq tmp(nth cnt item))
(strcat(rtos(cadr tmp)) "," tmp-str)
(strcat "," tmp-str)
(setq cnt (1+ cnt)
str-lst (cons tmp-str str-lst)
(if(setq fl(open file-nm "w"))
(foreach str (reverse str-lst)
(write-line str fl)
(close fl)
(alert(strcat file-nm " was created"))
(alert "Unable to create file")
