t1320t Posted December 15, 2009 Posted December 15, 2009 Hello- Our office uses a HP Designjet 800 plotter w 24" roll feed paper. I'm having issues w the plotted orientation of our Arch C sheets in paperspace.... the plot previews correctly but does not actually plot correctly. It does not plot the dwg the full width of the roll but does cut the sheet at the correct length (24"). All of the dwg get plotted but I have to cut the excess 6" off of every plot. Here are my current settings: "Paper size" Arch C "Plot area" Layout "Plot scale" 1"=200units "Plot offset" x=0 y=0 "Drawing orientation" Landscape Any ideas on how to fix this?? Thanks Quote
rkent Posted December 15, 2009 Posted December 15, 2009 Are you plotting from Model or Paper space? What are the exact dimensions of your titleblock? Post the title block here. Quote
todouble22 Posted December 15, 2009 Posted December 15, 2009 Are you plotting from Model or Paper space?What are the exact dimensions of your titleblock? Post the title block here. it appears that its in paper space since the option is layout.. try centering the plot and make sure your page setup is for c scale . you may have to adjust your scale to something other than 1 = 200 units so that it is uniform in the plot. Quote
t1320t Posted December 15, 2009 Author Posted December 15, 2009 I'm plotting from paperspace. The exact dimensions are 3600x4800. Quote
ReMark Posted December 15, 2009 Posted December 15, 2009 We use a HP DesignJet 500 and 24" wide paper and have no problem. Our paper choices include Arch C (landscape) and Arch C (portrait). We use Arch C (landscape) with a Drawing Orientation (Plot window) of Landscape as well. Perfect 18x24 plots each and every time. No waste. Quote
rkent Posted December 15, 2009 Posted December 15, 2009 If the exact dimensions of your title block are 4800x3600 then you are not allowing for plotter margins, so the plotter rotates the plot to make it fit on your roll. You may need to allow for an inch in both x and y directions for margins. I asked about paperspace or model space because you mentioned a plotting scale. Almost everyone that uses PS sizes their titleblock to true size and scales the viewports for plotting. So for your application your titleblock would be approx 23"X17" or the metric equivalent, etc. Quote
t1320t Posted December 15, 2009 Author Posted December 15, 2009 I have the "drawing orientation" set to landscape & it's previews just fine but the actual sheet that comes out of the plotter doesn't. If I change it to portrait, it cuts off the top and side of the plot. I do not have Arch C (landscape) as an option. Actually, neither Arch C & Arch D have options for (landscape) or (portrait) but Arch B & Arch A do. Quote
t1320t Posted December 15, 2009 Author Posted December 15, 2009 If the exact dimensions of your title block are 4800x3600 then you are not allowing for plotter margins, so the plotter rotates the plot to make it fit on your roll. You may need to allow for an inch in both x and y directions for margins. I asked about paperspace or model space because you mentioned a plotting scale. Almost everyone that uses PS sizes their titleblock to true size and scales the viewports for plotting. So for your application your titleblock would be approx 23"X17" or the metric equivalent, etc. Thanks for the insight. I work for a small company & have pushed hard to get to the point of even using paperspace. So, there's been a huge learning curve as I wade through it all then relay what I've learned to the other CAD operators. I'll try tweaking the size down & hope for the desired results. What exactly do you mean by "true size"? Do you bring your title blocks in at 1 scale? I'm currently inserting mine at the drawing scale. Quote
ReMark Posted December 15, 2009 Posted December 15, 2009 There's no reason you shouldn't have those options unless you have the wrong driver loaded. I'm using the dsgj800.inf driver. Quote
t1320t Posted February 11, 2010 Author Posted February 11, 2010 It looks like I'm using the HP Designjet 800 24 by HP driver. ReMark, how do I get to the dsgj800.inf driver that you referred to?? Quote
t1320t Posted February 11, 2010 Author Posted February 11, 2010 I've located the dsgj800.inf driver on my hard drive... now what? I can't select it from the drivers listed in the advanced tab. Quote
ReMark Posted February 11, 2010 Posted February 11, 2010 It should be included in the zip file you downloaded. Quote
ReMark Posted February 11, 2010 Posted February 11, 2010 During the printer installation process the user is prompted for the driver. Windows wants to go find it on its own (not always a good idea) but the user should select the option "Have disk" and then utilize the browse button to locate and open the .inf file. Quote
t1320t Posted February 11, 2010 Author Posted February 11, 2010 Thanks for the quick replies. I browsed for the dsgj800.inf file, went through the steps, clicked finished, then the original HP Designjet 800 24 by HP is still the driver. I'm lost. The dsgj800.inf doesn't show up in the pull down list either. Quote
ReMark Posted February 11, 2010 Posted February 11, 2010 And how are you able to tell the two apart? Something tells me I would have completely removed the "old" driver before attempting to utilize a new one. Quote
t1320t Posted February 11, 2010 Author Posted February 11, 2010 Yeah, I suppose if I'd been down this road before, I would've known to remove the "old" driver, but since this is my 1st time messing w drivers it didn't come to mind. Either way, I'm trying to do it now.. start>printers>file>server properties>drivers tab, selected driver, clicked remove but it says it's in use. I've cleared all print jobs & disconnected the printer. Is the correct method for removing drivers? Quote
ReMark Posted February 11, 2010 Posted February 11, 2010 Really? You never in your life, at home or work, had to remove and install new drivers for any piece of hardware? Man, you have lived a supremely mundane life. LOL I'm lucky as my printer is not on the network so removing a driver has never been a problem. How many other people have access to the printer besides you? Quote
t1320t Posted February 11, 2010 Author Posted February 11, 2010 Yep. I've installed printers but have never had to mess w drivers. Somehow I managed to avoid it this long & it doesn't look like I missed much. There're 4 other people who access the printer. Why? Are you suggesting that I pawn this little project off on someone else?? Quote
ReMark Posted February 11, 2010 Posted February 11, 2010 No I'm not. I'm just going to keep torturing you. I'm just wondering if all the other users have to uninstall the printer before you can go any further. Quote
t1320t Posted February 12, 2010 Author Posted February 12, 2010 Ha. Thanks for the support man. As the official unofficial IT guy, I'm going to push this project off for a little while until I can get a better handle on what I really need to do to fix the problem. Quote
