BlackAlnet Posted March 9, 2010 Posted March 9, 2010 You can place the text on a determined layer and then use filter command to change all the text height, since the height does not change the angle and the insert point of the text. Quote
tomjas Posted March 9, 2010 Author Posted March 9, 2010 Yes I know that Thanks I can't figure it out why I can't get the same results as you and CM Hev have. Is it that big difference between 2008 and 2010?? Anyway thanks for your ideas- now I can use excel to do my task! Thanks Quote
