ReMark Posted February 21, 2014 Share Posted February 21, 2014 I just emailed myself a reminder. I'll let you know one way or the other. Adios amigo. Quote Link to comment Share on other sites More sharing options...
mdbdesign Posted April 6, 2014 Share Posted April 6, 2014 Here's one for you buzz combine with DISH HEAD it kind of covers it all enough anyway to draw tanks and do a little planning at the same time.Feel free to add stuff and post back the newly added ones Best R Change the location of the file in the lsp (defun C:DEV () (setq prgpath for it to work Not working on AC2013 Command: (LOAD "C:/AutoCAD All support/DEVELOP/DEVELOP.LSP") C:DEVCommand: DEV ; error: quit / exit abort Command: What do I do wrong? Path changed. (defun C:DEV () (setq prgpath "C:\AutoCAD All support\DEVELOP") (setq dcl_id (load_dialog (strcat prgpath "DEVELOP.dcl"))) Quote Link to comment Share on other sites More sharing options...
mdbdesign Posted April 7, 2014 Share Posted April 7, 2014 Try this it should work and dont forget to add it in the search path file option tab (setq prgpath "C:/AutoCAD/All/support/DEVELOP/") Test on AC1012: Command: _appload DEVELOP.LSP successfully loaded. Command: Command: Command: DEV ; error: quit / exit abort There when I add backslash: Command: (LOAD "C:/ACAD ALL SUPPORT/DEVELOP/DEVELOP.LSP") ; error: malformed string on input. Sorry can"t enable code wrapper Quote Link to comment Share on other sites More sharing options...
ROBP Posted April 7, 2014 Share Posted April 7, 2014 Test on AC1012: Command: _appload DEVELOP.LSP successfully loaded. Command: Command: Command: DEV ; error: quit / exit abort There when I add backslash: Command: (LOAD "C:/ACAD ALL SUPPORT/DEVELOP/DEVELOP.LSP") ; error: malformed string on input. Sorry can"t enable code wrapper this is what you must have in the lsp file on the 30th line from the bottom (setq prgpath "C:/AutoCAD/All/support/DEVELOP/") path all seperated with the back slash as above with the last one also after develop as per above. Mine in on the desktop and here what is the path in the 30th line from the bottom (setq prgpath "C:/USERS/Robert Perron/DESKTOP/DEVELOP/") and it works fine Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 7, 2014 Share Posted April 7, 2014 Paths are unique to the user. What works for one won't necessarily work for another. Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 7, 2014 Share Posted April 7, 2014 I'm glad you like it but I have no need for your friend's program as I still use the one written by The Buzzard (the person who started this thread and donated his code). Thanks anyways. Quote Link to comment Share on other sites More sharing options...
ROBP Posted April 7, 2014 Share Posted April 7, 2014 I'm glad you like it but I have no need for your friend's program as I still use the one written by The Buzzard (the person who started this thread and donated his code). Thanks anyways. i use buzzard's on too but mine does other stuff you should load and have a look at it kind of complete ones need's to draw legs and cones along with holes in shells. R Quote Link to comment Share on other sites More sharing options...
mdbdesign Posted April 8, 2014 Share Posted April 8, 2014 Post #122 and #123 with backslash and without. I did change this line. Will try tomorrow to disable path line. Quote Link to comment Share on other sites More sharing options...
digger Posted April 10, 2014 Share Posted April 10, 2014 See Post#105 and Post #106 for code. Quote Link to comment Share on other sites More sharing options...
AFitchguy07 Posted April 10, 2014 Share Posted April 10, 2014 this one is for do it yourself sizes. I've managed to change the layers within the LSP file. I do have one left over issue i cannot seem to resolve... how do i remove the section which loads linetype "hidden2" as i do not use that linetype for my hidden layer. I know it's simple and just purge or LT and delete. But i'm curious how i can stop this behavior. Any input? Quote Link to comment Share on other sites More sharing options...
jorgeo79 Posted December 17, 2014 Share Posted December 17, 2014 Primer Post, Excelente Utilidad Saludos !!! Quote Link to comment Share on other sites More sharing options...
ProvoZA Posted April 4, 2015 Share Posted April 4, 2015 I am new to this forum, although I have been a lurker for quite a while and have benefited greatly from all the advice given here. But I need some assistance for 3D dished ends and this may not be the right thread to ask for help. But you guys seem to be very knowledgeable on LISP code and especially Buzzard's dished end code. Is there any way that Buzzard's code will put the dished end in the Z axis. I have used his LISP code to produce dished ends, but they always draw on the X or Y axes. I want to make a 3D dished end, but I am not able to do so. Any assistance will be appreciated. Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 4, 2015 Share Posted April 4, 2015 What is so difficult about rotating the dished head after creating it in the X/Y axis? Quote Link to comment Share on other sites More sharing options...
ProvoZA Posted April 4, 2015 Share Posted April 4, 2015 As I said, I have done many 2d drawings, but this is my first foray into 3D. I have tried the REVOLVE command, but all I get is strange shapes. I want to add the dished end to a cylinder, which is a standard 3D shape, but I have no idea how to create the dished end in 3D. Buzzard's LISP helped me create the 2D dished end, but it is only a 2D shape. Quote Link to comment Share on other sites More sharing options...
mdbdesign Posted April 4, 2015 Share Posted April 4, 2015 it always work great, need to know how. See below: Quote Link to comment Share on other sites More sharing options...
ProvoZA Posted April 4, 2015 Share Posted April 4, 2015 Ok, thanks. I got it to work, but the dished end is as per your drawing. Please have some patience with me, I do not know many of the 3D commands. How do I rotate the dished end so that the opening is horizontal. The tank will be a vertical tank with legs attached to the dished end. Thanks. Barry Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 5, 2015 Share Posted April 5, 2015 Reorient your UCS then rotate the head. Quote Link to comment Share on other sites More sharing options...
ProvoZA Posted April 5, 2015 Share Posted April 5, 2015 Thanks for all the help. I was able to get the dish into the correct orientation. Quote Link to comment Share on other sites More sharing options...
shawn8888 Posted October 15, 2015 Share Posted October 15, 2015 how do you edit this code Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 15, 2015 Share Posted October 15, 2015 how do you edit this code Why would you want to edit the code? I'd have to take another look since it has been a while since I used the program. I thought the program was compiled but I could be wrong. Quote Link to comment Share on other sites More sharing options...
