ReMark Posted May 24, 2010 Posted May 24, 2010 The OP has all his dimensions and text in model space but wants to utilize layouts and paper space. Quote
ReMark Posted May 24, 2010 Posted May 24, 2010 Since everything is in model space the key to keeping dimensions from being different sizes in different viewports is to set up different sized dimensions on their own layers. These can then be controlled by freezing or thawing them as required. Example: You might want to use two dimension scales; 1/8 and 1/4. You could set up a layer called DIM96 (for the 1/8th) and DIM48 (for the 1/4). Quote
Pablo Ferral Posted May 26, 2010 Posted May 26, 2010 ...That's a much simpler way of saying what I was trying to get at... 8-\ Quote
