MSasu Posted August 2, 2010 Posted August 2, 2010 @ReMark: Seems that this variable affects only coordinates inputted by dynamic point prompt, not the classical input using Command Line. Regards, Quote
bassmaster_m Posted August 5, 2010 Posted August 5, 2010 Hi all, Looks like this thread is more or less wrapped up, but I thought I'd just toss in my two cents: If one has their AutoCAD set-up so that input co-ordinates are defaulted as relative points, when absolute points are required (such as with the OP's rectangle) you can just throw a # sign in front of the x,y values to designate the co-ordinate as absolute. This way you don't have to mess around changing system variables as I find that 99% of the time I use relative input. eg: 30,250 (first point of rectangle - this is a relative co-ordinate but it works because it is relative to the origin, making it the same as an absolute point) #230,250 (absolute co-ordinate/relative to origin) #230,120 (absolute co-ordinate/relative to origin) #30,120 (absolute co-ordinate/relative to origin) C (close polyline) done deal! cheers, mw Quote
