biglow79 Posted August 19, 2010 Share Posted August 19, 2010 I am trying to draw details at multiple scales in one drawings, ex. 3"=1'-0", 1 1/2"=1'-0", 3/4"=1'-0" and have come across a problem. I am only allowed to have one ltscale per drawing, so how can I make the lines (dashed lines, centerlines, etc.) show up correctly??? Quote Link to comment Share on other sites More sharing options...
lpseifert Posted August 19, 2010 Share Posted August 19, 2010 You could use a different a Celtscale for the lines, but it would probably be better to use different viewports (in the layout tabs) with different scale factors. Be sure to set the Psltscale=1 in each layout tab. Quote Link to comment Share on other sites More sharing options...
biglow79 Posted August 19, 2010 Author Share Posted August 19, 2010 I guess this is my confusion. I want to have a 3"=1'-0" viewport in PS right next to a 3/4"=1'-0" viewport and they need to have different ltscales, but when i am in PS and I change the ltscale, it changes it for all the viewports. I am not familiar with CELTscale Quote Link to comment Share on other sites More sharing options...
lpseifert Posted August 19, 2010 Share Posted August 19, 2010 Set the Ltscale=1 and leave it alone (you already figured out why). Set Psltscale=1 (per layout tab) and the linetypes in the 2 viewports should display/plot the same. If you set Msltscale=1 the linetypes in the Model tab will display per the current annotation scale (independent from the display in the PS viewports). Quote Link to comment Share on other sites More sharing options...
