NoneShallSleep Posted August 25, 2010 Posted August 25, 2010 I looked around, and couldn't find anything that answered this question specifically. So here goes: I've got hidden viewports to show my 3D objects in. These objects require label text that I've created in paperspace to align with them. Is there any way to get the text to plot as solid instead of outlined from these viewports set to hidden? Thank you in advance! Quote
Cad64 Posted August 26, 2010 Posted August 26, 2010 The Shademode setting of your viewport should not affect your paper space text. At least it doesn't in 2010. Not sure about 2006 though? What font are you using? Quote
NoneShallSleep Posted August 26, 2010 Author Posted August 26, 2010 I'm on 2006 ... If I set the viewport to wireframe the text will print solid, but then that also renders the 3D objects in wireframe. Quote
