Can a lisp be used to force a value change of a specific tag?
The titleblock has a multitude of attributes with the same tag...
My employer's former titleblocks (for use with LDD 2006) had this same issue, and it was very frustrating.
Our solution...
Late last year (yeah, 3+ years we used the old stuff! :sick:), we re-created all of our titleblocks with *unique* attributes, deployed LDC 2009, and also rolled out .dst files which include custom properties (linked to the attributes) for use with SSM. :thumbsup:
  • Replies 51
  • Cat
    20
  • David Bethel
    12
  • BlackBox
    12
  • Lee Mac
    5
Posted Images
That's ugly....
Is there any logic to the scenario? 1st tag is always the name, 2nd the date, 3rd the city etc?
Do you have the handle values? and their respective descriptions?
-David
David,
I think I've reached the end of the rainbow as far as being able to maintain their titleblock.
It seems these guys have no clue that "Text" exists. The handles are NOT consistent from drawing to drawing. The only consistency is the Prompt they used per revision.
I think I only have three options. Edit them manually, redine an edited titleblock or special explode them and run a script to revise the text.
there....I said it....THERE IS SUCH A THING AS "TEXT".
You know, we could really use an emoticon that pulls it's hair out or strikes a match and sets it's head on fire.
Did you expect them to be? Handles are uniquely generated by AutoCAD for each object and remain fixed for the lifetime of the object.
Just curious...
Do these like-named attributes have similar insertion points from drawing to drawing (i.e., the Titleblock is always inserted at 0, 0 in paperspace)..?
If not, are said attribute insertion points relative to the insertion point of the Titleblock...?
Actually, now that the fog has lifted....no....I don't expect them to be.
But honestly, after mucking about in these particular drawings for over a week I have developed a Rhett Butler attitude....."Frankly, my dear, I don't give a ........"
RenderMan, no....the folks that did these drawings evidently aren't familiar with the way things should be done.
This is what I'm dealing with. They were last done in ELCAD and may have started out in Promise-E, I'm not sure. I tried to attach a pdf, but the file was to large. They have everything but the kitchen sink embedded in these dwgs.
Prompts are good enough.
The ATTDEFs and ATTRIButes can be deciphered as long as no one has (entmod) certain parts of the ATTRIB Def in the INSERT ( groups 7, 10, 11, 50, & 51 ) or actually deleted or added ATTRIBs via Autolisp.
As to the handles, I would have to check, but if the titleblock is part of the template file, they might be consistent.
-David
vla-get-promptstring, and vla-put-textstring, perhaps?
Example:
(defun c:FOO  (/ eName blockObj blockName blockItem attPrompt)
 (vl-load-com)
 (if (and (setq eName (car (entsel "\n  >>  Select Attributed Title Block: ")))
          (setq blockObj (vlax-ename->vla-object eName))
          (= "[color=red]TitleBlockName[/color]" (setq blockName (vla-get-effectivename blockObj)))
          (setq blockItem (vla-item
                            (vla-get-blocks
                              (vla-get-activedocument
                                (vlax-get-acad-object)))
                            blockName))
          (= :vlax-true (vla-get-hasattributes blockObj)))
   (foreach attrib  (vlax-invoke blockObj 'GetAttributes)
     (vlax-for item  blockItem
       (if (= "AcDbAttributeDefinition" (vla-get-objectname item))
           (if (= (vla-get-tagstring attrib)
                  (vla-get-tagstring item))
          (cond
            ((= "[color=red]Prompt1[/color]"
                (setq attPrompt (vla-get-promptstring item)))
               (vla-put-textstring attrib "[color=red]NewString1[/color]"))
            ((= "[color=red]Prompt2[/color]" attPrompt)
             (vla-put-textstring attrib "[color=red]NewString2[/color]"))
            ((= "[color=red]Prompt3[/color]" attPrompt)
             (vla-put-textstring attrib "[color=red]NewString3[/color]"))))))))
   (prompt "\n  <!> Invalid Selection  <!> "))
 (princ))
Thank you RenderMan. I'll give it a try.
Well, I attempted to adapt the code, but apparently I've made an error somewhere along the line :shock: because it puts my intials - TAC - in all the values.
Can this be modified as to not require user input per drawing? Assuming I can get beyond the initial issue?
(defun c:chgpromptvalue  (/ eName blockObj blockName blockItem attPrompt)
 (vl-load-com)
          (= "FBSTP2_ANSI" (setq blockName (vla-get-effectivename blockObj)))
                            (vla-get-blocks
                            blockName))
          (cond
            ((= "C Status (display)"
               (vla-put-textstring attrib "1"))
            ((= "C Revision (display)" attPrompt)
             (vla-put-textstring attrib "AS COMMISSIONED"))
            ((= "C Date (display)" attPrompt)
             (vla-put-textstring attrib "10-06-10"))
            ((= "C Name (display)" attPrompt)
             (vla-put-textstring attrib "TAC"))
            ((= "B Status (display)"
               (vla-put-textstring attrib " "))
            ((= "B Revision (display)" attPrompt)
            ((= "B Date (display)" attPrompt)
            ((= "B Name (display)" attPrompt)
            ((= "A Status (display)"
            ((= "A Revision (display)" attPrompt)
            ((= "A Date (display)" attPrompt)
            ((= "A Name (display)" attPrompt)
             (vla-put-textstring attrib " "))))))))
 (princ))
Perhaps this may be more to your liking (provided I've not overlooked something):
(defun c:chgpromptvalue  (/ ss)
 (vl-load-com)
 (if (setq ss (ssget "_x" '((0 . "INSERT") (2 . "FBSTP2_ANSI"))))
   ((lambda (i b / blockObj blockName blockItem attPrompt)
      (while (setq e (ssname ss (setq i (1+ i))))
        (if (and (setq blockObj (vlax-ename->vla-object e))
                 (setq blockItem (vla-item b blockName))
              (if (and (= "AcDbAttributeDefinition"
                          (vla-get-tagstring item)))
                (cond
                   (vla-put-textstring attrib " ")))))))))
     -1
     (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))))
 (princ))
Renderman,
I really appreciate all of your efforts, but it's still putting my initials in all of the values. I thought it might be because I had used a space for the values in all the tags relating to A and B, but I replaced the spaces with a "." and it still uses my initials for all the values. It may be an issue on my end with these particular drawings.
That's too bad.
*IF* you can post a DWG of just the title block itself (2007 format or older), then I'd be willing to take one more crack at it. Without a drawing to look at, I'm not sure I can help.
That's too bad.
For better or worse, here's the titleblock. I appreciate you taking the time to have a look at it.
If it's too much of a pain, don't worry about it. I'll just blow them to kingdom come and be done with it.
TB.dwg
I've got the drawing, and I'll post back as soon as I can... This drawing is Sooooooooo Slllooooooooooooooooooooooooow! lol
I know....everytime I try to do anything with them, Autocad develops Dysentery.
Perhaps another way to code it Renderman - this should be much quicker:
(defun c:test ( / Block Attribs _MAssoc _dxf def l ss )
 ;; © Lee Mac 2010
 (setq Block "FBSTP2_ANSI")
 (setq Attribs ; Prompt . Value
      ("C Status (display)"   . "1")
      ("C Revision (display)" . "AS COMMISSIONED")
      ("C Date (display)"     . "10-06-10")
      ("C Name (display)"     . "TAC")
 (defun _dxf ( key lst ) (cdr (assoc key lst)))
 (defun _Massoc ( key lst / r )
   (foreach x lst
     (if (eq key (car x))
       (setq r (cons (cdr x) r))
   (reverse r)
 (if (setq def (tblobjname "BLOCK" Block))
   (while (setq def (entnext def))
     (if (eq "ATTDEF" (_dxf 0 (setq el (entget def))))
       (setq l (cons (cons (_dxf 2 el) (_dxf 3 el)) l))
 (if (and l (setq ss (ssget "_X" (list (cons 0 "INSERT") (cons 2 Block) (cons 66 1)))))
     (lambda ( i / e p v )
         (while
           (not
             (eq "SEQEND"
               (_dxf 0
                 (entget
                   (setq e (entnext e))
           (if (and (setq p (_Massoc (_dxf 2 (entget e)) l))
                      (while (and p (not (setq v (cdr (assoc (car p) Attribs)))))
                        (setq p (cdr p))
                      v
             (entupd
               (cdr
                 (assoc -1
                   (entmod
                     (subst (cons 1 v)
                       (assoc 1 (entget e)) (entget e)
     -1
Completely untested however.
>> Cat: Be sure that the Attribute Prompt list at the top is absolutely correct.
Edited by Lee Mac
Unfortunately, this code does not succeed either, Lee. :(
Edit: While I see the elegence in your code, I still do not understand (at a glance) why my cond statement allows for multiple attribute definitions (each with a different PromptString!) to trigger the same expression.
Sidebar - What's up with the 'Edit' feature not including the spell check button!? Edits don't need spell check!?? lol
Ahh no - course it won't needs a 'massoc' :oops:
Will this do the trick?
;;; Utility function to get multiple group code CDRs
(defun massoc (key alist / x nlist)
 (foreach x alist
     (setq nlist (cons (cdr x) nlist))
 (reverse nlist)
Edit: I've never heard of 'massoc' until I Googled it, so I'm not sure what to do with it (yet).
