Guest balajibth84 Posted October 18, 2010 Posted October 18, 2010 (edited) Hai here Balaji.May i know how to open and Edit or View the Code from the *.Fas??And how to find out the *.Fas Command(LIke i want to know the Inside of the *.Fas Command) ???Is it Possibel? Edited October 18, 2010 by balajibth84 For Clear Doubt Quote
ReMark Posted October 18, 2010 Posted October 18, 2010 Are you trying to decrypt/decompile a FAS file? Quote
rkmcswain Posted October 18, 2010 Posted October 18, 2010 You can't. Obtain the source code from the author. More info: http://cadpanacea.com/node/170 Quote
Lee Mac Posted October 18, 2010 Posted October 18, 2010 I'm guessing you didn't do a search before posting this thread... Just earlier today: http://www.cadtutor.net/forum/showthread.php?53463-Fast-load-AutoLISP-(FAS) Quote
Guest balajibth84 Posted October 18, 2010 Posted October 18, 2010 auto_move.zip Are you trying to decrypt/decompile a FAS file? Hai here I have Attached One *.Fas Lisp for u r reference.Here how can look the Code or i want to know the This Fas Code Cad Command.... Quote
ReMark Posted October 18, 2010 Posted October 18, 2010 I do not condone the decompiling or decrypting of someone else's code. And I don't think you'll find anyone else here at CADTutor that does either. I was trying to determine your intent and I have. I suggest you stop asking about this topic and move on to something else we can assist you with. Quote
mdbdesign Posted October 18, 2010 Posted October 18, 2010 [ATTACH]23944[/ATTACH] Hai here I have Attached One *.Fas Lisp for u r reference.Here how can look the Code or i want to know the This Fas Code Cad Command.... You need to type "zx" to run program if that was question. Quote
Guest balajibth84 Posted October 18, 2010 Posted October 18, 2010 Hai hw u r find out that Command ?????May i know?? Quote
mdbdesign Posted October 18, 2010 Posted October 18, 2010 Drag and drop fas file into open Autocad and read command line. Quote
ReMark Posted October 18, 2010 Posted October 18, 2010 Drag and drop fas file into open Autocad and read command line. It generates this: Command: ZX ; error: bad argument type: FILE nil Can't believe everything you read I guess. Quote
Se7en Posted October 18, 2010 Posted October 18, 2010 Speaking academically, at one time i thought the FAS format was fascinating. I just took a real quick look at this one and i noticed right away that they changed the FAS file format since i have done research on it (Strings are now better crypted for one) but some things are "still in the same place". For example: this file has a main stream length of 259 with 29 strings the function stream has a stream length of 640 and 9 strings, and it *was* compiled on 03/29/10. Quote
mdbdesign Posted October 18, 2010 Posted October 18, 2010 Hai hw u r find out that Command ?????May i know?? Just "simple" answer. Need to find out what happen after balaji try to start codes... Quote
Lee Mac Posted October 18, 2010 Posted October 18, 2010 Wow, you guys are brave... I would never run a compiled fas/vlx from an untrusted source - you don't know what might be coded inside... Quote
ReMark Posted October 18, 2010 Posted October 18, 2010 Yeah true. Right at this very moment every file on my hard drive is being erased and I can't stop it from hap.................... Quote
The Buzzard Posted October 18, 2010 Posted October 18, 2010 Yeah true. Right at this very moment every file on my hard drive is being erased and I can't stop it from hap.................... ReMark! You must suffer for your code! Quote
Se7en Posted October 18, 2010 Posted October 18, 2010 Wow, you guys are brave... I would never run a compiled fas/vlx from an untrusted source - you don't know what might be coded inside... heh, no kidding. I thought the same thing. Quote
ReMark Posted October 18, 2010 Posted October 18, 2010 Too late now. All the text in my drawings have been changed to the Tamil language. I may have to get an Indian to English translation program. Quote
Lee Mac Posted October 18, 2010 Posted October 18, 2010 lol, you joke, but just changing a few registry values in a LISP can seriously screw up your system... Quote
mdbdesign Posted October 18, 2010 Posted October 18, 2010 Too late now. All the text in my drawings have been changed to the Tamil language. I may have to get an Indian to English translation program. Don't worry, balaji will write lisp conversion program with dialog and alert box, it is simple coding... Quote
ReMark Posted October 18, 2010 Posted October 18, 2010 I wouldn't hold my breath if I were you. Quote
