Why can you not write your words in full :cry:
It would almost enable people to read your demands :shock:
I believe there is a genuine language barrier, but that is easily overcome.
Overcoming the rude, impatient, discourteous, sense of entitlement... that's the biggest obstacle.
  • Replies 46
  • BlackBox
    7
  • ReMark
    6
  • Cad64
    6
  • jammie
    5
Guest balajibth84
hay i am asked its possible?y u r getting tension?y u r telling we r not teenage girl....plz talk related the topic plz......
bala:
Please use complete words we aren't "texting" here.
Your request for this particular code seems to have no basis in reality. What are you really trying to accomplish here?
I sense that you are trying to make something that is simple (multiple offsets) more complex than it has to be. What's the point?
Guest balajibth84
ok..iu am not asking multioffset..i am try to fix shortcut for offset...so r using the offset(Single line not multiple line) more time.so only i am asking thaty short cut..we r using more time 1,2,3,10,20,25,50,100,300,500..Etc...So i am using the short code for this regular numbers....each and every time i am need new number means i am paste that code and insert that neede text..So we r giving the number 1to15000 means i dont want edit that code every time......we r using offset more time...So only i am asking this short form...
(defun c:250()
(command "offset" "250" ))
Here i want 300 means i want to copy this and insert 300..So here i want to give 1 to 15000....
I like at that and cannot help but feel it is needlessly pointless. It's seems a waste of both time and effort.
Yes, lisp is supposed to speed things up especially repetitive/complex tasks but this one is so simple it begs the question "Why bother?"
I don't understand how this makes your work any easier. All you're doing is eliminating the need to type "o" to start the offset command. But if this is really what you want, then why don't you just create these lisp routines yourself? You already have the code, all you have to do is change the numbers and save to a separate file.
Start with this:
(defun c:250()
Change to this:
(defun c:300()
(command "offset" "300" ))
Save As 300.lsp
Now just do that 15,000 more times. :lol:
Wouldn't that be 14,998 more times? You already created two of the routines for him!:lol:
... Please post your code when you have all 15,000 of them, will you...!? o:)
Start with this:
(defun c:250()
Change to this:
(defun c:300()
Save As 300.lsp
... and without
 tags too, tisk, tisk. Can we get some moderator action?? lol :P
Oops, you're right. Damn, see I ended up giving him code. I broke my own rule. :oops:
... and without
Fixed quote tags. :P
These guys are brutal. Brutal I tell you! :ouch: :lol:
Yes, it is possible. You've demonstrated a few yourself. There are plenty of ways to accomplish this - quickly - with LISP, but since you are clearly not receiving the results you continuously and hastily demand, just write them yourself. Hell, if you break the command up in Excel, you could easily have it increment the number and then combine the columns to have what you want.
However, I agree with eldon, Remark, etc.; this is such a waste of time and resources. Just type precede typing each number with O and depressing the enter/spacebar/right-click.
I said it once before on here and I'll say it again: just because a LISP can be written for something, doesn't mean it should be.
"Just because a LISP can be written for something, doesn't mean it should be."
I think you just found your new signature.
Maybe it should be the forum's secondary slogan.
The biggest problem with this idea is clogging up your startup with loading 15,000 LISP routines (in addition to anything else that's being loaded) that will never save you more than a nanosecond. You'll waste more time on startup/loading than you'll save on your new 'cool' macros.
Thats a fair point. From my earlier post theres no need to define new commands on the fly. As is VVA's post I think its best just to change the offset distance
(defun c:endOffset()
 (if *unknownReactor* (vlr-remove *unknownReactor*))
(defun c:beginOffset ()
 (or *unknownReactor* (setq *unknownReactor* (vlr-command-reactor nil '((:vlr-unknownCommand . createOffset)))))
 (defun createOffset (<rea> <args> / acadDoc cmd offsetDist )
   (setq acadDoc (vla-get-activedocument (vlax-get-acad-object ))
  cmd     (car <args>))
   (if
     (and
(not (equal (setq offsetDist (atoi cmd))  0.0 1e-6))
(< 1 offsetDist 15000)
     (setvar 'offsetdist offsetDist)
     (vla-sendcommand acadDoc  (strcat  "._offset  "))))
(c:beginOffset)
(princ "\nReactor started. Type endOffset to stop")
Guest balajibth84
  cmd     (car <args>))
   (if
     (and
(c:beginOffset)
Hi While i am using this Code error Is Coming.After loading the Code(Command: ; error: no function definition: VLR-COMMAND-REACTOR)
You may be missing
(vl-load-com)
in the code.
You may be missing
(vl-load-com)
in the code.
Thanks for that
VLR-COMMAND-REACTOR is part of the Visual Lisp extension of AutoLISP
This part of the code is what creates a command reactor.
As per The Buzzards post you need to add (VL-LOAD-COM) to the top of the code. It loads the ActiveX & Command Reactor support
Edited by jammie
