Thats a fair point. From my earlier post theres no need to define new commands on the fly. As is VVA's post I think its best just to change the offset distance
(defun c:endOffset()
(if *unknownReactor* (vlr-remove *unknownReactor*))
(defun c:beginOffset ()
(or *unknownReactor* (setq *unknownReactor* (vlr-command-reactor nil '((:vlr-unknownCommand . createOffset)))))
(defun createOffset (<rea> <args> / acadDoc cmd offsetDist )
(setq acadDoc (vla-get-activedocument (vlax-get-acad-object ))
cmd (car <args>))
(if
(and
(not (equal (setq offsetDist (atoi cmd)) 0.0 1e-6))
(< 1 offsetDist 15000)
(setvar 'offsetdist offsetDist)
(vla-sendcommand acadDoc (strcat "._offset "))))
(c:beginOffset)
(princ "\nReactor started. Type endOffset to stop")
Hi Jammie,
First congratulations for his work.
I work with "CAD2002" and the routine goes in a loop when I type the decimal value for example: 1.5 ... 2.6 ... 10.3...
That is, only runs with integers.
Thanks in advance.
  • Replies 46
  • BlackBox
    7
  • ReMark
    6
  • Cad64
    6
  • jammie
    5
Hi Jammie,
Thanks in advance.
Replace createOffset sub with this one:
  (defun createOffset (<rea> <args> / off)
   (if (and (setq off (distof (car <args>))) (> off 0.))
     (vla-sendcommand
       (cond (*AcadDoc*)
             ((setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object))))
       (strcat "_.offset " (rtos off) " ")
(vla-sendcommand
(cond (*AcadDoc*)
Cool code Alan.
Thanks for your help.
Cool code Alan.
You're welcome.
Hi Jammie,
Thanks for that scamaru, glad you are getting some use of the code.
Alan thanks for the code update
Regards
Jammie
Regards
Jammie
error at lisp
error: malformed list on input
(vl-load-com)
     (vla-sendcommand
       (cond (*AcadDoc*)
(c:beginOffset)
Hi Autolisp,
You appear to be missing a closing bracket in the function c:beginOffset. This is what is causing the error : malformed list on input
Jammie
