sisterh00dz Posted October 27, 2010 Posted October 27, 2010 I just downloaded Autocad 2010, after installation, i click the launch shortcut at my desktop. But i can't seem to go past this error message: "UNABLE TO RUN AUTOCAD. THIS MAY BE DUE TO ONE OF THE FOLLOWING REASONS: 1. THIS VERSION OF AUTOCAD WAS NOT INSTALLED PROPERLY..... 2. YOU DO NOT HAVE SUFFICIENT RIGHTS I have been uninstalled it a number of times, but the error message still continues... Please help me anyone! Thanks! (: Quote
ReMark Posted October 27, 2010 Posted October 27, 2010 Do you have sufficient rights? There is a recommended procedure for uninstalling AutoCAD before trying to reinstall. I don't suppose you knew that did you? Quote
sisterh00dz Posted October 27, 2010 Author Posted October 27, 2010 i certainly didn't know of that... but do you know where can i find that procedure? Quote
ReMark Posted October 27, 2010 Posted October 27, 2010 Read this: http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240617&id=2887771&siteID=123112 Do you have full admin rights to the computer you are using? What OS are you running? Quote
sisterh00dz Posted October 27, 2010 Author Posted October 27, 2010 I have followed the steps in deleting properly. I'm using Windows 7. I will try installing again. Quote
Jack_O'neill Posted October 27, 2010 Posted October 27, 2010 This is the second person I've seen on this forum to have this problem, and I had it myself on a client's XP machine. The problem I has was that it was already installed, I'd been using it for months, and it just started doing this. Gives the same error. And to add more craziness yet, Trueview did it too and it had been on there longer than 2010. That machine did contract a virus that I had to get a pro to remove and it started it after that. Don't know if that had anything to do with it or not. I was almost finished with what I was doing for them, so I wrapped up that project at home. Never did figure out how to get it to work, and I don't know if they ever got it resolved. Thier IT guy was going to reformat the harddrive and reinstall everything. Quote
sisterh00dz Posted October 28, 2010 Author Posted October 28, 2010 so you mean i have to reformat my harddrive? I tried installing it for the 6th time... still the same error. Quote
ReMark Posted October 28, 2010 Posted October 28, 2010 (edited) I would not recommend reformatting your hard drive. This is the third and last time I'm going to ask the question... Do you have full admin rights to your computer? You wrote in your first post that one of the messages you were getting was... "YOU DO NOT HAVE SUFFICIENT RIGHTS" Read this: http://www.howtogeek.com/howto/windows-vista/enable-the-hidden-administrator-account-on-windows-vista/ Edited October 28, 2010 by ReMark Quote
Jack_O'neill Posted October 28, 2010 Posted October 28, 2010 I wouldn't recommend formatting the hard drive either. The IT guy at that company uses that as a solution for anything he can't figure out. In my case, I did have full admin rights, as I said, it was working and then suddenly stopped. This link has a possible solution: http://avatechsupport.blogspot.com/2009/09/failed-to-launch-autocad-2010.html Seems that the problem is widespread and has to do with the .NET Framework 3.51 sp 1 install, or at least that's what this link talks about. Quote
Jack_O'neill Posted October 28, 2010 Posted October 28, 2010 Here is another link that mentions an error in the registry that may cause it, and if not goes on to talk about the .NET installation too. http://appliedtg.wordpress.com/category/launching-issues/. The error we've been discussing is the second article on the page. I didn't find any of this information when I was having the problem, so maybe enough people have squawked about it now that there are some solutions churning to the surface. Quote
ReMark Posted October 28, 2010 Posted October 28, 2010 Wouldn't a problem with the .NET Framework be a bit more obvious? Quote
Jack_O'neill Posted October 28, 2010 Posted October 28, 2010 I dunno...would it? It's seem pretty obvious to me if things stop working after the service pack is installed. I didn't think about it at the time, but the place i mentioned kept all the automatic updates turned on, so it may have downloaded that service pack without me being aware. It updated something or other often enough that I got so I ignored it. I have automatic updates turned off here (if it ain't broke, don't fix it) except for my antivirus. Don't get me wrong, I really don't know enough about .net to discuss it but nearly every site I went to looking for an answer to this question today had something to do with either registry errors or .net framework problems. Is it the problem? I really don't know. Quote
ReMark Posted October 28, 2010 Posted October 28, 2010 I've seen where .NET Framework problems crop up when someone tries updating .NET and fails to follow recommended procedures for uninstalling one version and installing another. I'm aware that back in 2008 there was a bug in NET Framework 3.5 SP1 for which MS released a hotfix. Maybe it's a problem with the OP's antivirus program? Quote
sisterh00dz Posted October 30, 2010 Author Posted October 30, 2010 I have tried running the software in full admin rights using administrator account, but still, the same error occurs... Quote
ReMark Posted October 30, 2010 Posted October 30, 2010 I have tried running the software in full admin rights using administrator account, but still, the same error occurs... If that is the case then we're back to the "version not installed properly" error. Just to verify, you have a 32-bit (pr 64-bit) system and you are installing a 32-bit (or 64-bit) version of AutoCAD? I don't understand why you are having so many problems. Quote
Jack_O'neill Posted October 30, 2010 Posted October 30, 2010 I've dug through dozens of pages on the Autodesk discussion forum about this problem, and it all keeps coming back to either a corrupted .net file, a registry error, or both. The solution that keeps getting suggested there is to completely uninstall the offending autodesk product and all versions of the .net framework, then reinstall the autodesk product. I say "product" because this problem affects a wide range of different packages. Quote
sisterh00dz Posted October 31, 2010 Author Posted October 31, 2010 I'm using a 32 bit OS... i download the 32 bit version too. if i want to fully uninstall autocad, how do i do it? right now i'm just uninstalling from control panel-programs. Quote
Cad64 Posted October 31, 2010 Posted October 31, 2010 Clean Install Procedure: http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240617&id=2887771&siteID=123112 Quote
sisterh00dz Posted November 2, 2010 Author Posted November 2, 2010 Thanks everyone for their time in giving me advice! I have solved the problem by reformatting my laptop aha! now my autocad can load as normal (: Quote
Jack_O'neill Posted November 2, 2010 Posted November 2, 2010 That works too. At least you got it to work. Congrats. Quote
