sparkyuk Posted November 11, 2010 Posted November 11, 2010 Hi I'm using autocad 2008, and up till now I have never had to draw a 600x600 ceiling grid into a room (I always adjust what others have done before me), now i can do it in a lot of different ways but are all time consuming, but i bet there is a easy auto fill/fit way of doing this, so can anyone help me out please ?. Quote
ReMark Posted November 11, 2010 Posted November 11, 2010 The ARRAY command? Or.... Someone, somewhere probably wrote a lisp routine to do it. Quote
sparkyuk Posted November 11, 2010 Author Posted November 11, 2010 Good Morning Remark thanks and yes array can make 600x600 shapes as many as needed for square room, but it will not auto fill to size of room, unless im doing it wrong ? Quote
ReMark Posted November 11, 2010 Posted November 11, 2010 "...auto fill to size of room..." Looks like I missed one minor but very important detail. So it sounds like you need a lisp routine that can be used for any configuration/size room with any size grid layout. Right? Quote
sparkyuk Posted November 11, 2010 Author Posted November 11, 2010 Been looking it up on net, seems architect has it built in ? http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240657&id=6043627&siteID=123112 Quote
ReMark Posted November 11, 2010 Posted November 11, 2010 Cgrid.zip A routine that draws a ceiling grid centered on the user defined room. Download it here: http://www.cadcorner.ca/lisp.php Let us known how well it works. Or... Ceiling Grid Enhanced here at Cadalyst magazine: http://cadtips.cadalyst.com/misc-user-tools/celing-grid-enhanced We expect a full report on the pros and cons of each. Hurry up, we're waiting. Quote
sparkyuk Posted November 11, 2010 Author Posted November 11, 2010 I would try these out but havnt a clue on how to use a lisp file lol, off to find out ---------------> Quote
ReMark Posted November 11, 2010 Posted November 11, 2010 I would try these out but havnt a clue on how to use a lisp file lol, off to find out ---------------> No way dude! Say it ain't so. See the CADTutor AutoCAD FAQ section and look under Customization. And hurry up, time's a wastin'. Quote
sparkyuk Posted November 11, 2010 Author Posted November 11, 2010 Ok the first one says its an unreg version and stop with error: An error has occurred inside the *error* functionFunction cancelled and the second one loads and runs but after tracing the outline using pline, its comes up with this error ; error: An error has occurred inside the *error* functiontoo many arguments so still no luck, but i have not given up yet , but will try again later Quote
ReMark Posted November 11, 2010 Posted November 11, 2010 Test both routines on a simple square, small, room. How do they perform? Quote
sparkyuk Posted November 11, 2010 Author Posted November 11, 2010 The first one wont run at all need to buy it from him,I did try that on the other one to check it but and it was the same so still no luck Quote
ReMark Posted November 11, 2010 Posted November 11, 2010 Buy it? OK. I thought it was a freebie. Sorry. And no luck on the second? That sucks. Search here at CT maybe something has been written that I'm not aware of. Sorry but I'm kind of busy at the moment. Quote
David Bethel Posted November 11, 2010 Posted November 11, 2010 Here's a routine that works for rectangular shaped rooms. It defaults to imperial standard sizes, but should work with metric as well. Have fun! -David CEILGRID.LSP Quote
sparkyuk Posted November 12, 2010 Author Posted November 12, 2010 Cheers David that works a treat, in the uk we do not show the ceiling grid size on the lay out just the tile size, but that was easy to get over, thanks again nice one Quote
David Bethel Posted November 12, 2010 Posted November 12, 2010 Cheers David that works a treat, in the uk we do not show the ceiling grid size on the lay out just the tile size, but that was easy to get over, thanks again nice one You're welcome. I assumed that you were looking for 3D stuff. We don't show width in 2D here either. I guess I could add a 2D Option. -David Quote
sparkyuk Posted November 12, 2010 Author Posted November 12, 2010 No David 2D is all we use, 3D is not something we come across in our field, thanks again Quote
David Bethel Posted November 12, 2010 Posted November 12, 2010 Ok, it's early here and I had a minute. 2D \ 3D Grid Options v3.3 Irregular shaped rooms would take a completely different approach. Have fun! -David CEILGRID.LSP Quote
autolisp Posted November 13, 2010 Posted November 13, 2010 Ok, it's early here and I had a minute. 2D \ 3D Grid Options v3.3 Irregular shaped rooms would take a completely different approach. Have fun! -David Dear Sir, Nice Code One more request add dialog box, I thing more flexible. Quote
BIGAL Posted November 15, 2010 Posted November 15, 2010 If you just want grid lines of any size not actual tiles with mortar joints then its easy theres a hatch pattern called net which is a grid. Its imperial /iso in acad.lin a bit of simple renumbering and hay presto for mm just enter grid size as scale factor. *NET,Horizontal / vertical grid 0, 0, 0, 0, 3.175 90, 0, 0, 0, 3.175 *NETtile,Horizontal / vertical tiles 0, 0, 0, 0, 1.0 90, 0, 0, 0, 1.0 Quote
