Layer color changes back to original color.
Patrick Jones
 Share
Recently i changed the layer color for a drawing in AutoCAD. However, each time i would use one of my layer states, the layer would change to the previous color.
SOLUTION:
Since i use layer states quite frequently, i keep a drawing with them saved in a prototype directory. All i had to do to fix the problem above was re-save the layer states with the new layer color. And then export them out as files (if you use layer states as often as i do, you know what I'm talking about).
Hope this helps!
Patrick
 Share
