iuliandonici
LAYER status issue
iuliandonici
Hi again,
I would like to know why can't I use my layers, the ones that TURNED white while trying to import a layer state. Why aren't they "enabled" like the other layers?
Share this post
Link to post
tzframpton
I believe that just means they are unused. In other words, nothing is on that layer. Move something to one of those layers, and check the Status. It should be filled blue and not grayed out.
Share this post
Link to post
BlackBox
The layer's 'status' simply indicates if there are objects on that layer or not. :wink:
To test this... try placing some objects on one of the 'white' layers (i.e., layers not in use), and then re-open the layer properties manager.
Share this post
Link to post
iuliandonici
Thank you, it worked!
Share this post
Link to post
