cbat Posted June 2, 2011 Share Posted June 2, 2011 I use Autocad 2011, I'm a bit of a Cad newb, and I appear to have somehow messed up my right click short-cut menu settings. Before, I could right-click and get all of the edit options (delete, move, rotate, draw order, properties, select similar, etc.). I could get these options whether an object was selected or not. Now, my options are the "default" ones (Repeat, Pan, Zoom, Quick calc, etc, to name a few). This happened after I made an adjustment to the drawing in a viewport. Ie. I was in layout, clicked into model space to draw a line, then clicked back to paper space. I NEVER do this (I always switch back to model to edit), except for this one time. Also, if I select an object and hit "delete" on the keyboard, nothing happens. I've already tried adjusting the "shortcutmenu" command number, and nothing really changes in the shortcut menu itself. Also, when keying in a command, the keystrokes used to show up beside my cursor, but now they show only in the command line at the bottom. That's not really a big deal, but I did like the previous function. Any advice anyone could give me would be much appreciate. Remember I'm a newb, so please provide step-by-step instructions, if possible. Thanks! Quote Link to comment Share on other sites More sharing options...
nestly Posted June 2, 2011 Share Posted June 2, 2011 If you can't delete using the Delete Key, then Noun/Verb Selection is almost certainly turned off. Tools > Options > Selection > Noun'/Verb Selection, or set the PICKFIRST variable to 1 at the Command line. If PICKFIRST is disabled (0) then that also explains why your context sensitive right-click menus don't work. The Input at your cursor is called Dynamic Input. You can turn it back on by clicking the Dynamic Input button on your Status bar, or by setting DYNMODE to 3 at the Command line. Switching from model to paper shouldn't have affected those settings. The typical culprit is escaping out of a LISP routine that doesn't have error correction. Also, welcome to Cadtutor Quote Link to comment Share on other sites More sharing options...
rkent Posted June 2, 2011 Share Posted June 2, 2011 I use Autocad 2011, I'm a bit of a Cad newb, and I appear to have somehow messed up my right click short-cut menu settings. Before, I could right-click and get all of the edit options (delete, move, rotate, draw order, properties, select similar, etc.). I could get these options whether an object was selected or not. Now, my options are the "default" ones (Repeat, Pan, Zoom, Quick calc, etc, to name a few). This happened after I made an adjustment to the drawing in a viewport. Ie. I was in layout, clicked into model space to draw a line, then clicked back to paper space. I NEVER do this (I always switch back to model to edit), except for this one time. Also, if I select an object and hit "delete" on the keyboard, nothing happens. I've already tried adjusting the "shortcutmenu" command number, and nothing really changes in the shortcut menu itself. Also, when keying in a command, the keystrokes used to show up beside my cursor, but now they show only in the command line at the bottom. That's not really a big deal, but I did like the previous function. Any advice anyone could give me would be much appreciate. Remember I'm a newb, so please provide step-by-step instructions, if possible. Thanks! Soujds like you have three separate issues. Pickfirst to 1 will let you use the delete key as you remember. The shortcut menu will show the options you remember after you have selected one or more objects. The commands at the cursor is the DYN dynamic input, see the DYN button at the bottom of the screen, toggle it on. Quote Link to comment Share on other sites More sharing options...
cbat Posted June 2, 2011 Author Share Posted June 2, 2011 Thanks for your advice. I've successfully solved the "delete" issue, and the commands at the cursor. My shortcut menu options are still not back to normal, however. Rkent, I'm not sure what you mean by "the shortcut menu will show the options you remember after you have selected one or more objects." Can you clarify? Nestly, how can I solve this "LISP routine" issue? Thanks again for your help! Quote Link to comment Share on other sites More sharing options...
rkent Posted June 2, 2011 Share Posted June 2, 2011 With no command active pick on a line, now right click on mouse. Quote Link to comment Share on other sites More sharing options...
nestly Posted June 2, 2011 Share Posted June 2, 2011 These are the default settings for AutoCAD2011 (SHORTCUTMENU = 11) If you're the only one that uses your computer for CAD and you don't know what a Lisp is, then that's probably not the problem, but for future reference, a lisp is programming code that automates certain autocad tasks. These programs often have to temporarily turn off some AutoCAD features such as PICKFIRST, Dynamic Input, OSNAPS, etc, but if the user uses ESCAPE before the program completes, often those features don't get restored to their previous settings. Quote Link to comment Share on other sites More sharing options...
cbat Posted June 2, 2011 Author Share Posted June 2, 2011 I'd already experimented with those and it hadn't worked, but now it's back to normal! Thanks very much for both your help! I really appreciate it! Quote Link to comment Share on other sites More sharing options...
SLW210 Posted June 3, 2011 Share Posted June 3, 2011 I used MVSETUP in a viewport and it reset PICKFIRST and all of my snaps. I expect better from freeware. Quote Link to comment Share on other sites More sharing options...
