Hello,
How to determine te smaller (and bigger) value,Y or X, for a polyline? I mean the Y coordinate on a polyline where Y has the minimum value for the whole polyline?
  • Replies 22
  • flopo
    6
  • BlackBox
    6
  • Tharwat
    4
  • pBe
    3
Posted Images
look at the min and max functions
also i think there was a post about this awhile back try to search for it
This would make a point at the lowest coordinate point of the selected Polyline that has the smallest Y value in it , besides that it would show the Coordinates of the Point which the point lays on . :)
(vl-load-com)
(defun c:test (/ ss Coords l i p p1 pt)
 ; Tharwat 15. 06. 2011
 (if (eq (getvar 'pdmode) 0)
   (setvar 'pdmode 3)
 (if
   (setq ss (ssget "_+.:L" '((0 . "*POLYLINE"))))
      (setq Coords (vlax-get (vlax-ename->vla-object (ssname ss 0))
                             'Coordinates
      (setq l (/ (length Coords) 2))
      (setq i 0
            p (cons 10 (list (car Coords) (cadr Coords)))
      (repeat l
        (setq
          p1 (cons 10
                   (list (nth i Coords) (nth (setq i (1+ i)) Coords))
        (if (< (caddr p1) (caddr p))
          (setq p p1)
        (setq i (1+ i))
      (print p)
      (entmakex (list (cons 0 "POINT") p))
Tharwat
*cough* GetBoundingBox *cough*
(defun c:GBB () (c:GetBoundingBox))
(defun c:GetBoundingBox (/ ss v mn mx)
 (vl-load-com)
 (princ "\rGET BOUNDING BOX \n")
 (if (and (setq ss (ssget ":S:E" ))
          (vlax-method-applicable-p
            (setq v (vlax-ename->vla-object (ssname ss 0)))
            'getboundingbox))
      (vla-getboundingbox v 'mn 'mx)
      (princ (mapcar 'vlax-safearray->list (list mn mx))))
    (cond (ss (prompt "\n** GetBoundingBox method not available ** "))
          ((prompt "\n** Nothing selected ** "))))
 (princ))
Untested - Written quickly on my MacBook from memory.
Edited by BlackBox
Code correction
Hi Renderman .
The (min max) are functions and you have used them as variables . Is that possible ? :)
(/ ss v [color=blue][b]min max[/b][/color])
Regards.
Tharwat
Hi Renderman .
I noticed that too when I came to work to test (code works BTW).
Sadly, it was a typo on my part typing code in the forum text box. :oops: Code corrected.
Here's some old code I wrote to find the Max/Min points of a curve:
(defun LM:CurveMinMax
 ( obj fuzz / _GetBoundingBoxWithOffset _GroupByNum _FlattenPoint a acdoc acspc lst obj tmp )
 (defun _GetBoundingBoxWithOffset ( obj o / ll ur )
     (lambda ( a )
       (mapcar
         (function
           (lambda ( b )
             (mapcar
               (function
                 (lambda ( c ) ((eval c) a))
               b
             (lambda ( x ) (- (caar  x) o))
             (lambda ( x ) (- (cadar x) o))
             (lambda ( x ) (+ (caadr x) o))
             (lambda ( x ) (+ (cadadr x) o))
       (progn (vla-getboundingbox obj 'll 'ur) (list ll ur))
 (defun _GroupByNum ( l n / r)
   (if l
     (cons
       (reverse (repeat n (setq r (cons (car l) r) l (cdr l)) r))
       (_GroupByNum l n)
 (defun _FlattenPoint ( p )
   (list (car p) (cadr p) 0.0)
 (setq acdoc (vla-get-activedocument (vlax-get-acad-object))
       acspc (vlax-get-property acdoc (if (= 1 (getvar 'CVPORT)) 'Paperspace 'Modelspace))
 (cond
   ( (not (vlax-method-applicable-p obj 'GetBoundingBox))
   ( t
     (setq tmp
       (mapcar
         (function
           (lambda ( x )
             (apply 'vla-addline (cons acspc (mapcar 'vlax-3D-point x)))
         (_GroupByNum (mapcar '_FlattenPoint (_GetBoundingBoxWithOffset obj (- fuzz))) 2)
     (setq lst
       (mapcar
         (function
           (lambda ( x )
             (car (_GroupByNum (vlax-invoke obj 'Intersectwith x acExtendOtherEntity) 3))
         tmp
     (mapcar 'vla-delete tmp)
     lst
;; Test Function
(defun c:test( / e m )
 (if
   (and
     (setq e (car (entsel)))
     (setq m (LM:CurveMinMax (vlax-ename->vla-object e) 1e-)
     (apply 'and m)
   (foreach x m
     (entmakex (list (cons 0 "POINT") (cons 10 x)))
Hi Renderman .
Regards.
Tharwat
It's "possible", since you can redefine anything in Lisp - and since they're localized variables they won't affect enything outside the defun - so the min & max functions wont be removed in other places. Though this is not recommended and would cause a warning message in VLIDE (something like protected symbol redefined).
Thank you .
I have faced that message before which made me panic for a long time and after searching in that time I have realized the main issue of it , and I doubt I may forget these memories with it and the perfect lesson that I had . :D
Regards.
  • 6 months later...
Hi guys,
I have a lisp with points defined like j1, j2......j10. Sometimes i can have only j1...j6, and sometimes j1...j10. I' trying to calculate lowest point on y like this
(SETQ PMIN (MIN (CADR J1) (CADR J2 )(CADR J3 )(CADR J4 )(CADR J5 )(CADR J6 )(CADR J7 )
	    (CADR J8 )(CADR J9 )(CADR J10 )))
when i have only j1...j5 is not working (of course!!). How to do this ? Which condition to add to make this work?
...If j6 exist, then....
how to do this? Thanks!
Consider using the MAPCAR function.
Here's a small example using the coordinates of a rectangle drawn in WCS, then rotated 5 degrees (so clearly one vertex is the lowest):
(defun _LowYcoord  (pointList)
 (car (vl-sort (mapcar 'cadr pointList) '<))
VLIDE Console (lowest Y value):
_LOWYCOORD
_$ (_LowYcoord '((-11.1758 20.4623 0.00) (2.19028 21.6316 0.00) (3.11153 11.1017 0.00) (-10.2546 [color=red]9.93234[/color] 0.00)))
9.93234
_$
** Note that the supplied argument may be a list of any number of coordinates, either 2D (X Y), or 3D (X Y Z).
HTH
(SETQ POINTLIST (LIST 'J1 'J2 'J3 'J4 'J5 'J6 'J7 'J8 'J9 'J10))
(SETQ PCOTAMIN (car (vl-sort (mapcar 'cadr pointList) '<)))
LIKE THIS? HOW?
_LOWYCOORD
9.93234
_$
HTH
(defun _lowYcoord (pointlist)
 (car (vl-sort pointlst (function (lambda (a b) (< (cadr a) (cadr b))))))
Slight modification:
 (car (vl-sort (mapcar 'cadr [color=blue](mapcar 'eval[/color] pointList[color=blue])[/color]) '<))
Example:
(setq J1 '(-11.1758 20.4623 0.00))
(setq J2 '(2.19028 21.6316 0.00))
(setq J3 '(3.11153 11.1017 0.00))
(setq J4 '(-10.2546 9.93234 0.00))
(setq pointList '(J1 J2 J3 J4))
(_LowYcoord pointList)
I don't understand... I need a point... Which is the lowest point in this case? How to use it in the lisp after? I need to set a point... (setq pmin ....) ?? how?
(SETQ PMIN (_LowYcoord pointList)) ???
I don't understand... I need a point... Which is the lowest poit in this case? How to use it in the lisp after? I need to set a point... (setq pmin ....) ?? how?
Sorry, I got hung up on the 'Y' in your previous post:
Give this a try:
 (car (vl-sort (mapcar 'eval pointList) '(lambda (a b) (< (cadr a) (cadr b)))))
*Tips hat to Alan*
Edited by BlackBox
Same question as above...hot to set that point??
Same response as above...
Here's an(other) example from Console using this function:
_LOWYCOORD
_$ (setq J1 '(-11.1758 20.4623 0.00))
(-11.1758 20.4623 0.0)
_$ (setq J2 '(2.19028 21.6316 0.00))
(2.19028 21.6316 0.0)
_$ (setq J3 '(3.11153 11.1017 0.00))
(3.11153 11.1017 0.0)
_$ (setq J4 '(-10.2546 9.93234 0.00))
(-10.2546 9.93234 0.0)
_$ [color=blue](setq pointList '(J1 J2 J3 J4))[/color]
(J1 J2 J3 J4)
_$[color=red] (setq pMin (_LowYcoord pointList))[/color]
_$
Hello... Hello.. Hello... Hello....
:lol:
